04-11-2007, 05:57 PM | #1 |
Member#: 92614
E. Canada
Needing map for modded injectors and vf39
Was wondering if anyone has a map for modded injectors with a vf series turbo, my car doesnt seem to be running right and i cant get the injector scaling right along with some other things
04-11-2007, 10:50 PM | #2 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
what kind of modded injectors?
04-12-2007, 01:22 AM | #3 |
Member#: 92614
E. Canada
wrx stock injectors from a 2005
04-12-2007, 08:42 AM | #4 |
Member#: 114730
SWIC
Can't help you there but someone has got to know the injector flow and latency for those injectors. If you can get those 2 right, I can help you with the rest
04-12-2007, 10:16 AM | #5 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
I got a map made for this setup as long as you have a Fuel Pump upgrade as well. PM me your e-mail address and I'll send it to you tonight when I get home.
04-12-2007, 01:26 PM | #6 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
04-12-2007, 01:41 PM | #7 |
Member#: 88322
Vehicle:2009 BMW 135i |
I'd revert to a 100***37; stock map, then only touch the injector scaling and latency settings. It sounds like you've been jacking with more than you should on the tune.
I wouldn't run someone else's map. Find someone local to tune it right. You never know what physical problem someone else might have tuned around with their map. They might have a leak tuned out in their map that could blow your engine. |
04-12-2007, 03:05 PM | #8 |
Member#: 92614
E. Canada
its a base vf39 map that has been modified to modded injectors. how do i do the injector scaling and such on my own
04-12-2007, 03:52 PM | #9 |
Member#: 114730
SWIC
04-12-2007, 04:21 PM | #10 | |
Member#: 88322
Is this a map you paid for? If not maybe you can post it. If you did pay for it, why don't you ask for support from the provider, since we're never going to be able to really help you blind. We'll never know what other things could be jacked up in this tune without being able to look at it. Especially since you started to mess with it, no offense. Are you on a stock intake? If not, can you swap back to stock intake? I agree you really need a fuel pump as well. And a wideband, while we're at it. |
04-12-2007, 04:37 PM | #11 |
Member#: 34860
Vehicle:2005 Forester CGM |
If these are modded stockers he shouldn't have to change the latency. He should have to change the scaler and probably tune the intake calibration table.
04-12-2007, 05:04 PM | #12 |
Member#: 88322
Well I just realized you also posted on Enguinity. There you mentioned throwing several CEL codes, which you failed to mention here.
Someone posted a map on Enguinity for you. Hopefully that will get you close enough, but really, you should pony up for the tune. The tune isn't the part you should decide to cheap out on. |
04-12-2007, 05:29 PM | #13 |
NWIC
I agree with everything Freon has said. Even if I sent him a map it would only be sort of close. Each set of modded injectors flows differently.
04-12-2007, 10:48 PM | #14 |
Member#: 92614
E. Canada
i was thinking if i cant get this map to work, i would sell a set of stock injectors i have here, plus get the ones in my car flow tested and cleaned then sell them and pick up a set of pink and run a cobb map. Can i run injectors out of an 06 wrx i heard there side feed
04-13-2007, 06:27 PM | #15 |
Member#: 92614
E. Canada
aight i got the map to work for my car but im gonna go with a set of smaller injectors so i can run a base map, kind of limited on funds right now to get a tune, have a forsale thread up with these injectors plus a stock set. thanks for everyones help
04-14-2007, 03:17 AM | #16 |
Member#: 6551
that's what i posted on the enginuity forum. Running injectors that flow roughly twice the amount of fuel with the same(read stock) fuel pump is nuts.
Yes the moddeds do tend to flow differently but for the most part you can get the maps close, the problem is that he's already started with a modified VF-39 map and is trying to make that work...who knows what was changed in that map he's running. |
06-20-2007, 12:44 PM | #17 | |
Member#: 31016
NWIC
Vehicle:2016 Focus RS (blue) 2005 WRX Wagon (white) |
read this thread for more details: http://forums.nasioc.com/forums/show...atency+scaling |
I need help with injectors and vf39 install! | street_racen_va | Mid Atlantic Impreza Club -- MAIC | 6 | 10-07-2009 02:19 PM |
I need an Accessport map for 650cc injectors! Help!!1!1 | trustSTI | AccessPort | 11 | 11-29-2006 12:05 PM |
Need UTEC start up map for MOD STI injectors please. | AXA | Engine Management & Tuning | 0 | 01-28-2005 07:43 PM |
utec map for 800cc injectors and race gas. | oldbluwrx | Engine Management & Tuning | 9 | 06-21-2004 04:44 AM |
Need a utec map for 800cc injectors. | oldbluwrx | Engine Management & Tuning | 6 | 05-15-2004 07:13 PM |
