05-13-2007, 10:24 AM | #1 |
Member#: 36576
Vehicle:2k2 WRB wrx WAGON 16G'd & FMIC'd |
PE650 Latency values?
I have been searching far and wide and can not find what latency values I should input (using enginiuity) for the PE650 injectors. I did some calculations (based on the 1.5ms listed by PE), but I am not sure what voltage the 1.5ms is for.
I read through and found that for the UTEC the latency values are based on either 12.8V or 13.8V (don't remember exactly anymore), so I would think that 1.5ms would be for a similar voltage. Anyone have any input on this?
05-13-2007, 10:26 AM | #2 |
Member#: 67483
Vehicle:2005 WRX STi |
I don't have the values for you but if you have a wideband a little time to log things it shouldn't be that hard to figure out.
05-13-2007, 10:29 AM | #3 |
Member#: 36576
Thanks I do have a wideband. I have the idle running perfect and am getting ready to tune the fuel map. Just wanted to make sure I was starting with decent values so it doesn't come back to bite me in the butt.
I am using eginiuty to tune the injector scale and latency, and using the UTEC for everything else. |
05-13-2007, 02:05 PM | #4 |
Member#: 22825
NWIC
05-13-2007, 02:30 PM | #5 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
The cobb tuning worksheet says to use these settings for the PE 650's:
scaler 4160 latency 3.69, 2.39, 1.88, 1.58, 0.68 hope this helps. |
05-13-2007, 03:59 PM | #6 | |
Member#: 36576
The only thing I don't understand with the above is the "scalar" value. I thought Cobb was basically the same thing as openecu? I ended up using 660 as the injector flow scaling (enginuity). I have a pretty good idle but STFT is still on the negative side, so I still need to pull a little more fuel. Well, I am giving up for today, to nice out to be stuck in the. Thanks big time for the values, I am gonna input those right now. |
05-13-2007, 11:28 PM | #7 |
Member#: 14911
Vehicle:Not A Wagon! 2011 WRX - 285s on 18x9.5 |
The scaler is easy to figure out once the latency is set. Just log and add AF Learning 1 to AF Correction 1 then adjust the scaler by that amount. Log again to verify and make corrections as needed. I would set the scaler so that the AFR is accurate over the widest range and then tune out the rest as needed using the MAF table.
05-14-2007, 11:03 AM | #8 |
Member#: 36576
Thanks for the help guys. I used the latency values posted above, and the car idles great. I still need to tweak the scalar because at idle the car is pulling about 10% of the fuel. Long term learning is pulling about 15%.
I am only using enginuity to control idling and will tune the fuel maps in the utec to control everything else (basically leaving the 0% column as all zero's). |
05-24-2007, 11:31 AM | #9 | |
Member#: 36576
6.5V 9.0V 11.5V 14.0V 16.5V 3.61 2.31 1.80 1.50 1.20 jays05 - where did you find those values? I looked through all of the latencies (for all different injectors and years) and can't find those anywhere on the sheet. |
05-24-2007, 02:50 PM | #10 | |
Member#: 78165
South East
08-27-2007, 03:49 AM | #11 |
Member#: 82487
Vehicle:2007 WRX STI Spec C |
Sorry if this sounds totally noobish....Can i use this values for Ecutek?
08-27-2007, 11:03 PM | #12 |
Member#: 89589
how about utec values?
Injector Latency Value Database | hawker800mech | AccessPort | 18 | 08-18-2014 10:44 PM |
Perrin 816cc latency values | WRX2ning | Engine Management & Tuning | 3 | 05-17-2007 04:03 AM |
Injector Scaling and Latency Values..... | Chp_Stix | Engine Management & Tuning | 9 | 05-10-2007 09:11 PM |
deatschwerks 650cc latency values? | 69_Lex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 07-30-2006 08:47 PM |
Need latency values please | kingtut12 | Engine Management & Tuning | 2 | 05-24-2006 11:56 AM |
