04-23-2007, 12:51 PM | #1 |
Member Sales Rating: (27)
Member#: 91776
NESIC
Vehicle:2008 Civic Hybrid Silver |
Whiteline Subframe Lock Kit
I purchased these bolts from Exeter Subaru (www.subaruwrxparts.com). They were priced at $30 and contained two bolts (17mm hex).
I read the directions from Whiteline's website and they were the same directions that came with the bolts. Install time: 60 minutes. It was a pain in the arse to install these bolts. Whiteline recommends leaving the car at normal ride height, re: do not jack the car. I highly recommend a breaker bar with a half inch swivel drive. It's tight working in that area and I probably could have made it easier on myself if I took off the axleback. I'm an idiot and didn't do that so the driver side was more of a pain than the passenger side. Response: I took the car out to a controlled (relatively) environment. It's effect is pretty noticable. It feels a lot tighter back there. Even just swerving at low speeds, you can feel the rear want to swing. Flex back there is reduced a ton. Without these bolts, the car seems to want to understeer when cornering. It took a little bit of effort to swing the rear around. Now, with these bolts, the feeling of the car as it is in a corner, is less understeer. I found it easier to induce oversteer and the car just felt more controlled and balanced. Sorry, no pics yet.
04-23-2007, 01:46 PM | #4 |
Member#: 91776
NESIC
The instructions said normal ride height, so I left it on the ground. Maybe you can put it on rhino ramps, I'm not 100***37; sure.
04-23-2007, 06:24 PM | #5 |
Member Sales Rating: (18)
Member#: 116052
Vehicle:2011 STI ( Sold ) WRB |
I did that on ramps. I tried. it was really almost impossible for me to install it w/o ramps. no problmes. this lock bolt big time tighten the rear so that you feel solid rear big time. one of my fav mods so far. oh do grp n engine and tranny mounts along with kartboy xmember bushing. i love this solid and connected feeling.
06-20-2007, 08:46 PM | #6 |
Member Sales Rating: (1)
Member#: 37748
SCIC
Vehicle:O=O Wgn Silver |
installed mine last friday, and went for a drive. seems like the rearend plants a little better, responsive, tracks well.
current suspension mods: Whiteline R&P Bushings Whiteline Rear Strut Bar Whiteline Read Diff. Outrigger Bushings TiC Fender Cowl Brace WRX Sedan Rear Sway Bar Helix Rear Pillowball Endlinks = sweeeet! |
06-21-2007, 12:45 AM | #8 | |
Member#: 116052
06-21-2007, 12:41 PM | #10 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member Sales Rating: (35)
Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
The height of your springs don't change the location of the rear crossmember- what would they have to do with installing these? I don't think you understand where they go if you think spring height factors into the installation. Look here:
http://www.northursalia.com/modifica.../subframe.html Brian |
06-21-2007, 01:53 PM | #11 |
Member Sales Rating: (10)
Member#: 115390
Vehicle:2002 WRX Platinum Silver Metalic |
Just wanted to caution everyone that is thinking of installing these that if they are difficult to screw on because of rust then you need to clean and chase the threads first.
I tried installing these on my 2002 WRX and they were very tight when I started treading it. I backed it off and started again to make sure that it wasn't cross threaded. Did this a couple of times each time going in a little further. I ran out of patience, so I used a breaker bar. I was three quarters through when I heard something snap. The captive nut that this threads to must have broken off. Now I can't tighten it or take it off. It just spins, and since the nut is inside a frame rail you can't get to it!. For the other side I learned my lesson and chased the threads first and there was no problem. So with only one side really installed I don't think I could give an accurate review, but for what it's worth I really couldn't detect much of a difference. Last edited by Flaroc01; 06-21-2007 at 01:59 PM. |
06-21-2007, 05:31 PM | #12 | |
Member Sales Rating: (145)
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
What I am trying to say is whether there is enough space to work on your car with lowered springs...
06-27-2007, 03:51 AM | #15 |
Member Sales Rating: (15)
Member#: 150248
SCIC
Vehicle:08 FXT Sports WRB |
just bought these from TiC and the Whiteline instrux say:
"should not be used for extended periods as it may lead to premature chassis wear." they suggest that it should be removed between races. anyone notice any issues after using these over time? |
06-27-2007, 09:20 AM | #16 |
Member#: 42329
Vehicle:2002 WRX sedan WRB |
Mine have been in for 70,000 miles wih no problem.
I had the same concern when I got them, but that disclaimer is just for "legal" purposes. |
08-11-2007, 12:31 PM | #19 |
Member Sales Rating: (69)
Member#: 142029
Vehicle:2013 Forester 2008 350z, 1991 Miata BRG |
just installed these today (on rhino ramps). Install was a breeze and what a great cheap mod. My wagon's arse is finally tighter than the front. The car really rotates better. There was very little additional NVH from these.
The more suspension mods I do, the more I realize that my tires are absolute garbage. |
02-26-2009, 05:01 PM | #21 |
Member#: 164241
Vehicle:2007 wrx wagon pearl white |
i just got the sexy rear end kit from TIC it came with katboy allen head bolts instead of whiteline. the katboy bolts are just that bolts with a sleeve around it ti fit the wider hole. now they seem longer then the whiteline bolts and i totally bottomed them out but there is still a tiny amount of room under the collar more on the outside part then the inside. itseems were the bolt goes in is not totally flush either that or i am imagining it. my wrx is an 07 wagon would this have any difference?
02-26-2009, 07:30 PM | #22 |
Member#: 164241
itnstalled the Kartboy ones today tightened up the rear of my 07 wagon. Did it with the backend up on a set of rhino ramps and had no problems. Call TIC about the issue I had and they said it is normal they will not sit flush. Now what are the long term effects if any? I see that the witeline ones have a disclaimer. Is this just to CYA or is there a real need to worry about leaving them in?
02-26-2009, 11:28 PM | #23 |
Vendor Sales Rating: (617)
Member#: 79304
South East
Vehicle:CALL 941-257-9618 www.ImportImageRacing.com |
exactly...great cheap mod
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Open Daily To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. #1-941-257-9618 AIM= importimagerace To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Best Deals on To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. !!! Let us Beat your Lowest Price Quote!!!!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. <> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
02-27-2009, 02:34 PM | #24 |
Member#: 135480
Vehicle:2007 Impreza WRX Satin White |
I left mine in from about a year ago and inspect the area every time my car's on the lift. Haven't seen anything out of the ordinary yet. *shrug*
As far as performance goes, they seem to produce a more solid feel to the rear end. On loose material (snow/dirt/gravel/etc) it's easier to bring the rear end around with the throttle. The bolts don't seem to change anything off throttle. I say buy a set and throw them in, especially if you have a newer year car, since your subframe isn't as likely to be as tweaked as an early year. |
Whiteline Subframe lock kit | Penphoe | VIC Private Classifieds | 2 | 05-25-2008 03:23 PM |
FS: Whiteline Subframe Lock Kit NIB | Scoobykid1984 | Suspension/Brakes/Handling | 9 | 06-03-2007 03:46 AM |
FS: Whiteline Subframe lock kit | 05_WRX | Suspension/Brakes/Handling | 3 | 05-08-2007 08:52 PM |
Whiteline subframe lock kit, or diff bushings? | STIRS | Brakes, Steering & Suspension | 29 | 05-15-2004 11:19 PM |
Anyone Install the Whiteline Subframe Lock Kit? | Ryan24 | Brakes, Steering & Suspension | 11 | 06-26-2002 12:56 AM |
