04-02-2007, 11:07 PM | #1 |
Member Sales Rating: (4)
Member#: 23313
Vehicle:99' 2.5Rs black |
99' Rs Part Out!!!
Alright, I'm swapping a full 04' Wrx drivetrain into my car. Tons of stuff to sell. I'll list as many as I can think of and if you think I may be swapping it out just ask and I'll let you know.
Engine- New short block at 60k miles So this block has around 45k Trans- 05 non turbo Legacy trans I've put maybe 10k miles on it. But if you're interested in it ask me about it because you'll have to crack the case and put in a speedo gear. Rear- Stock Rs Rear obviously 4.11's. Front and rear Rs axles- Front are beefed up Fidanza axles rears are stock Front and rear brakes- I'm going to use the 04's since they are newer but the ones on my Rs are the same thing as the Wrx brakes. I upgraded the front brakets and will sell the rotors that the came with all my parts. Steering Rack- Stock Rs no problems no noises Rs dashboard- painted some parts so if you want pictures let me know Stock Rs white faced gauges- Odometer reads 99,7xx I forget the rest. Super AFC II- Used about a year bought Cobb Ap 2.0 so I don't need it. Random Tech cat- used for a few years works great Stromung mid pipe- It was way to loud so I put in a resonator also when removing apparently stromung just tack welds the flange on there and when I took it down they all broke. Pipe isn't ripped appart or damaged. The flange just needs to be welded back on and good as new. Clutch and Flywheel- Again has about 10k on them. It's an Exedy street clutch with a fidanza 9 lb 2 piece flywheel.
04-13-2007, 10:36 PM | #9 | |
Member Sales Rating: (1)
Member#: 462
NESIC
Vehicle:2000 Impreza 2.5 RS SCCA Rally Cross Car |
04-14-2007, 02:25 AM | #10 |
Member#: 23313
Only part left is my axle back. I was going to keep it but with me putting in the rear subframe I might have to mod it and I don't feel like doing that. I'll probably stick with the sti muffler that came with it. I won't know untill everything is together though.
04-14-2007, 02:44 AM | #11 |
Member#: 23313
Pmed you. It wasn't in my sent box though. Let me know if you got it. I just put prices next to stuff but it's not set in stone expecially if you're going to be buying a lot of stuff.
05-18-2008, 04:23 PM | #12 |
Member#: 180331
i want ur cat! Is it the random tech with And will it fit my 99r.5rs? If so, I want it! I'm having a lack of power between 3-4k rpms and i beleive its either due to a clogged cat or an 02 censor. I've got borla headers and catback, so this will finish it up in th exhaust department quite nicely.
05-18-2008, 11:10 PM | #13 | |
Member#: 23313
PA: Stock 99' RS parts | Seanrob | 1993 - 2001 Impreza Specific Parts | 4 | 07-05-2009 12:09 AM |
COMPLETE 2.5 rs Part out! Lots of Parts | snowcrzy | SCIC Private Classifieds | 17 | 01-23-2009 05:11 AM |
Crashed RS part out!! phase one all interior bits! some out side no drivetrain YET | scobaru | MWSOC Private Classifieds | 48 | 01-19-2008 11:57 PM |
99' RS Part out feeler thread | Aaron'z 2.5RS | Complete Car Part-Out | 20 | 12-14-2007 10:10 PM |
02 RS Part Out! Rotas, Axxis Ultimates, Stock Parts Galore! | DrBoy01 | Tri-State Area Private Classifieds | 15 | 08-06-2006 01:37 PM |
