Welcome to the North American Subaru Impreza Owners Club Tuesday August 22, 2017
Old 03-06-2007, 04:36 PM   #1
kn0bby8
Member#: 97644
2006 WRX
Default 06 USDM WRX with JDM Ver. 8 6spd
I know what is necesarry to make the JDM Tranny work in an 02-05 WRX. WIll it be the same into an 06? Will I run into problems with the push/pull clutch? Some say no problem others say there could be problems with the push/pull clutch. I called Andrewtech and whoever I spoke to said he honestly didn't know? Is this some type of mystery I am gonna have to spend a ton of money a frustrations on? Anyone know someine with a 6spd in an 06 WRX?
kn0bby8 is offline   Reply With Quote
Old 03-06-2007, 06:13 PM   #2
Sypher
Member#: 106366
2006 WRX
[quote=kn0bby8;17277568] Is this some type of mystery I am gonna have to spend a ton of money a frustrations on?QUOTE]
Yup an yup!!! u are !
Sypher is offline   Reply With Quote
Old 03-06-2007, 06:14 PM   #3
Sypher
Member#: 106366
2006 WRX
no one has done it yet or if they have theres no info out there. And yeah the Pull/push is the main prob.
Old 03-06-2007, 06:49 PM   #4
kn0bby8
Member#: 97644
2006 WRX
There was a someone who posted pics of a black tr that had a 6 sped swap but i cant find the post. Its the tr that is on the ultimate racing page.
U got a ppg box correct? I would hate to spend so much money on ppg gears and be frced to use the crappy subaru syncros.
Old 03-06-2007, 09:03 PM   #5
kn0bby8
Member#: 97644
2006 WRX
Appearantly this car has a 6 speed.
http://forums.nasioc.com/forums/show....php?t=1090764
Old 03-06-2007, 10:40 PM   #6
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
With all the work done to that car, i'd say he probably did a complete pull type clutch/tranny swap...
The problem is a) the clutch fork moves the opposite direction, so you'll need a different master/slave setup and b) whatever clutch fork you do end up using might not work with the push clutch throwout bearing.
Seeing how there is only 6 aftermarket clutch option out there for the push clutch, and it flexes more than a pull style, if you're really set on a 6 speed you should just go for the full clutch/tranny swap...
ExpO is offline   Reply With Quote
Old 03-08-2007, 07:07 AM   #7
kn0bby8
Member#: 97644
2006 WRX
I planned on buying the Transmission Clutch Flywheel and Slave. As far as the clutch will I need anything else?
05 wrx with jdm ver 8 sti wiring issue...?? treystoys Subaru Conversions 9 03-29-2011 02:22 AM
Subaru WRX STI JDM Ver 8 Top Mount Intercooler TMIC GARFIELD Engine/Power/Exhaust 9 11-27-2008 07:19 AM
EJ257 with jdm ver.8 heads comp ratio oldbluwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-31-2005 08:38 PM
Newest Utec compatable with jdm ver.8 eng? serious Engine Management & Tuning 18 08-27-2004 12:25 PM
