03-23-2007, 12:08 PM | #1 |
Member#: 81234
HELP! ECU sensing knock with upgraded valvetrain
Hello Gurus,
I just installed Cosworth cams and valvetrain. Trying to tue with ecutek, and it senses knock, which in turn retards timing up to 12 degrees! I know there's no knock at all. What can I do other than completley disabling the knock sensor? HELP! thanks in advance
03-23-2007, 01:12 PM | #2 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
is the lash set properly? why is the new valvetrain so much noisier?
03-23-2007, 01:32 PM | #3 |
Member#: 107472
New valvetrain has double springs. Valves are adjusted to cosworth's provided specs.
03-25-2007, 01:45 AM | #4 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
Newly Minted 257/WRX hybrid -- rod knock or noisy valvetrain? | wigglesxjr | Built Motor Discussion | 45 | 12-09-2012 04:36 PM |
6th gear UTEC to ECU transition knock ... Need Help | WRX-Blue-Mica | Engine Management & Tuning | 7 | 12-21-2004 10:25 AM |
where to get phase1 head upgraded valvetrain | YaZahX | Normally Aspirated Powertrain | 5 | 10-20-2003 11:45 AM |
Can I keep boost controller with upgraded ECU? | wReXeRw | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 01-30-2003 02:12 PM |
Does UTEC sense knock? | rallytuned | Engine Management & Tuning | 5 | 10-15-2002 07:04 PM |
