Welcome to the North American Subaru Impreza Owners Club Thursday March 21, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 03-12-2007, 04:29 PM   #1
Td5turbo
Member Sales Rating: (1)
Member#: 126410
02 WRX Wagon
Default '92 240sx **SUPER CLEAN** silvia converion, sr20det, many mods **TONS of PICTURES**
Asking $10,500 obo
Will trade only for an WRX or WRX STi or Evo (or other AWD car newer than ‘02) and I will give you some cash.
Contact: [email protected]
Car: 1992 240sx SE
Model: Coupe SE
Factory Color: AG2 G Red
Miles: Engine about 50,000 Chassis about 160,000
Modification list
Engine:
SR20DET Redtop with cooling fins (from a ’94 Silvia, last year for the redtop)
Hydrid Development FMIC with piping (using half of factory hotpipe and I just painted the upper coldpipe black)
Megan Racing tubular exhaust manifold
Megan Racing turbo outlet
XS Engineering 3” downpipe (deletes cat)
URAS RS 3” exhaust
APEXi power intake
Manual boost controller set at 12psi
Walbro 255lph fuel pump
Z32 fuel filter
GReddy baffled oil pan
GReddy rocker arm stoppers (RAS)
Brand new engine mounts when engine was put in
Bosch bypass valve (same ones used on Audi’s and VW’s)
Koyo aluminum radiator
Flex-a-lite (FAL) dual 12” electric fans
Battery relocated to trunk
Brand new O2, knock and TPS sensors
Redline 10w-30 oil, just changed to Mobil 10w-30 (because I couldn’t find a local retailer of Redline)
Drivetrain:Exedy Stage 2 clutch (street disk, its thicker than the racing disk)
Mookeeh Short shifter
S15 helical LSD
Redline fluids
Suspension/Brakes/Wheels
Buddy Club Racing Spec Dampers (coilovers)
SPL Parts outer tie rods
Z32 inner tie rods
Adjustable tension rods (not sure on the brand, my buddy got them and I bought them off him because they are very beefy!)
Footwerks rear upper control arms (RUCA’s)
SPL Parts solid aluminum subframe bushings
Suspension Techniques F&R sway bars with bushings
Megan Racing upper strut tower bars F&R
Megan Racing lower rear tie bar
Z32TT (30mm wide) Calipers F&R (Brand new fronts, remanufactured rears..so basically all calipers are brand new, not junky used ones)
Brembo slotted and zinc plated rotors F&R
Z32 E-brake assembly installed and working
Valvoline <DOT4 rated brake fluid
Earl’s Plumbing stainless conversion lines
Z32 1 1/16” (17/16”) brake master cylinder (brand new)
Ichiba front 5-lug conversion hubs
S14 SE rear 5-lug hubs
MB Motorsports Competition 17x9 +27 wheels (7mm spacer up front)
Pirelli 225/45/17 P6 All-season (about 40% left on front and 55% rears)
350z touring wheels (17x8 +33 rear, 17x7.5 +30 front)
Rears with 215/45/17 Potenza’s (about 10% left, good for one last drift session!), no tires on fronts
I had a pair of Crown Victoria Meshies but I cant find them…
Interior:
Momo Competition Steering wheel
Momo hub
Momo horn button
Brand new gray carpet
S14 seats
Alpine headunit with iPod connection cable (CDE-9852)
Alpine type-s 5x7 speakesr front (SPS-570A)
Lightning Audio 5 1/2 speakers rear
Rockford Fosgate 10” Punch HE subwoofer (has a tear, but still works good)
Rockford Fosgate 2-channel amplifier
Custom box (small)
Carpet removed from door panels
Burberry, yes Burberry glove box
I have the digital (HUD) cluster in the car now, but also have an Analog clucter with harness
Autometer 2-pod a-pillar gauge mounts
Autometer ultra-lite boost gauge, mechanical (#4303)
Autometer ultra-lite water temp gauge, electric (#4337)
Autometer ultra-lite Exhaust Gas Temperature (EGT) gauge, electric (#4344), gauge works only sometimes…don’t know what wrong with it so its not hooked up right now, but the sender is taped and run into the turbo outlet
Exterior:
Silvia front end conversion
Carbon Fiber GTR grill
3-projector headlights with working/hooked up fog lights
Aftermarket sun roof (doesn’t invade on headroom)
New paint about 10,000 miles ago (factory repaint AG2 G Red)
Alignment settings:
Camber front: -2.0 degrees
Camber rear: -1.8 degrees
Caster front: 7 degrees
Toe front: 0.0 degrees
Toe rear: 0.0 degrees
The bad about the car:
The car ran runs slightly richer than normal due to the TPS going out (why I said I bought a new one) thus the rear bumper, just above the exhaust, is burnt..or more some black stains, no bubbling of paint or anything
The front bumper has quite a few rock chips on the lower portion. If you were to get a lip it would over about 80% of them up. You cant really tell unless you looking for them and 10ft or closer but they are still there
The trim (like around the windows) on the exterior could use a good touch up with some black paint.
The dash has some cracking above the cluster. You cant see it while your driving, so I forget about it until someone point it out!
A rock flew up about a month ago and cracked the windshield pretty bad at the top on the driver side
The car has been running rich due to the Walbro fuel pump but if you were to get an adjustable FPR (fuel pressure regulator) from NISMO for about $80 it will run perfectly fine
The carpet doesn’t fit 100% factory but you cant expect an aftermarket carpet to! But it fits fine and has no stains!
The sub is sort-of blown, but its an old sub and I don’t even think most who want this car care about the sub but if you want it, it will come with the car, if you don’t I will keep it I guess
The blower for the heater and a/c only works sometimes. I think its just a loose connection but I have been too busy to work of the car lately..i am sure its an easy fix though (like I said, it WORKS, just sometimes so I don’t think it’s a bad blower motor)
The A/C is all in the car but the hose that runs from the firewall to the compressor got cracked and leaked all the Freon out so no a/c (likewise, I just took off the belt). A new hose and you should be set, but don’t quote me on that…it was working before the hose got a hole in it (due to engine movement slowly rubbing a hole in the metal lines)
That all that is wrong with the car…But there is WAY more good than bad about it! I just want to let you guys know about the car fully so your not thinking I am trying to rip you off
Thanks for looking!
Td5turbo is offline   Reply With Quote
Old 03-12-2007, 04:30 PM   #2
Td5turbo
Member#: 126410
02 WRX Wagon
burnt bumper
Old 03-12-2007, 04:30 PM   #3
Td5turbo
Member#: 126410
02 WRX Wagon
Last pic with ROTA GT3 wheels (sold them to pay for 5-lug conversion)
Carbon GT-R grill (and a nice view of SoCal in the background)
The lighting was great that day, it wasnt too sunny, but it give good contrast to the car
A preview and when I picked up my new wheels
The engine bay, torn apart for new turbo parts and to clean up all the wiring
Old 03-12-2007, 04:31 PM   #4
Td5turbo
Member#: 126410
02 WRX Wagon
Harness being redone.
New Rear upper control arms (RUCA's)
The stock T25 turbo
Brand new/Remanufactured F&R calipers
All calipers (they are aluminum so they weight the same as stocks, but are super huge compaired to the whimpy stock brakes)
Front rotors (brembo) with calipers
Calipers were painted with VHT 1000degree caliper paint (about a can for a pair because I put about 8 coats to get them extra glossy and make sure they dont chip). I sanded down the letters so they say NISSAN is silver, kinda cool haha
Old 03-12-2007, 04:31 PM   #5
Td5turbo
Member#: 126410
02 WRX Wagon
Another shot
Drivers side with RUCA's installed, also EARL's Stainless braided brake conversion lines
Passenger side
The car as of yesterday. I am going to paint the wheels black when i get new tires!
Well I got bored of the stock carpet glove box so i decided to baller it up with some Burberry. Hope you like it!
Old 03-12-2007, 04:32 PM   #6
Td5turbo
Member#: 126410
02 WRX Wagon
(fender gap LOOKS bad because you cant see the tire, but it looks nice in daylight)
(car looks like a monster truck, but at least i can go over speed bumps!!!)
I thought it was funny to take this photo because it shows just how freaking SMALL these cars are...i mean LOOK AT THAT ****!!!!!!!
Old 03-13-2007, 04:04 PM   #7
Td5turbo
Member#: 126410
02 WRX Wagon
Located in Charleston SC 29412
Old 03-13-2007, 04:21 PM   #8
kennyvb
Member Sales Rating: (166)
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
i like that glove box idea.
kennyvb is offline   Reply With Quote
Old 03-14-2007, 02:12 PM   #9
Td5turbo
Member#: 126410
02 WRX Wagon
^ thanks! bump
Old 03-14-2007, 11:54 PM   #10
ckcadavona
Member Sales Rating: (9)
Member#: 135730
93 L
Nice car, but I'm not sure about the price. BUMP
ckcadavona is offline   Reply With Quote
Old 03-15-2007, 12:32 AM   #11
mogrl840
Member Sales Rating: (20)
Member#: 85298
Keep talkin **** you
are makin me famous
how much cash are you willing to through in the trade? I got a 2004 sti with mods
mogrl840 is offline   Reply With Quote
Old 03-18-2007, 07:39 PM   #12
Td5turbo
Member#: 126410
02 WRX Wagon
^ Your car is "nice" but i think your asking way to much and the figure I told you isnt what you want...(if infact you want $35k for your STi)
Old 03-18-2007, 07:59 PM   #13
carl s.
Top Scoob 026
Member Sales Rating: (5)
Member#: 119034
96 Open Class STI
i recognize you from 240sxforums (i'm go240 over there). good luck with the sale/trade - mine started at 12k, i ended up selling for 9k
carl s. is offline   Reply With Quote
Old 03-18-2007, 10:03 PM   #14
02fastWRBLUE
Member Sales Rating: (4)
Member#: 52590
pics of headlights on?
02fastWRBLUE is offline   Reply With Quote
Old 03-18-2007, 11:07 PM   #15
Td5turbo
Member#: 126410
02 WRX Wagon
Yup, i know you! You sold the two s13's one blue with chrome grenades and the grey beater...
I'm basically doing the same thing you are and I hope i can get over 10k for it....
no one has even an offer to shoot out?
Old 03-18-2007, 11:43 PM   #16
Dingo
Member Sales Rating: (2)
Member#: 42736
2003 WRX
WR Blue
As a former S13 nut, I appreciate your work and effort, but doubt you will be able to recoupe more than 8K out of what you invested. Modified cars are for pleasure and not investments is the unfortunate truth, yet we continue to do it.
Dingo is offline   Reply With Quote
Old 04-11-2007, 01:37 PM   #17
Td5turbo
Member#: 126410
02 WRX Wagon
Car was pending trade, but that fell through.
I will consider any reasonable offer.
Old 04-11-2007, 01:44 PM   #18
godfather2112
Papi Chulo
Member Sales Rating: (13)
Member#: 53794
... 2017 BMW M2
2017 F-150
sweet 240. I was asking 9 for mine with damn near same mods to body and engine. only got 7
godfather2112 is online now   Reply With Quote
Old 04-11-2007, 02:09 PM   #19
Td5turbo
Member#: 126410
02 WRX Wagon
Old 04-11-2007, 02:09 PM   #20
Td5turbo
Member#: 126410
02 WRX Wagon
tons of caliper clearence
Old 04-12-2007, 01:56 PM   #21
Td5turbo
Member#: 126410
02 WRX Wagon
Old 04-12-2007, 08:52 PM   #22
colin edge
Member#: 97648
That is the cleanest S13 dash EVER! All of them are cracked, faded, or both.
Very nice car. The coupes were always my favorite [I had one] and with the Silvia front makes it even dreamier.
Good luck with the sale, finally a 240 for sale that's not done drifter halfass.
colin edge is offline   Reply With Quote
Old 04-13-2007, 10:08 AM   #23
Td5turbo
Member#: 126410
02 WRX Wagon
^thanks, but it does have a crack! above the cluster....i have yet to see a s13 without a cracked dash, damn nissan! haha.
Old 04-13-2007, 01:37 PM   #24
rpdwrx
Member#: 92904
2002 PSM WRX
1998 RBP WRSX
Great car, wish you were closer.
rpdwrx is offline   Reply With Quote
Old 04-13-2007, 02:58 PM   #25
the mike
Member#: 30926
2003 MBP
Sedan
PMed you.
the mike is offline   Reply With Quote
NC: black 1995 240sx s14 sr20det many mods. j3t Private Vehicle 'For Sale' Classifieds 7 04-15-2009 06:05 PM
FS: sr20det s13 fastback many mods aka_tur Private Vehicle 'For Sale' Classifieds 7 11-13-2006 06:48 PM
FS: s13 fastback with sr20det redtop. many mods aka_tur Private Vehicle 'For Sale' Classifieds 0 10-18-2006 08:08 AM
FS: 1990 240SX Hatchback, Many Mods, Ready for a Swap S-K South East Region Forum 14 06-19-2005 09:55 PM
FS/FT: 1995 240sx w/ SR20DET-Many mods 240sxSR20det Private Vehicle 'For Sale' Classifieds 33 05-26-2004 01:51 AM
