03-21-2007, 01:07 AM | #1 |
Member#: 48838
BAIC
Vehicle:2008 Stage 2 STI A.W. |
UTEC and Cobb stage 2?
I have an early version of the Cobb stage 2 reflash on my 04 WRX with an unequal length header, uppipe, catless DP, turboXs catback, pulley, k&N short ram, and one step hotter NGK's. I plan to get a bigger turbo soon but want to start with purchasing a UTEC, obviously for the flexibility verses the off the shelf style Cobb maps. My question is if I will be able to piggyback the UTEC to my Cobb staged 2 ECM using the stage 2 as my base with and without the stock turbo? What are my options?
03-21-2007, 08:45 AM | #2 |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
if you have a cobb you can store 5 maps so why mess with the utec? both can have custom maps made by you or a tuner. i say keep the cobb, get a turbo w/ supporting mods and then get a protune.
03-21-2007, 09:56 AM | #3 |
Member#: 48838
BAIC
I only have a reflash. Not an Accessport.
03-21-2007, 11:11 AM | #4 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
The answer to your original question is yes, you can still use the UTEC and use the Stage 2 map as a base.
03-21-2007, 11:26 AM | #5 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
May I ask why you only have a flash and not the AP itself?
Or was it OpenECU Flash or Ecutek? |
03-21-2007, 11:53 AM | #6 |
Member#: 23717
NESIC
Vehicle:2005 Big red |
Before the AP you had to mail your ECU to be reflashed.
TMS |
03-21-2007, 01:56 PM | #7 |
Member#: 50267
SWIC
he said he has a cobb reflash so he must have used open source to copy it. thats the best way to go.
03-21-2007, 04:37 PM | #8 |
Member#: 108089
03-21-2007, 08:04 PM | #9 | |
Member#: 48838
BAIC
And the reason I don't have an AP is because before 2004 Cobb offered a reflash service called AccessECU which was basically an off the shelf map which was physically written onto my stock ECM. |
03-21-2007, 08:44 PM | #10 |
Member#: 50267
SWIC
my buudy has a ecutek flash combined with utec so i dont see why it wouldnt work. when the utec is on the stock map setting the car is only gloing off the ecutek reflash. his other utec maps are for good gas and nos.
03-21-2007, 09:29 PM | #11 |
Member#: 48838
BAIC
How often is the UTEC on the stock map setting? The problem is that not only is the map an early generic one for non CA gas but since having the reflash I have added a K&N SRI, Perrin pulley, and unequal length header. After reading Unibombers faq regarding the Accessport these mods are doing nothing for my car, thus my need for a UTEC.
03-21-2007, 09:35 PM | #12 |
Member#: 23717
NESIC
About the only thing the stock ECU will be used for is the low load and idle. After the UTEC is in control what is on the stock ecu won't matter. Since you didn't change injectors the Utec Stage 2 base map should be ok to start with.
TMS |
03-21-2007, 10:20 PM | #13 |
Member#: 50267
SWIC
so you are wanting a utec to compensate for your flash being wrong for your car? since you live in bay area they are plenty of tuners who can flash it for your current mods. if you have the correct flash put on you could use the utec(if you still wanted it) to run gas maps.
03-21-2007, 11:05 PM | #14 | |
Member#: 48838
BAIC
Are the gas maps you're reffering to100 octane, alcohol injection, etc? |
03-22-2007, 12:03 AM | #15 | |
Member#: 50267
SWIC
have you thought about a tactrix cable? you could flash over your old cobb and still tune it yourself. the learning curve is very close to utec. if you are initerested in learning you should meet some locals in your area who have experience and have them show you the ropes. |
03-22-2007, 05:51 AM | #16 | |
Member#: 23717
NESIC
TMS |
03-22-2007, 08:41 AM | #17 |
Member#: 50267
SWIC
you might be right although most of our local boys that have cables are former utec self tuners and picked it up with no problems.
03-22-2007, 11:36 PM | #18 | |
Member#: 105404
NESIC
Vehicle:2006 FPGreenSTI SOLD 04 GMC 2500HD Duramax CC |
It takes a lot of reading and stuff to work with Enginuity....im still slowly learning from reading and working with a local member who knows quite a bit....plus i did some minor tuning of 4 stroke turbo snowmobiles |
WTB:04-05 bumper, headlights and fenders and cobb stage 2 | jogfrogjog | Private 'Wanted' Classifieds | 0 | 07-15-2009 01:02 AM |
UTEC and Cobb stage 2? | SonnyCrockett04 | UTEC | 1 | 03-22-2007 10:34 PM |
scoobysport downpipe, axle back and cobb stage 2 reflash | showcasewrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 03-22-2004 08:22 PM |
what should an UP, DP, catback, and cobb stage 2 put out? | WRblueX_Guy | Proven Power Bragging | 12 | 01-25-2004 09:51 PM |
FS: (NEED TO GET RID ASAP) Walbro Fuel pump and cobb stage 2 | WRX Jim | Mid Atlantic Impreza Club -- MAIC | 0 | 10-18-2003 10:42 AM |
