05-24-2007, 10:16 PM | #1 |
Member#: 131770
Vehicle:2017 WRX Black |
VF11 turbo
I have a VF11 turbo, I have tried to find out what the wastegate spring is inside for the pressure of the boost but cant find anything on it.
Does anyone know what a stock vf11 pushes ? thanks !
05-25-2007, 02:49 AM | #2 |
Member#: 31364
Vehicle:Ver6 Trek and couple bottle of gatorade 4boost |
i believe 10 psi is when the gate opens definately not 14.6psi
05-25-2007, 03:05 AM | #3 |
Member#: 76586
RMIC
Vehicle:2006 9-2x Aero |
Stock wastegate on mine is 6psi.
05-25-2007, 06:46 AM | #4 |
Member#: 131770
so now i can replace the spring with any 40-50mm spring to lower that ... correct ?
05-25-2007, 10:46 PM | #5 |
Member#: 93071
RMIC
Vehicle:1995 Impreza L EJ22G (Hybrid EJ22T/EG20G) |
From what I understood a stock vf11 was 5-6psi.
05-25-2007, 10:52 PM | #6 |
Member#: 36333
NESIC
Vehicle:98 RS GT30R, closed deck madnes |
is that the old stock Legacy turbo ?
05-26-2007, 10:43 AM | #7 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
yes i beleive it is.
05-28-2007, 01:16 PM | #8 |
Member#: 35330
NESIC
Vehicle:1999 RSTi + 4.44 = ) Silverthorn... for now |
yes, it is indeed. The car can 9ish PSI (maybe 10-11 peak) but wastegate pressure was 5-6ish pounds.
02-17-2016, 06:12 PM | #9 |
Member#: 432168
So you're all wrong. I have a vf11 on my 92 ss and its piped into a Manual boost controller and it will make a steady 17-18 psi at fully closed waste gate. Factory waste gate settings is 5-7 psi.
02-17-2016, 10:35 PM | #10 |
Member#: 36333
NESIC
good to know
02-19-2016, 08:44 AM | #11 |
Member#: 395223
E. Canada
Vehicle:1999 JDM WRX STi White |
One thing you have to keep in mind though is 19 PSI through a VF11 is no where near 19 PSI through VF48/54 ECT!
1991 Legacy Turbo Parts: VF11 Turbo, intake, injectors, etc | RYNOMOTO | Engine/Power/Exhaust | 17 | 05-08-2010 03:52 PM |
FS: VF11 turbo no shaft play $90 | blueGC | Engine/Power/Exhaust | 2 | 01-24-2009 01:01 PM |
FS - VF11 Turbo | vipergtrdj | Engine/Power/Exhaust | 2 | 07-23-2007 08:21 PM |
FS Turbo Legacy VF11 Turbo | Legacy777 | Engine/Power/Exhaust | 4 | 07-17-2007 09:49 AM |
FS Turbo Legacy VF11 Turbo | Legacy777 | TXIC Private Classifieds | 0 | 01-12-2007 02:34 PM |
