Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 04-29-2007, 11:32 PM   #1
Brydon
Member#: 107569
1998 Forester S
SRP
Default Another Turbo Legacy back on the road!
i guess this goes in this Forum!?! Anyway I have been working on this in my spare time for a buddy of mine. It's a 91 turbo Legacy.
ej22t block rebuilt with new bearings/rings/seals/etc
04 WRX heads and manifold
TWE valve springs. (for cams later)
Full GPMoto twin-scroll kit with 3" downpipe
Tial 38mm Wastegate
Garrett gt32 turbo
Custom FMIC by Rallitek.com
Titanium catback (Amazing how lite this thing is.)
KYB AGX struts for a RS
H&R Springs for a RS. Will go WRX to raise the rear a little.
01 RS seats
AEM EMS with UEGO for a WRX custom wired by me.
Blitz EBC
Greddy Turbo timer
06 WRX TR front brakes Brand new from Subaru
Braided brake lines from Rallitek.com
STI master cylinder (to be installed)
Some other stuff I'm sure i forgot.
Let me know what you think!
Still needs a good tune in it but it drives beautifully. It also has WRX coil packs and WRX modded injectors so running this thing at 30-35psi again shouldn't be a problem. As a little history this was my last setup that I donated back to my friend. He had an ej20g swap before this and donated the ej22t block to me. I drove 5000miles on it before going ej257. Now it is back in it's home to make this Legacy go fast.
Brydon is offline   Reply With Quote
Old 04-29-2007, 11:38 PM   #2
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
siiiiickk, i love that car!
just curious brydon, how much hp can the legacy pink injectors support? you seem to know your ej22t stuff
oh and..how much AWHP is 30-35 psi?? thats ALOT of boost
mxpunk is offline   Reply With Quote
Old 04-30-2007, 12:28 AM   #3
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Looks like you forgot to mention the Koyo aluminum rad.
I seem to remember when this was posted over on LegacyCentral. I love how you have the I/C pipes run.
Always great seeing another slick '91 running around. I am hoping to run some similar stuff (twin-scroll, early WRX heads or SOHC RS heads, FMIC, Blah, Blah.....).
IronMonkeyL255 is offline   Reply With Quote
Old 04-30-2007, 12:55 AM   #4
Brydon
Member#: 107569
1998 Forester S
SRP
The legacy pink injectors I assume would be high 200s maxed out. But this car has almost 800cc injectors. The ej22t was the first subaru motor I rebuilt. Then I spent way to much money on my 93 Imreza L. I imagine we should be able to push high 300 Whp on this car. The only problem is that it has super low compression, 7.7:1. You can run tons of boost but it limits the HP per pound. hopefully we will be on the dyno to get some real number results and I will post them up. This was old setup in my L and I had no problem keeping up with 400Whp STIs.
Old 04-30-2007, 12:58 AM   #5
Brydon
Member#: 107569
1998 Forester S
SRP
Yep, that also. Oh, and Fog lights integrated into the Blinkers. Kelly who use to work for Rallitek made those for his Legacy Turbo and they ended up on this car. They are pretty neat.
Old 04-30-2007, 01:21 AM   #6
Brando
Member#: 130736
1995 brighton
teal
That car is f-ing awesome............ Because it mine!. Thanks Brydon for your masterful skill of wiring cleverness! You rock!
Brando is offline   Reply With Quote
Old 04-30-2007, 01:36 AM   #7
kbahus
Member#: 70256
2000 STI V2 Swapped
very cool
kbahus is offline   Reply With Quote
Old 04-30-2007, 01:36 AM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Wow, a 91. Any plans to update it to the 92-94 style?
subiekid is offline   Reply With Quote
Old 04-30-2007, 02:33 AM   #9
azn2nr
Member#: 35276
drool
i want to buy it.
azn2nr is offline   Reply With Quote
Old 04-30-2007, 09:03 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
nice work did you switch out the 2.2 crank gear to make with the aem/wrx heads?
Old 04-30-2007, 09:11 AM   #11
Brydon
Member#: 107569
1998 Forester S
SRP
Yep put in a WRX gear I had laying around. The original setup used a LINK with a RS cam gear that was machined out to bolt onto the WRX camshaft. Pretty slick I don't know why more people haven't done that. Or maybe I just don't hear about it. For this setup I took a WRX jumper harness and cut off all of the plugs. Then I went through wire by wire linking every wire up to the Legacy harness. Then I made a custom motor harness with extra harness bits I had laying around merging together legacy stuff and WRX stuff. We also changed over to The WRX crossover pipe and temp sender for the guage and the AEM. The only difference is this car doesn't have the WRX fuel pump controller. I just setup an output to run the fuel pump like a normal car and wired in a 3 BAR map sensor.
Old 04-30-2007, 09:25 AM   #12
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Why would he do that? The '91 has more aggressive styling, IMHO.
Old 04-30-2007, 12:26 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
your garage must look like mine ...
its alot easier to do these sorts of things when you have lots of misc bits sitting around
Old 05-01-2007, 01:24 AM   #14
Brydon
Member#: 107569
1998 Forester S
SRP
I seem to collect things... I have many boxes labeled Mitsu, Nissan, Toyota, Subaru, Wiring harness and a huge bolt bin. I also have a really nice work bench that makes things easier. If I want to make the drive to my fathers house (an hour or more). He has a 80ft x 100ft shop with a lift, paintbooth, woodshop, nice welder, etc. It's nice to live out in the sticks were you have lots of room. He also is nice enough to store a few cars for me. my 66 Lemans and a rx7 track car I have been working on for my girlfriend.
Old 05-01-2007, 03:31 AM   #15
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Why? Facelifts are ugly compared to pre facelifts.
btw, what 'box is in it?
i_c_the_light is offline   Reply With Quote
Old 05-01-2007, 03:35 AM   #16
Brydon
Member#: 107569
1998 Forester S
SRP
not sure what you are refering to, "box"?
Old 05-03-2007, 01:54 PM   #17
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I don't think its a good idea to have ur coolant over flow shoot right into ur open timing belt cover
scobaru is offline   Reply With Quote
Old 05-03-2007, 02:02 PM   #18
subiekid
Member#: 25516
92 to 94>91
Old 05-03-2007, 08:50 PM   #19
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
92 to 94>91
How so?
'91 got rear LSD
'91 got factory oil cooler
How is that worse than '92-'94?
Old 05-04-2007, 02:02 AM   #20
Brydon
Member#: 107569
1998 Forester S
SRP
1) it wouldn't matter. 2) I doubt the Koyo will ever overheat. 3) The cover is already back on. The pic was taken after initial setup.
I was using a feeler gauge to see the best clearance between the cam sensor and timing marks that resulted in the best signal to the AEM.
Old 05-29-2007, 09:51 PM   #21
ej20Legacy
Member#: 125135
Default turbo legacy
nice legacy! I also have a 93turbo with a 5 spd, lost the EJ22t to warped cylinders and now run a JDM ej20 with a link plus. Now I need a tranny solution! any ideas? STI 6 spd? is the stock 5 spd worth rebuilding if i plan on running over 300HP?
ej20Legacy is offline   Reply With Quote
Old 05-31-2007, 09:45 PM   #22
biggreen96
Member#: 12535
Low 06 5MT OBXT
92 EG33 Legacy Rally Car
Oh boy nice work on the leggy. I recognize those intercooler pipes from legacycentral, awesome way to route them.
biggreen96 is offline   Reply With Quote
Old 06-01-2007, 12:21 AM   #23
Brydon
Member#: 107569
1998 Forester S
SRP
Thanks. The car when through WA emissions yesterday and passed with flying colors. Shortly after the clutch master cylinder went out. ... I swear this car is my nemesis. Soon everything on the car will be new do to failure.
By the way the car has now hit 30psi at 18degrees of timing on pump gas. Time to put it on the dyno.
As for a tranny I say PPG gears or 6 speed. I myself will be doing PPG gears soon on my impreza L.
Old 06-04-2007, 04:33 AM   #24
V8eta
Member#: 116334
1996 WRX Sti type RA
I blew 2nd in my JDM 4.11 box in gear with around 300-320hp, currently have 2 5 spd's in case 1 breaks but ive been looking at the 6spd conversion as the best value for money upgrade.
Very nice car Brydon, i may be slightly bias here being a fellow legacy fan
v
V8eta is offline   Reply With Quote
Old 06-06-2007, 08:51 PM   #25
UASheva
Member#: 144792
1992 Subaru Legacy L
Awesome car ! how much did the whole build cost you ?
UASheva is offline   Reply With Quote
need to get the beater back on the road lostintheforest Off-Topic 3 08-21-2006 03:07 AM
MY 1991 legacy is back on the road! shipjumper Legacy Forum 8 04-14-2003 04:26 PM
Stripped the tranny on Tuesday...car back on the road Thursday...Thanks Subetek!! wrxnate Rocky Mountains Impreza Club Forum -- RMIC 2 01-18-2003 04:12 AM
Back on the road again kevinsUBARU Tri-State Area Forum 0 08-06-2001 08:34 PM
Back on the road... WRC666 General Forum Archive 5 01-30-2001 11:47 AM
