Welcome to the North American Subaru Impreza Owners Club Monday March 27, 2017
Old 07-20-2007, 09:12 PM   #26
Thugthizzle
Member#: 114098
The baffle comes with the oil pan so that has the same part #.. Just got mine today!
Thugthizzle is offline   Reply With Quote
Old 07-20-2007, 09:16 PM   #27
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
yeah!!!
so those part numbers listed are the only things required?
Jon
iNfEk is offline   Reply With Quote
Old 07-20-2007, 11:43 PM   #28
palmerx141
Member#: 58312
WRB Bugeye SQC 217
272whp/283wtq
oh man I'm about to put in a twin scroll kit and this sounds much harder then I thought
How do you do this without lifting the motor at all?
palmerx141 is offline   Reply With Quote
Old 07-21-2007, 12:17 AM   #29
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
It can be done but very difficult to get to rear bolts.
snwman is offline   Reply With Quote
Old 07-21-2007, 12:19 AM   #30
PhastEddie
Member#: 136545
2006 Evolution IX
You're gonna have to lift the motor but its easy. Just unbolt the tranny mount, pitch stop and engine mounts, and put a piece of wood in between the jack and the transmission and jack it up. Keep an eye not to extend any wires or hoses to much and you will have plenty of clearance. I recommend a small ratchet with long extension and swivel socket to get those rear oil pan bolts.
PhastEddie is offline   Reply With Quote
Old 07-21-2007, 12:20 AM   #31
PhastEddie
Member#: 136545
2006 Evolution IX
I did find even that installing this turbo is much easier than trying to fit the stock td04 in place. I am glad I did this.
Old 07-22-2007, 05:44 AM   #32
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
nice! How much the kit set you back? What engi e dod yiu put this on and are you using any engine management system or are yiu using a V8 ECU
Old 07-22-2007, 10:48 AM   #33
PhastEddie
Member#: 136545
2006 Evolution IX
Installed on an 03 wrx. Got it from JDMSpecC4U, paide 1700 for everything, although later I found a couple users had some for sale for like 1500 right after I got mine! Anyhow, I am using the Cobb Streettuner and actually am getting protuned on thursday.
Old 07-22-2007, 11:46 AM   #34
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Doh... well I've got my hands on a v7 pickup, but no oil pan... any chance of a measurement from the mounting surface to the very bottom of both of those pickups? Need to know which oil pan I will need, and not about to order a JDM one.
Old 07-22-2007, 06:38 PM   #35
ARORA_808
Member#: 144073
05 STi
world rally blue
I've been confused about this for a while now......I was looking into getting equal length headers for my 06 wrx and I have read that you have to change to an Sti oil pan......my car has the 2.5L in it....do I still need to change the oil pan? Is it the same as the STi pan since it's basically the same engine just with smaller injectors,turbo and intercooler, does this only apply to the 2.0L?
ARORA_808 is offline   Reply With Quote
Old 07-22-2007, 11:43 PM   #36
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
thanks... Thinking about getting from them as well... It'll be going on a JDM V7 engine which has the same oil pan as the USDM WRX. I'm not sure if the oil pick up is the same one as posted. Also wondering myself if I would just need the pan or everything
Old 07-23-2007, 12:49 AM   #37
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The oil pickup I have looks like the STI one up top, and it was either off a v7 motor or an 02 WRX motor. I'm still wondering if they are the same length (depth) from the motor to the pickup area.
WRX oil pan vs STi oil pan Gigabelova Built Motor Discussion 211 10-30-2016 09:45 PM
WTB: NV STi oil pan and WRX oil cooler lowell787 Private 'Wanted' Classifieds 2 01-12-2010 10:58 AM
STi Oil Pan on 99 2.5 Engine? Soulofdarkness Normally Aspirated Powertrain 3 05-31-2009 04:31 PM
STi oil pan on bugeye? tonecold Newbies & FAQs 26 03-06-2009 12:36 PM
anyone change a wrx oil pan to sti oil pan? 1WRX2NV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-30-2007 09:32 PM
