03-10-2007, 05:43 PM | #1 |
Member#: 79402
NWIC
Vehicle:'05 STi |
Stock sti wideband W/enginunity
So i have been doing some data logging with enginuity on my 05 sti and have noticed that there is a option to log widebad o2. Is this accurate enough to tune from. I have a stock ecu with 3'' tbe catless and a perrin o2 simulator on the rear o2 sensor if that makes any difference.
It appears to accuratly match the targeted afr in the ecu map so what do you think? I have been eyeing the Lc-1 but if this is an option i would choose to save the $ for other purchases. thanks
03-11-2007, 03:45 AM | #2 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
no, the factory widebands are useless under 11.5:1 or so
03-11-2007, 03:52 AM | #3 |
Member#: 88322
Vehicle:2009 BMW 135i |
The stock O2 is not accurate under 12.5-13:1 or so in practice. There is a thread going on in the Enguinity forum discussing trying to relocate the stock O2 post turbo to see if it does any better, although I don't think that is a great idea regardless of if it makes it accurate.
03-11-2007, 04:06 AM | #4 | |
Member#: 6551
03-11-2007, 06:42 AM | #5 |
Member#: 79402
NWIC
Vehicle:'05 STi |
Thanks for the info. I guess if it sounds to good to be true than it probably is. So back pressure from the header to turbo is what causes the inaccuracy? And the therory on the enginunity forum is that by moving the sensor after the turbo there will be less exhaust pressure and therefore it will be more accurate? So how will the ecu react if you move the sensor since reading will be different and the ecu uses it to check targeted afr?
03-11-2007, 08:13 AM | #6 | |
Member#: 88322
2) see 1 3) I know the delay on my LM-1 WB at the bottom of the downpipe is considerable at idle. Enough that I'm going to guess it will give the ECU a hard time trimming fuel. Honestly, I'd just buy an aftermarket unit like the LC-1. |
FS: STi TMIC, VF39, stock STi injectors, stock STi up pipe | da n00b | Engine/Power/Exhaust | 23 | 11-04-2011 11:25 AM |
Stock STI 6mt Trany mount VS STI Group-n Trany Mount? | KiggerSTI | Transmission (AT/MT) & Driveline | 10 | 06-04-2010 02:06 PM |
FS: (IL)- DW850, Stock STI TMIC, Stock STI TBE, STI UP, Airbox/K&N panel, EBCS... | ImranM847 | Engine/Power/Exhaust | 26 | 02-12-2010 05:43 PM |
is stock o2 sensor on 05 sti wideband? | 005sti | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 05-03-2005 08:24 AM |
STi wideband A/F graph from my dyno | 909 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 10-09-2003 04:01 PM |
