03-26-2007, 05:18 PM | #1 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
How to tune for a GM Boost Solenoid?
I want to install a GM boost solenoid and tune my car to use it
What should I start doing first and from then on?
03-27-2007, 12:00 AM | #2 |
Member#: 29716
Vehicle:2006 wrx wagon booze powered e85 monster |
Well it depends on what turbo you're running. If it's the stock turbo, you are going to need to drop both the initial and max wgdc tables by about 40 points. You are also going to want to reduce all three of the turbo dynamics tables as well as the temp compensation table.
03-27-2007, 08:57 AM | #3 | |
Member#: 108089
anything else I should know? or should I just start off with that and go on from there |
03-27-2007, 08:34 PM | #4 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
'scribed. I want to do this on my VF39. I'll report back on what worked.
03-27-2007, 09:04 PM | #5 | |
Member#: 29716
As far as the temp compensation, you could probably multiply the entire thing by, oh I dunno, 0.75. Remember, with the GM BCS a little goes a LONG way. Thus, leaving the stock temp compensation map will cause your boost to go all over the place with large temp swings (especially at this time of year). Have fun. |
03-29-2007, 08:41 AM | #6 |
Member#: 80939
South East
Also remember to easy onto boost at first to see what psi you're hitting and make small to medium increments.
03-30-2007, 03:23 PM | #7 |
Member#: 14911
Vehicle:Not A Wagon! 2011 WRX - 285s on 18x9.5 |
This is what I'm using on a TD04 with uppipe, Bellmouth Downpipe, and 3" catless...
Code:
Turbo Dynamics (Burst) -2.94 -1.70 -0.77 0.00 0.31 0.77 1.70 2.94 4.51 -5.50 -2.00 -0.79 0.00 0.70 2.50 9.00 20.00 40.00 Code:
Turbo Dynamics (Continuous) -2.94 -1.70 -0.31 0.00 0.31 0.77 1.70 2.94 4.51 -1.50 -0.50 -0.10 0.00 0.15 0.50 1.50 7.00 20.00 Currently my Wastegate Intake Temp Compensation is set to all 0's and I haven't seen any variations due to temp. Just for the heck of it, here is my Max Wastegate Duty table. Keep in mind that you may want to start below these values and work up: Code:
Max Wastegate Duty 12 24 42 49 62 76 88 100 2000 0.0 0.0 0.0 39.8 55.1 69.9 80.1 94.9 2400 0.0 0.0 0.0 29.7 44.9 60.2 69.9 80.1 2600 0.0 0.0 0.0 25.0 37.1 51.2 60.2 66.0 3000 0.0 0.0 0.0 25.0 37.1 51.2 60.2 66.0 4000 0.0 0.0 0.0 25.0 37.1 51.2 60.2 66.0 5000 0.0 0.0 0.0 25.0 37.1 51.2 60.2 66.0 5500 0.0 0.0 0.0 25.0 37.1 51.2 69.9 75.0 7000 0.0 0.0 0.0 25.0 37.1 51.2 64.8 69.9 |
03-30-2007, 03:39 PM | #8 |
Member#: 29716
Yeah, that table is totally not going to work for an '06 WRX.
03-30-2007, 05:21 PM | #9 | |
Member#: 53665
NESIC
Vehicle:2022 BMW M240i Thundernight |
Holy Cow! You're dialing +40% WGDCs on the gain table. That sounds like insanity to me. My table ends at 3psi with 5 WGDCs. That yields stupid fast spool with slight spiking on my car. I can't imagine what 40 will do. Maybe scaling the table higher and dialing in something really big will help spool but even 20 at 3 psi seems really high. I do have my turbo and DP wrapped but I doubt that would account for such a big variation. It is possible that you're reaching the physical limit of how fast the turbo can spool. Dialing 20 or 40 will not do that much more for it. Please post some more info that I asked for above so I can get a better understanding how this is working for you. |
03-30-2007, 07:14 PM | #10 |
Member#: 14911
I've been running these values for months, so everything from -8F to 75F has been stable. I loaded these same tables on another 2.0 WRX at Stage 1 (gutted uppipe) and he was hitting 16 psi with a 16.4 psi target. This is probably due to the fact that his wastegate arm hasn't been tightened. He was running an MBC before and has had nothing but good things to say about the boost control with my tables. Here is my Target Boost for 100% throttle:
Code:
RPM Boost 2000 16.86 2500 17.94 3000 18.41 3500 18.41 4000 18.41 4500 17.94 5000 17.33 5500 16.55 7000 14.08 Code:
Time RPM Boost TPS WGDC 28842 1884 -10.447 0 0 29052 1869 -9.141 7.45 0 29272 1941 -3.482 17.25 0 29473 1864 0.435 82.75 40 29673 1946 1.016 100 96.86 29873 2022 1.596 100 96.08 30084 2027 2.322 100 96.08 30284 2070 3.047 100 94.51 30484 2125 3.627 100 92.16 30685 2191 4.208 100 89.8 30885 2214 4.933 100 88.63 31085 2258 5.514 100 85.49 31295 2327 6.239 100 83.53 31496 2400 6.965 100 81.96 31696 2463 7.835 100 77.25 31896 2553 8.996 100 70.98 32097 2603 10.157 100 67.45 32297 2701 11.463 100 67.45 32507 2784 12.914 100 67.45 32707 2859 14.8 100 67.45 32908 2967 17.122 100 67.45 33108 3051 17.992 100 67.45 33328 3171 18.282 100 67.45 33549 3333 19.008 100 67.45 33749 3418 18.573 100 66.67 33949 3496 18.427 100 66.67 34149 3646 18.427 100 66.67 34350 3716 18.427 100 66.67 34550 3826 18.137 100 66.67 34750 3927 17.847 100 67.45 34951 4032 18.573 100 67.45 35151 4157 18.718 100 67.45 35351 4266 18.573 100 66.27 35552 4368 17.702 100 67.45 35752 4443 17.847 100 67.45 35952 4579 17.992 100 67.45 36152 4647 17.702 100 67.45 36353 4756 17.702 100 67.45 36553 4908 17.412 100 67.45 36753 4960 17.267 100 67.45 36954 5037 16.686 100 68.63 37154 5144 16.396 100 69.41 37354 5219 16.396 100 70.98 37554 5296 16.106 100 72.16 37755 5415 15.961 100 73.33 37955 5547 15.816 100 74.51 38155 5589 15.525 100 76.08 38356 5665 15.38 100 76.47 38556 5738 15.09 100 76.08 38756 5864 14.8 100 76.08 38956 5896 14.51 100 75.69 39157 5929 14.51 100 75.69 39357 6014 14.075 100 75.29 39557 6147 14.075 100 75.29 39758 6224 13.784 100 74.9 39958 6260 13.494 100 74.51 40158 6292 13.494 100 74.51 40358 6421 13.349 100 74.12 40559 6460 13.204 100 74.12 40759 6488 13.204 100 73.73 40959 6585 13.204 100 73.73 41160 6661 13.204 100 73.33 41360 6702 13.059 100 72.94 41560 6690 13.204 100 72.94 41760 6812 13.204 100 72.94 41961 6862 13.059 100 72.55 42161 6900 13.204 39.61 72.16 42371 6313 -10.302 0 0 Code:
Time RPM Boost TPS WGDC 143817 2309 -11.027 0 0 144037 2323 -8.561 9.02 0 144257 2279 -6.675 9.8 0 144478 2355 -1.306 25.49 0 144698 2437 0.29 35.69 0 144898 2502 2.176 69.41 46.67 145098 2568 3.627 100 67.84 145299 2792 5.369 100 67.84 145499 2955 7.835 100 67.84 145709 3174 10.882 100 67.84 145910 3415 14.365 100 67.84 146110 3735 17.412 100 67.84 146310 4015 17.847 100 67.84 146510 4298 17.122 100 67.84 146711 4647 16.976 100 67.84 146911 4973 16.541 100 67.84 147121 5137 10.737 0 0 147332 5017 -8.996 0 0 Code:
Time RPM Boost TPS WGDC 11967 3864 -11.463 0 0 12188 3796 -9.867 7.84 0 12408 3854 -3.047 38.43 0 12628 3868 3.337 99.22 67.45 12849 4065 8.851 100 67.45 13049 4221 15.235 100 67.45 13249 4345 18.137 100 67.45 13450 4534 18.282 100 67.45 13650 4702 17.557 100 67.45 13850 4886 16.976 100 67.45 14050 5057 16.396 100 67.45 14251 5219 15.961 100 67.84 14451 5423 15.525 100 69.02 14651 5539 15.09 100 70.2 14852 5695 14.8 100 71.76 15052 5841 14.51 100 73.73 15252 6063 14.075 100 74.9 15472 6078 3.337 16.08 0 15683 5910 -9.576 0 0 |
how to tune for injectors | b0nd18t | Open Source Reflashes | 13 | 07-08-2008 08:19 PM |
For Sale: GM Boost Solenoid n and Harness | mrtrex | Private 'For Sale' Classifieds | 2 | 11-16-2005 12:32 PM |
how to tune for headers/intake/intercooler w/ streetuner? | anthonyrb98 | Engine Management & Tuning | 2 | 04-01-2005 10:10 AM |
UTEC: How to tune for added displacement? | LiquidForce | Engine Management & Tuning | 2 | 04-04-2004 01:13 PM |
How to tune for intercooler upgrade? | Chef_C | Engine Management & Tuning | 2 | 09-23-2003 07:07 AM |
