Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Old 04-23-2007, 11:08 AM   #1
spit_heron
Member#: 23655
Default Center Diff Failure and Replacement
edit: im gonna try to resize pics
Car: 2002 Wrx 120k miles, about 60k at stage 2.
Symptoms: Very loud rotational grinding noise coming from under seat during accel and decel
Suspected the center diff due to oil coming out of shift linkage area and extension case.
Drained the trans oil and it looked contaminated with a shiny liquid.
Take the extension case off the trans and find this:
So it looks like the seal? on the diff blew and chunked itself in the extension case, which in turn mangled and chipped a few teeth on both the drive and driven gears. It looks like I need a new diff, new drive gear and new driven gear at minimum.
A few questions before I start ordering parts. Referencing this:
I cant find washer number 2. Did it explode or am I missing something? Same for washer number 1, should I be able to see this washer with what I have apart?
The bearings on the driven gear look fine, but I think I will just order new ones to be safe. I guess these need to be pressed on, can any place with a press can do this, or is this something I should leave to a dealer.
Finally, let me say that the failure is my fault and was avoidable. I had a slow leak in my front driver side tire that I let go too long and drove a fairly long distance with too great a tire pressure difference from front to rear.
spit_heron is offline   Reply With Quote
Old 04-23-2007, 07:32 PM   #2
St.race
Member#: 136092
If it's your first time do not do it yourself. Washers have a different thickness and you will only know which one you need during reassembly. And any place with a press can do the job right if they know what they are doing.
St.race is offline   Reply With Quote
Old 04-23-2007, 07:43 PM   #3
spit_heron
Member#: 23655
well, it looks somewhat straight forward per the FSM.
If someone knew the thickness of the ST guage it would help.
Old 04-23-2007, 10:43 PM   #4
REDI-wgn
Member#: 38068
03 WRX Wagon
ANy shop with a press, provided they have all size adapters, should be able to do it.
REDI-wgn is offline   Reply With Quote
Old 04-23-2007, 11:50 PM   #5
WRXINTX
Member#: 96712
I tried to find that out for over a month with my subaru dealership....
I think we should call Andrewtech/Gearboxtech.com and buy the tool from them or ask them what the thickness is....
WRXINTX is offline   Reply With Quote
Old 04-23-2007, 11:52 PM   #6
WRXINTX
Member#: 96712
I have a perfect set of 1.1 :1 transfer gears with good bearings still on them if you are interested in buying these used.....
I think new, everything was about $290 for bearings and all....
I would happily take $200 shipped and save you the hassle of having bearings pressed on and off.....
Let me know
RYNO
Old 04-23-2007, 11:57 PM   #7
WRXINTX
Member#: 96712
Btw, the cases are what are slightly different usually..... the actual gearsets are spot on perfect every time.....
so, if you have your washer/s and they are in good shape, you can stack and gauge them with the new gears in and make sure it is all good to go....
Also, did you find a good used center differential???
I have two units myself that I am looking to sell....
I was keeping them as spares....
I am asking $250 for the center differentials in good shape....
RYNO
Old 04-24-2007, 12:01 AM   #8
WRXINTX
Member#: 96712
I have broken three sets of stock output shafts..... and one center diff....
I had broken a set of output shafts and didn't realize it until I started getting the clunk clunk clunk.... thud!!!! tick tick tick... from the center diff....
The rear ouput shaft had broken clean in two pieces going into the driveshaft and was no longer pulling the rear wheels, thus causing the center diff to try and transfer all torque to the front wheels only....
My car makes about 600whp, so I have broke some parts to be sure....
Now, I have a set of experimental PPG unbreakable output shaft gears in and gonna hit them with all I got....
The set of gears you will get are in good shape and have never been raced on, so you will have no worries of breakage...
these shafts are so brittle, they just snap when they break....
"POP" and that's all she wrote...
Old 04-24-2007, 11:21 AM   #9
spit_heron
Member#: 23655
wrxintx, thank you for your help. I may take you up on your offer.
Can someone confirm if these two parts came of the center diff itself?
Old 05-08-2007, 09:26 PM   #10
Raiden
Member#: 50054
Did you remove the center diff section without removing the trans? If so how hard is this to do? I am having this very same problem and was told by the dealer that I need my carrier bearings replaced. If I can remove the center section myself and take it to them that would save me about $500 dollars in labor for the dealer to remove the trans.
Thanks in advance
Raiden is offline   Reply With Quote
Old 05-09-2007, 12:48 PM   #11
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Yes sir. Those two pieces were both part of the same piece. Originally it was a 3 layer snap ring type thing that holds the diff's end cap on.
Tim Sanderson is offline   Reply With Quote
Old 05-09-2007, 04:34 PM   #12
spit_heron
Member#: 23655
Thanks in advance
yeah, it was fairly straight forward. I followed this:
http://www.scoobymods.com/forums/showthread.php?t=6049
Except instead of removing the transfer case like he needed to do, you only need to remove the extension case to access the center diff.
Old 05-20-2007, 11:46 PM   #13
Raiden
Member#: 50054
Awesome
Thanks for the link.
Old 05-21-2007, 01:57 PM   #14
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
Dorothy from OZ, the XT
the washers are different thicknesses to setup the bearing preload on the tapered roller bearings of the transfercase. I'm working on the exact same thing right now putting mine back together with a new diff and new bearings. And as a slight thread jack, WRXINTX, how much are the PPG transfer gearsets? I snapped the rear output shaft clean in half an inch above the drive shaft splines and am just putting in a stock set that has been cryoed.
340Duster is offline   Reply With Quote
Old 07-13-2008, 02:45 AM   #15
richard donovan
Member#: 62738
2000 RS,5MT,Silver
DeltaCams,Borla,Prodrive
it doesn't matter what the thickness is of the standard , the only thin that matters in the difference between he standard and the measurement you take with the depth mic. so if its 1 inch and you measure 1.005 that means the shim has a .005 gap (or 1.005-1.000 = .005 thousandths of an inch) so no need to find out the thickness of the ST gauge, its not relevant
richard donovan is offline   Reply With Quote
Old 07-13-2008, 02:57 AM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I have wondered about this. I guess I don't need one yet.
Old 07-13-2008, 03:12 AM   #17
powertothewrx
Member#: 115211
04 WRX 19psi TDO4
WRB6SpeedBrembos SOLD
Thats whats left of the locking ring on the back of the center diff.
I no longer had one but many more smaller pieces.
It doesnt like to much torque aplied and thats what fails most of the time.
Some guys weld the back together to prevent that.
powertothewrx is offline   Reply With Quote
Old 11-30-2008, 06:04 PM   #18
andrewt461
Member#: 70647
2004 WRX
can't seem to break the seal on the extension myself.
Any hints here?
where is a good point to try and pry this thing off?
andrewt461 is offline   Reply With Quote
Old 11-30-2008, 07:31 PM   #19
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Any hints here?
There are two alignment dowels. Tap them down and then you can jar the piece loose with a dead blow hammer.
Old 12-01-2008, 12:15 AM   #20
andrewt461
Member#: 70647
2004 WRX
was doing that - didn't work for me too well...
ended up able to pry it off after much effort
thanks tho!
Old 09-30-2011, 01:14 PM   #21
shamrock 05
Member#: 120057
2018 WRX (base) 6spd
OK, for the plate that unbolts from the trans to pull the center diff out, how its covered in oil......thats transmission fluid correct? And couldnt you have just kept an eye on the trans fluid level then this may not have been so bad? Meaning it would have just been a center diff replacement rather than all those other parts?
Cause I am having the same prob, I got under the car the other day to look at the shifter bushings and noticed the oil residue on that plate and I checked the trans fluid and it was still covering the "F".
Ideas/opinions....and right now I dont have $1000 for parts and labor to fix the center diff, but it will be done within the next few weeks/month.
shamrock 05 is offline   Reply With Quote
Can I use 98 outback manual center diff in my 01 rs manual trans? scurabus Transmission (AT/MT) & Driveline 9 06-04-2010 07:32 AM
2004 STI dying center diff - need to replace, need opinions chron North West Impreza Club Forum -- NWIC 1 05-16-2010 09:53 AM
WTS(houston): Center Diff, BOV and intercooler. KIrbstermcgee TXIC Private Classifieds 0 10-16-2009 02:55 PM
Center Diff replacement and cost? JamesWilson2 Transmission (AT/MT) & Driveline 7 03-24-2009 11:16 AM
Sti ver 2 tranny and options to replace center diff (01RS) dcoty Transmission (AT/MT) & Driveline 17 10-27-2003 11:13 AM
