03-16-2007, 02:27 PM | #1 |
Member#: 118769
Vehicle:2006 WRX Sedan Aspen White, XPT Stage 2 |
Engine supposed to turn off when EcuFlash reads ROM?
The engine has to be running when you start EcuFlash, right? When it's in idle (green test connectors connected) and I do a read ROM from EcuFlash the engine shuts off. I can still read and write a ROM but i was just wondering if this was normal.
Another thing. After I rewrite a ROM and disconnect the green connectors, the car won't start immediately when turning the key. It'll make that noise like it's supposed to when the key is turned but the engine won't come on. When i stop and try it a second time, the engine starts fine. Does everybody experience this also? I'll admit, I was too lazy to do a search for this. Please redirect me to a thread of similar subject if there already is one. Thanks.
03-16-2007, 02:47 PM | #2 |
Member#: 113940
E. Canada
Vehicle:2006 WRX Steel Grey Metallic |
No. The engine shouldn't be on. The key should only be turned 1 click so that the accessories are powered, that's it.
03-16-2007, 02:48 PM | #3 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
03-16-2007, 02:52 PM | #4 |
Member#: 118769
OK, thanks. Do you guys get the restart issue i'm having after a reflash?
03-16-2007, 03:14 PM | #5 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
The fuel pump bleeds back to the tank during reflash. Just disconnect the green test connectors, turn the key all the way on without cranking and leave it for about 5 seconds. Your car will start right up.
03-16-2007, 03:16 PM | #6 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
IIRC when you reset the ECU like doing a reflash or pulling the battery, the ECU needs to check and reset some sensors (such as the DBW throttle body). You are probably turning off the car after reflashing, disconnecting the green connectors and trying to fire that bad boy up. Instead, try turning the key on, wait 5 seconds and then crank it.
03-16-2007, 03:19 PM | #7 | |
Member#: 114730
SWIC
Beat you to it by 2 min. ^ But you had a better explanation. |
03-16-2007, 03:22 PM | #8 | |
NWIC
03-16-2007, 10:01 PM | #9 |
Member#: 124282
NWIC
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
03-30-2007, 02:32 AM | #10 |
Member#: 62131
Vehicle:2005 Impreza WRX STi Crystal Grey Metallic |
Well
Deleted
03-31-2007, 03:09 PM | #11 |
Member#: 118779
Vehicle:2006 WRX Black |
My problem is that when I select the Read from ECU, and turn the ignition on y starts conecting but gives mi an error. Is there some issue on the 06 WRX?
04-02-2007, 07:01 PM | #12 |
Member#: 127991
Vehicle:2006 WRX Wagon Aspen White |
^ check under the dash, their is to connectors right under the fuse box panel that has to be connected to flash.
04-02-2007, 11:29 PM | #13 |
Member#: 53665
NESIC
Vehicle:2022 BMW M240i Thundernight |
You need the ignition key to be turned to Start to allow the connection to ECU to happen. Do not start the car if you're planning to read the ROM off the ECU. Once you are done flashing, you need to turn the ignition to off position to get the ECU out of test mode. Disconnect the connnectors, turn the ignition on and the car will start right up. You can't just flash, leave the key in the same position and try to start the car. The ECU will not allow it.
Ecuflash Reading ROM Error | andyvi | Open Source Reflashes | 6 | 01-19-2010 08:20 AM |
Engine map to turn off turbo | fweidner | AccessPort | 10 | 06-13-2007 08:50 PM |
Radio sometimes turns off when I turn off engine | dauss | Newbies & FAQs | 3 | 04-06-2007 12:07 AM |
is the AC supposed to turn on itself when... | Antonios Kintos | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-08-2005 08:30 PM |
Are rear wheels supposed to turn when car is up in air in gear? | ImportVenom | Newbies & FAQs | 7 | 11-10-2003 02:11 AM |
