04-12-2007, 07:28 PM | #1 |
Member#: 141347
SCIC
Vehicle:2005 WRX WRB |
Question the effect of flashing the ECU
Since you are flashing the ROM on the stock ECU, could the ECU go bad after multiple reflashes? The memory is not RAM which can be reflashed repeatedly so a friend of mine theorized that constantly flashing the stock ECU is not good. I'm sorry I don't know much about openecu tuning or flashing.
04-12-2007, 08:13 PM | #2 |
Member#: 115771
NWIC
Vehicle:2006 WRX WAGON OS Stage 1 |
they guarantee around 100 reflashes but there are people that have flashed 100's of times and it is still fine. Search, there is a lot of info on the subject
04-12-2007, 10:27 PM | #3 |
Member#: 141347
SCIC
Trouble is finding the right keywords to search.
Thanks for the input though. |
04-12-2007, 10:51 PM | #4 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
I have about 200 on mine and I know of others with much more. I've yet to hear of an ecu failing because of too many flashes. Try searching 'flash limit' or 'reflash limit' There are a lot of posts on it.
effect of stage 2 ecu reset on reflash | Redboss | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 08-31-2007 03:37 PM |
Question about the effects of A/F, Timing, and boost change in Version 5.8 UTEC | bluesube2000 | UTEC | 4 | 08-21-2007 11:01 AM |
what are the effects of running a dump pipe right off of the stock downpipe? | xias07wrx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 04-24-2007 12:10 PM |
Effects of 04 WRX ECU swap with 04 ECUtek | PinnacleChronos | Engine Management & Tuning | 3 | 09-18-2005 02:03 PM |
will stock ECU cancel out the effect of a changed fuel map? | twlai | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 08-09-2002 03:47 PM |
