03-26-2007, 01:47 PM | #1 |
Member#: 129060
Vehicle:2007 STI White |
Stumble, need advice
Mods:
bullseye power (small)16g STI TMIC Modded Stock Injectors Warbro 255 3" TBE I flashed my 02 with the big16g map from openecu. its the 16g map that in the 02-05 modded section. Once i flashed and started the car with my new turbo setup(the 16g) the car wouldnt run right, it sputtered and almost seemed like it has a huge miss in the engine, but when i rev it it sounds fine, this leads me to beleve i dont have a setting right, i played with the injector flow scaling to see if i could improve the idle with no luck. any ideas? the car just stumbles and stumbles and then cuts off. the only things i noticed was the slight smell of gas in the exhaust and steam from the exhuast where we acceddentally spilled a little coolent in the uppipe while taking off the old turbo.
03-26-2007, 02:59 PM | #2 |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
injector issues? flow tested?
03-30-2007, 02:44 PM | #3 |
Member#: 10955
NWIC
Vehicle:07, 06,01,93 I have 4 domtuned subys |
Post or email me your latency values and injector scaling.
Are the injectors you are using out of another 02 or an 04? The injector latency has changed over the years some. Also, you might need to make a small change to the MAF cal in the idle voltage regions to stabilize the air signal and prevent large changes in fueling. |
04-01-2007, 10:39 PM | #4 |
Member#: 53665
NESIC
Vehicle:2022 BMW M240i Thundernight |
Indeed. Modded injectors are not created equally. There's lots of variations between them and I believe they all require MAF table recalibration to get them to run right. They do not flow in liner fashion so that makes it harder to tune. Price you pay for savings a few bucks. There's plenty of people here running with modded stockers that got the tune right so you should find plenty of useful help.
04-11-2007, 05:55 PM | #5 |
Member#: 92614
E. Canada
did you find anything my cars running bad with modded stock injectors
04-12-2007, 10:11 AM | #6 | |
Member#: 14911
Vehicle:Not A Wagon! 2011 WRX - 285s on 18x9.5 |
04-13-2007, 12:32 AM | #7 |
Member#: 10955
NWIC
not the same, but very small changes.
the factory ecu maf cal has large changes. |
I need advice. N00bie relationship advice. | Pretty Waste | Off-Topic | 52 | 07-28-2006 01:13 PM |
Need OTter help...new puppy coming and I cant stop it. Need advice... | kaisersouse | Off-Topic | 83 | 04-25-2006 04:41 PM |
Need to replace front rotors/pads on 2002 OBS - Need Advice! | mekkon | Brakes, Steering & Suspension | 6 | 04-24-2006 06:16 PM |
Need advice ! new home need cheaper car but my wagon is leased | Karlos | Off-Topic | 2 | 03-05-2004 10:29 PM |
i need a rear lip, need advice and opinions | Tobey | Interior & Exterior Modification | 2 | 08-01-2003 06:35 PM |
