05-14-2007, 05:50 PM | #1 |
Member#: 128115
South East
Vehicle:2008 STi Hatch OBP enginuity is cool |
Lean AFR, 13 IAM
First of all, is 10.51:1 considered lean? At mid-high load and RPM it is about 1.0 leaner than the stock map. (this is in the low detonation fuel map)
When does the high detonation fuel map kick in? Does the IAM have to sense extreme knock before it comes on? I know this all ties in with the OL/CL concept which I don't fully understand. I'm all confused
05-14-2007, 05:56 PM | #2 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
10.5:1 is considered very very rich. Lower numbers are richer, higher is leaner. Are you saying that the AFRs are higher or lower than what the map says?
Please e-mail me your map and some logs and I'll take a closer look. I can also help you with the OL/CL stuff. [email protected] |
05-14-2007, 10:30 PM | #3 |
Member#: 147328
South East
Vehicle:2007 WRX FlimFlamRacing |
Would you consider an a/f r of 11.02 being to rich for a 3rd gear WOT pull?
I'm running stage 1 on my 07 WRX TR with 91 octane. |
05-15-2007, 12:24 AM | #4 |
NWIC
^^^Where are you getting the AFR from? That sounds like the reading from the stock O2 sensor which isn't something you can trust for AFR readings outside of stoic.
My AFR target is usually around 11.2, for 91 octane it would probably be 11 though. It isn't too rich for pump gas. You have to be careful with how rich you go with the stock catalytic converters in place. The Stock ECU does run pretty rich though so I don't know what the limit is, but too rich will burn up your cats. |
05-15-2007, 01:08 AM | #5 |
Member#: 10108
NWIC
Vehicle:1874 Bicycle |
05-15-2007, 08:01 AM | #6 | |
Member#: 147328
South East
05-15-2007, 08:07 AM | #7 | |
Member#: 147328
South East
For the time being, I suppose I could find an AWD dyno in the KC area with a good sniffer. |
05-15-2007, 11:02 AM | #8 |
NWIC
^^^If you still have Cats in place, which you should at Stage 1, then the sniffer will be useless in getting a valid reading.
05-15-2007, 11:21 AM | #9 |
Member#: 147328
South East
05-15-2007, 11:24 AM | #10 |
NWIC
^^^Yup. But it will probably need to be custom installed in the stock downpipe. The WB02 sensor needs to be after the turbo and before the catalytic converters to get a good reading. IMO easier to just go stage 2 and replace the rear O2 with a wideband unless you want to stay Stage 1
05-15-2007, 12:02 PM | #11 | |
Member#: 147328
South East
That does sound a lot easier to just do it when I get a TBE. If the stock piping comes off it is going to stay off. Thanks man. |
06-06-2007, 02:06 AM | #12 |
Member#: 131944
BAIC
Vehicle:2002 WRX Wagon |
So is it possible to just replace the factory O2 Sensor with a WB 02 sensor and plug the WB into the ECU and then be able to get the correct AFR from enginuity?
06-06-2007, 02:09 AM | #13 |
Member#: 131944
BAIC
Wait, there is 2 O2 Sensor right? one in the exhaust manifold on the passenger side and another one in the downpipe. Which one does enginuity display?
Under target boost and lean afr | jtmarsh | AccessPort | 2 | 02-23-2010 07:43 PM |
Going lean AFR tuning methodology! Post your thoughts :) | Tgui | Open Source Reflashes | 105 | 06-22-2009 11:03 PM |
vf39 installed - car misfires and hesitates >3000rpm + lean afr | anarchyburger | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 32 | 11-06-2008 12:21 AM |
Lean AFR when I let off the brakes! | pwrx | Brakes, Steering & Suspension | 6 | 09-24-2007 10:44 AM |
AFR rich to lean or lean to rich? | crashtke | AccessPort | 8 | 01-03-2007 10:48 AM |
