05-02-2007, 07:42 PM | #1 |
Member#: 123057
NESIC
Vehicle:2016 WRX silver |
Ecutek with manuel boost controler?
I was just wondering if this would be a good idea or not? Useing a manuel boost controler along with my Ecutek to hit boost sooner
I'm having a problem with my VF34 where it doesn't really hit full boost until 5000 rpm's and pulls hard to redline. I was going to use the Prodrive boost solienoid but my tuner ( XXTuning ) is having problems with them in the cold causeing the car to surge. So any help would be great, Thanks, Ian
05-02-2007, 10:32 PM | #2 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
As long as you are tuned for it you will have no problems. Have the tuner make sure there are no closed loop delays and PTFB is not a problem either (though with a VF34 you are unlikely to have PTFB at low rpms anyway).
05-02-2007, 11:02 PM | #3 |
Member#: 123057
NESIC
Hey thanks, but whats a PTFB? And do you think that would help me boost sooner?
05-03-2007, 09:45 AM | #4 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
PTFB, partial throttle full boost.
with your vf34, you should see full boost way before 5k rpms, more like mid 3k rpm. my vf30 spools to 1 bar (14.7 psi) by 3600~3800 depending on weather ecutek would be a better choise to handle your boost than a mbc. |
05-03-2007, 05:16 PM | #5 |
Member#: 144081
AKIC
Vehicle:2003 WRX Blue |
Ecutec can achieve this without the use of a boost controller.
After your mixtures have been set to an acceptable (but still very conservative levels) your tuner can now go and maintain the peak boost value all the way to the redline. Plenty of enthusiasts feel the need to spend hundreds of dollars on an electronic or manual boost control system, but could a similar result be achieved with a few keystrokes? There are two changes necessary to raise the boost level. First, the tuner must raise the peak solenoid duty cycle map, and second, change the boost target map. Last edited by Foska Oats; 05-16-2007 at 08:35 PM. |
05-09-2007, 03:33 PM | #6 |
RIP 3/18/1965 to 1/10/2008
Scooby Specialist Member#: 91500
Vehicle:hmmm sr-30+640cc=? I has teh Endless BBK. |
subscribing
05-09-2007, 09:28 PM | #7 |
Member#: 123057
NESIC
What if I went with the Perrin boost solienoid thing to get better control of my boost? We were going to put in the Prodrive one but my tuner said they get surging in cold weather on WRX's but it's great for the STI's.
05-09-2007, 11:45 PM | #8 |
Member#: 144081
AKIC
^^ Why take the chance
06-21-2007, 03:16 AM | #9 |
Member#: 144965
NESIC
Vehicle:04 WRX STi wrb |
Hmmm...Fishing for information outside of Wrxtuners,eh? hahahahaha!!!
06-21-2007, 05:50 PM | #10 |
Member#: 123057
NESIC
06-21-2007, 06:20 PM | #11 | |
NWIC
But, a MBC will give the most solid boost control and quickest spool up possible. The ECU's boost control is ok, but for the best performance something else should be used. Even interrupt (GM, Perrin, Prodrive) solenoids on the stock ECU don't come close to the response of a MBC. |
06-21-2007, 06:28 PM | #12 |
Member#: 123057
NESIC
I guess I forgot to reply to this thread after geting my car fixed
Well My tuner ( Chris at XXTuning ) put in the Prodrive boost soleniod + a retune and OMG! what a difference! The car is doing what it is supossed to be doing now. I hit full boost at 3600 rpm's instead of 5000 and it stays that way all the way to redline! My car feels soooo much better! My stock boost soenoid was deffinitly my problem. Thanks for the help, Ian |
06-21-2007, 08:38 PM | #13 |
Member#: 135156
Vehicle:05 sti gone, now 06 mazda 6 w/extra ghey |
maybe it was your tune?
Need Manuel Boost Controller Or Boost Cylinoiod | ANT03IMPREZA | Private 'Wanted' Classifieds | 6 | 03-27-2008 01:01 PM |
FS CT Hallman Manuel Boost Controller BLACK | neb11ihtut | Engine/Power/Exhaust | 9 | 04-03-2007 08:01 PM |
FS: BRAND NEW Turbo XS Manuel Boost Controller | subbiedo04 | Engine/Power/Exhaust | 8 | 03-31-2007 07:19 PM |
Max boost with OEM boost controller and Ecutek? | Silver '02 REX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 08-26-2005 01:14 AM |
question on manuel boost controller | adrian559 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 11-04-2004 09:27 PM |
