04-29-2007, 03:13 PM | #1 |
Member#: 143641
AKIC
Vehicle:1999 mitsubishi gsx black |
my car is being funny...any clues to why?
i hate thinkin that there is sumn up with my car..this time it is that the gas pedal feels choppy or sticky about an inch in...every gear...more just depends on how quickly or slowly i press on it...makes a funny noise too...anybody got any clues as to why? choppy pressing on...sticky letting off...that's the best discription i got for it anyway
04-29-2007, 03:35 PM | #2 |
Member#: 68709
AKIC
Vehicle:2012 WRX red |
Sounds like your throttle linkage is malfunctioning. Often caused by: corrosion at the pivot points, or connecting bolts getting loose, so the linkage doesn't work as designed, or throttle cables that get sticky from corrosion or dirt. I would try to examine whatever part of the throttle linkage I could under the hood.
Good luck. |
04-29-2007, 04:13 PM | #3 |
Member#: 143641
AKIC
i was thinkin sumn like that..but have no idea where to look lol
04-30-2007, 04:10 PM | #4 |
Member#: 135785
AKIC
Vehicle:2006 Impreza WRX LTD Cloaking Device Gray |
Find your air filter, follow that up the the manifold, on the manifold will be a throttle body where you see cables and springs in 1 spot. that is where you should look and lube if needed. Check obstructions around your pedal as well.
04-30-2007, 04:35 PM | #5 |
Member#: 143641
AKIC
checked for obstructions...guess i'll pop my hood later and check round the throttle body...lube?..with what? lmao..wd40? sheesh i dunno...eh if i cant figure it out i might need to call in some reinforcements lol....
thanks guys |
04-30-2007, 05:25 PM | #6 |
Member#: 135785
AKIC
Yeah, WD-40 will work. If you like, I can stop by to peek at it on my way to Jerry's tonight. Let me know.
04-30-2007, 05:37 PM | #7 |
Member#: 114704
Vehicle:1990 Mazda Miata BRIGHT ASS RED |
Don't use WD-40 it will just wear off. Use some White Lithium or silicone grease. Both are weather-proof and will help.
04-30-2007, 05:41 PM | #8 |
Member#: 135785
AKIC
04-30-2007, 10:10 PM | #9 |
Member#: 143641
AKIC
lol see now that's why i ask first..anywho..i think i found out what the REAL problem was..and lets hope thats it...one of my nuts keeping the rods holding the battery in place together...was missing..so the whole set up (including battery) appeared to have been just knocking about in there..haha should've popped my hood sooner...since i put it back in place i haven't felt the mysterious choppiness...going to buy nut...and hope i never feel that again...(nothing appeared to be wrong with the throttle cable etc etc) i seem to lose alot of bolts nuts and screws...this wouldn't be the first one to disappear
my car is being worked ON!!!!! | Keith | Off-Topic | 14 | 09-07-2004 08:49 AM |
Help! my car is acting funny | 03mbpREX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-23-2004 02:18 AM |
My girlfriend dumped me. My WRX is being funny. | FraudulentNeon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 04-16-2004 12:24 PM |
My Car Is Being Stoopid! | huckedup16 | Legacy Forum | 4 | 11-03-2002 07:02 PM |
My car is being weird. | Dolphin Overton | Transmission (AT/MT) & Driveline | 13 | 03-06-2002 02:22 PM |
