04-12-2007, 01:29 PM | #1 |
Member#: 108872
2.5 STI Hybrid - share some tuning tips!
I am in the process of doing the STI hybrid swap. I will be tuning with open source and could use some tuning tips.
My mods are: stock wrx heads STI headgaskets modified stock injectors VF22 TurboXS intake lightweight flywheel LC1 O2 sensor TXS knocklite I know there are some others here with similar setups so I'm looking for your advice on what ways this will differ from the stock maps and any specific trends related to this setup as far as timing or fueling go. If somebody has a map they could send me to use as a base map it would help me out a ton.
04-15-2007, 03:30 AM | #2 |
Member#: 4293
SCIC
Vehicle:2002 WRX Midnight Black Pearl |
subscribed...i'll be headed down this route soon...
-Joseph |
04-17-2007, 02:22 PM | #3 |
Member#: 73609
International
Vehicle:2002 wrx White |
send me your map
i will add hi det / lo det / timing / correction tables to it and maf curve |
04-17-2007, 02:26 PM | #4 |
Member#: 4293
SCIC
radrider, how are you calibrating your knocklite? at a stop in neutral? while rolling in gear? The TXS instructions a little bit vague on how/when you should calibrate it.
I have an LC1 as well -Joseph |
04-17-2007, 02:36 PM | #5 |
Member#: 41561
Vehicle:04 GT3076 2.1 Stroker = Broken 3rd |
i have a map but its for the utec its at the bottom of the page.
http://forums.nasioc.com/forums/show....php?t=1128301 |
04-18-2007, 06:53 PM | #6 |
Member#: 80928
Vehicle:2013 XV Crosstrek MBP |
My hybrid is almost together and I'd really like to hear some input on this as well. I already have a tactrix cable and I think I'm going to go ahead get an LC-1...just because :P The knock light thing...I'd rather tune my so that it's never that close to being an issue. I plan on logging very frequently anyway sooo prolly won't need it. I hope....
04-22-2007, 09:18 PM | #7 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
do steady state pulls increments of 1k in rpm
so you can monitor the afrs. after you get done with that full pull. you will be building a custom fuel map that is taylor suited for you engine. after fuel monitor boost. then repeat for timing |
04-23-2007, 10:47 PM | #8 |
Member#: 44422
SWIC
Vehicle:2009 G8 GT Cammed, sprayed, stalled |
What ECU are you using?
04-23-2007, 11:18 PM | #9 |
Member#: 74753
BAIC
Vehicle:2003 Wrx 2.5Lw/gt30r Team Snail |
you have to pull alot of timing over stock
04-24-2007, 01:06 PM | #10 |
Member#: 108872
Calibrate the knocklite in nuetral as the engine won't knock without load. This is to get a baseline for the amount of noise the engine makes.
04-24-2007, 04:14 PM | #11 |
Member#: 78967
VIC
Vehicle:2011 335i Black |
is the turbo xs knock light reliable? im thinking on getting one.
04-25-2007, 12:01 PM | #12 |
Member#: 108872
04-27-2007, 02:28 AM | #13 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
04-27-2007, 02:31 AM | #14 |
Member#: 74753
BAIC
04-30-2007, 02:37 PM | #15 |
Member#: 131667
sounds sweet man, keep up the good work!
how soon till you plan to be up and running? |
04-30-2007, 05:22 PM | #16 |
Member#: 108872
...new engine is going back into the car tommorow!
05-03-2007, 02:32 PM | #17 |
Member#: 108872
The new engine is in the car. Does anyone have an open source map I could start out with?? I'm not sure how to read the UTEC map posted above...
I need to break in the motor and the old map is just a stock 02 wrx code. Most of the upgrades are new so I'm not sure how safe the stock map is. If I can't find a map, I will probably just change the map by scaling the injectors, zero out the duty cycle for the boost solenoid, and take 3 degrees of timing out at higher load values. Then I will monitor AFR and make sure that is in the ballpark and not too rich or lean. Break it in for 1000 miles or so, then start tuning and increasing boost and adjusting timing. Does this method sound safe to you more experienced tuners? I know an AFR around in the high 10's, low 11's is good for high load on 93 octane but what about lower load values? I would imagine it would run much leaner than 11:1 at low loads so it can transfer smoothly into closed loop? Also, does the TurboXS short ram intake mess up the fuel calibration? It is supposed to be the same size tubing and therefore a direct replacement but I forgot to verify the actual diameter when it was off the car. |
05-07-2007, 03:39 PM | #18 |
Member#: 22902
TXIC
Vehicle:2005 STI CGM |
Bump
Bump....Interested in answers for your questions.
05-07-2007, 03:49 PM | #19 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
I am thinking the same with meth kit. pnp heads and groppe-s stage 2 block. Just waiting for my 2.0 to die. 141k currectly. Kind of wondering if I should stay with a pnp vf30?
05-15-2007, 05:35 PM | #20 |
Member#: 68197
South East
Vehicle:2005 OBP WRX PPG + EJ257 |
bump....my 2.5 hybrid swap should be done by the end of this week, and ill have to drive it around untuned for a couple weeks. im runnig a 7c fp green and modded stockers
05-15-2007, 05:41 PM | #21 |
Member#: 74753
BAIC
05-16-2007, 02:49 PM | #22 |
Member#: 4293
SCIC
is anyone else having problems with the stock 2.0 WRX knock detection being a little sensitive like in post #12 in this thread:
http://forums.nasioc.com/forums/show....php?t=1265068 -Joseph |
05-17-2007, 03:35 PM | #23 |
Member#: 4293
SCIC
So after people have tuned the timing down on these hybrids, are people getting ECUs pulling timing randomly? Seems to be an endemic problem on enginuity.org. People here seem to have had some luck, so maybe i t's a car to car thing, and not something inherenetly wrong with 2.0L ECUs?
-Joseph |
05-18-2007, 07:06 AM | #24 |
Member#: 49667
Vehicle:2004 WRX 2.5 Hybrid 8cm18G - PPG Helical |
You will just have to see how your ECU reacts to your specific engine. Maybe it won't pull timing, maybe it will. Just make sure you get your tune really conservative and see if it is pulling timing. The knocklite should help you confirm if it is real or not.
Make sure you check for anything that could be causing false knock before you just call it an over-sensitive ECU. Loose heatshields, other rattles, over-torqued knock sensor, etc. Then try cutting the wire you tapped in for your knocklite (if you are not running a separate sensor) to make sure your knocklite isn't causing the ECU to see false knock. If it does have issues with false knock, your only choice is pretty much a UTEC or Hydra. I went the UTEC route and it works exceptionally well for my hybrid swap. I tried a lot of things in order to eliminate the knock problems, but without some kind of custom active filtering of the knock signal or a change to the ECU code you are pretty much out of luck. |
Max WHP for 2.5 STI on 91 Octane w/ mods and tune | NewSuby | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 14 | 03-08-2017 12:11 AM |
good turbo for 2.5 STI hybrid swap? | swift2fly | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 38 | 01-16-2007 01:24 PM |
WRX Head/2.5 STi bottom Hybrid 12.92 @ 106.19 | Ronin Quickblade | Proven Power Bragging | 8 | 05-25-2006 09:02 PM |
new 2.5 rs wagon shared parts question | FromEvoToRS37 | Normally Aspirated Powertrain | 5 | 07-16-2005 05:09 PM |
Cometic gasket and 2.5 STI hybrid users | RiftsWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 02-06-2004 06:52 PM |
