04-24-2007, 02:17 PM | #1 |
Member#: 13626
Vehicle:02 996 |
Enginuity: IAM jumps immediately from .8 to 1.0
'06 STI, using Enginuity 4.1 for maps and logging, stock exhaust, stage 1 tune.
I set the IAM at .8, the logs show 1.0 within 20 seconds of starting the car. I figure this could be caused by a few things: 1. the location for setting IAM is wrong in the map editor 2. the location for logging IAM is wrong in Enginuity 3. the ECU legitimately raises IAM that quickly 4. I am an idiot
04-24-2007, 03:12 PM | #2 |
Member#: 103136
what cal id are you running (example A2ZJE11J)? Did change any table values in the 'Knock' category?
04-24-2007, 03:54 PM | #3 |
Member#: 115771
NWIC
Vehicle:2006 WRX WAGON OS Stage 1 |
I believe it adjusts that quick on 06+. Mine will go to one in a few blocks and only a slight amount of boost
04-24-2007, 04:39 PM | #4 |
Member#: 13626
Vehicle:02 996 |
04-24-2007, 04:41 PM | #5 |
Member#: 13626
Vehicle:02 996 |
For me, this happens while idling with no throttle blips. I don't see it move to 1, but as soon as the logger wakes up, it's already logging as 1. Maybe I should set it to 0.05 ?
04-24-2007, 04:46 PM | #6 |
Member#: 34860
Vehicle:2005 Forester CGM |
That should not happen in my opinion. When you're idle it's probaby looking at 2 or 3 cells on any map.
04-24-2007, 05:38 PM | #7 |
Member#: 103136
I checked those definitions and they are correct. Do you see the .8 IAM at all or are you saying that it always shows 1.0? Remember, that your initial IAM will only take effect after a reset. Either a hard reset by disconnecting the battery or after a reflash. Other than that, it isn't used and IAM is dynamic.
04-24-2007, 07:14 PM | #8 |
Member#: 98645
NESIC
Vehicle:2002 WRX Wagon PSM |
seems normal to me. but log the IAM during a power pull and see what happens then.
04-24-2007, 09:02 PM | #9 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
factory iam is default value of 0.5.
so if it is set at 0.8, reset to 0.5. |
04-24-2007, 09:52 PM | #10 | |
Member#: 13626
Vehicle:02 996 |
the logger only displays 1.0 Maybe it's running up that quickly? How can we be sure? This is immediately following a reflash, but not a reset of the ECU, I guess I could try that. thanks for the ideas guys |
04-24-2007, 09:53 PM | #11 |
Member#: 13626
Vehicle:02 996 |
04-24-2007, 11:37 PM | #12 |
Member#: 103136
You can log IAM without starting the engine. Just turn the ignition to on after the reset and see what IAM is at.
04-25-2007, 01:46 AM | #13 |
Member#: 78967
VIC
Vehicle:2011 335i Black |
04-25-2007, 10:33 AM | #14 | |
Member#: 13626
Vehicle:02 996 |
veightkiller - what do you set your IAM to? Could this be a bug or can someone confirm that this works on an '06 sti? |
04-25-2007, 11:09 AM | #15 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
On some DBW cars, an ecuFlash reflash does not reset the ECU. So, if your IAM was already at 1.0, then it will still be at 1.0 after reflashing.
04-25-2007, 11:19 AM | #16 | |
Member#: 13626
Vehicle:02 996 |
Cool that may be the answer. I'll try it today. Do other important settings require a reset too? thanks x99 |
04-25-2007, 11:21 AM | #17 |
Member#: 103136
04-25-2007, 12:05 PM | #18 |
Member#: 98645
NESIC
the IAM being at 1.0 is a good thing...
04-25-2007, 12:26 PM | #19 |
Member#: 72829
W. Canada
Vehicle:2006 WRX 2015 WRX |
I have '06WRX with DBW and ecuflash does reset the ECU. I use "reset IAM" of 0.6 and after a reflash, it reads 0.6 until I drive it for a bit.
04-25-2007, 12:46 PM | #20 |
Member#: 27108
04-25-2007, 12:58 PM | #21 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
I've experienced the same. Plus my car drives like crap for the first few minutes until the ECU smartens up, it definitely is a reset.
04-25-2007, 03:37 PM | #22 |
Member#: 132705
Vehicle:2006 WRX Wagon Crystal Grey Metallic |
Same here. I knocked my '06 WRX down to 0.8 and reflashed w/ Enginuity. A little -KC and crappy running, then voila a smarter ECU than I. It was back to 1.0, smooth running with a little quicker spool-up and better pull.
04-25-2007, 06:33 PM | #23 | |
Member#: 78967
VIC
04-27-2007, 01:14 PM | #24 |
Member#: 127556
Vehicle:2006 WRX RomRaided. |
The ECU will reset the IAM after a flash. My car goes from .5 to 1.0 IAM after about 100 yards and the slightest amount of boost. This is perfectly normal for the 32bit ECU's, provided you have good timing maps.
05-28-2007, 09:46 PM | #25 |
Member#: 13626
Vehicle:02 996 |
I finally reset the battery and sure enough the IAM starts at .8
After hitting about 6 pounds of boost - IAM moves instantly to 1.0 Apparently some 2006 cars (STIs only?) need to have a full battery reset in order to "forget" certain values. |
swap 1.8 to 2.0 | newbreed | Subaru Conversions | 1 | 11-16-2007 03:57 PM |
Unable to transfer from PC to AP1.0 !!!HELP!!! | EROC263 | AccessPort | 3 | 01-19-2007 10:22 AM |
1.8 to 2.0 wiring swap | nuclearfiziks | Subaru Conversions | 11 | 12-22-2006 03:56 PM |
national alcohol limit changing to 1.0 ***? | Protege Menace | Off-Topic | 32 | 07-04-2005 11:00 PM |
1/8 to 1/4 mph gain??? | geronimo66 | Proven Power Bragging | 18 | 09-22-2003 06:18 AM |
