04-24-2007, 02:38 AM | #1 |
Member#: 130063
Vehicle:2003 WRX Silb |
Lean Issues
I'm running a stage 2 setup. The target AFRS all look good 10.5 on the top end. My car thinks its seeing 11.1, On the dyno it started knocking and showed a AFR of 13.5 at which point we let out of the dyno.
the maf read 180CFM in the 5k range, I cleaned the MAf its reading 195+ now but I've not made it back to the dyno yet to retest. Any other suggestions for things to look for?
04-24-2007, 08:38 AM | #2 |
Member#: 44422
SWIC
Vehicle:2009 G8 GT Cammed, sprayed, stalled |
More info on your car and mods!
04-24-2007, 09:03 PM | #3 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
04-24-2007, 10:58 PM | #4 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
Don't know about your case but I recently got a bad tank of gas and my a/f ratio which usually shows 11:1 on my WBO2 was reading 11.9:1. At 1/4 tank I refilled at my usual station and it went back down to 11.2:1, since it's still a mix of the junk. Either that or you have a post maf pre turbo intake leak, causing unmetered air to enter the engine.
axel issue maybe tranny issue? | 04stinugget | Transmission (AT/MT) & Driveline | 2 | 06-03-2010 11:14 PM |
axel issue maybe tranny issue? | 04stinugget | Brakes, Steering & Suspension | 0 | 06-03-2010 08:44 PM |
'02 wrx lean issues, can't figure it out | NJsilvernotch | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 20 | 05-26-2008 09:06 PM |
Is my STi running too lean or other other underlying issues? | j2los | Newbies & FAQs | 17 | 10-11-2006 11:21 AM |
having vacuum/lean run issue...need advice/input | Homemade WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 06-08-2004 07:21 PM |
