Welcome to the North American Subaru Impreza Owners Club Wednesday August 16, 2017
Old 05-02-2007, 11:49 PM   #1
saddlewrxcreek
Member#: 147727
Question JDM pink Springs VS. Non JDM pink Springs
I just bought a set of the non- jdm p. springs, and was curious of the differences of the two springs. Im shure this topic is all all over this forum, but i have searched, and hope i made the right decsion on the springs, Im just lookin for a small even drop, from front to rear, with a little stiffer of a spring. thanks
saddlewrxcreek is offline   Reply With Quote
Old 05-02-2007, 11:55 PM   #2
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
JDM Pink springs are intended for the STi. They will be a bit on the stiff side for a WRX.
USDM Pink springs are intended for the WRX. They will be wasted on an STi since they are pretty close to the stock STi springs.
Both are pretty good when used on the intended car.
- Andrew
RaceComp Engineering is offline   Reply With Quote
Old 05-03-2007, 12:58 PM   #3
saddlewrxcreek
Member#: 147727
Any of you guys have any comments on the usdm pinks? Level of drop, ride qualtiy, difference form stock?
Old 05-03-2007, 08:13 PM   #4
BIGSKYWRX
Member#: 7958
09 GH B+
the drop (WRX pinks) is between 10-15mm, the spring rates are quite a bit firmer than stock at 223/195- oe WRX (depending on model/tranny) is 168/117 (sedan/MT)- ballpark 35% increase in front rates, 65% increase in rear rates
the drop of the STi pinks on a WRX is ~ 30-35mm, rates firmer yet @ 252/217
the WRX ones will work OK w/ the oe struts, aftermarket struts will work much better, I'd say no to the STi ones w/ oe WRX struts
2007 Struts and springs vs 2005 Struts and springs Ray_STi Brakes, Steering & Suspension 2 04-10-2007 11:11 AM
JDM sti pink springs vs. 04+ pinks for 02 wrx compressor_guy Brakes, Steering & Suspension 22 10-10-2006 03:15 PM
94 L Springs vs. 00 2.5RS Springs 83Rabbit Brakes, Steering & Suspension 5 06-12-2006 09:44 AM
The STI JDM Pink springs vs Prodrive 04-05 springs , owners give your feedback. RaceComp Engineering Brakes, Steering & Suspension 104 03-21-2006 05:43 PM
RS-R Down SUS Springs vs. Tein S.Tech Springs Diversion Brakes, Steering & Suspension 5 07-28-2003 02:06 PM
