05-24-2007, 11:37 PM | #1 |
Member#: 80888
Vehicle:04 Forester XT Cayenne Red |
XPT Stage 2 Upgrade question
I can't believe I have had my Subaru almost 3 years now and I am JUST finding out about OpenECU! I am literally as excited now about flashing as I was when I first bought my Subaru.
My original goals were to bring the car up to Stage 2 with the proper parts and then buy an AP, flash it, and be done with it. I really was not planning on a custom tune, just running the OTS tune and being happy with it. But now that I have found out about OpenECU and the XPT Stage 2 flash, I immediately ordered my Tactrix cable and began reading all I could about the flashing process. My question is this, I already have my TBE and uppipe and panel filter. If I wanted to upgrade to an STi TMIC in the future would that be within the realm of the OTS XPT Stage 2 rom? CN: Have- Stock ECU 3in TBE STi Uppipe Prodrive Y pipe Drop in panel filter 94 Octane Doing- XPT Stage 2 Rom Future upgrade- STi TMIC, is it cool to run this later? Thanks for the help! Joe
05-25-2007, 12:46 AM | #2 |
Member#: 13626
Vehicle:02 996 |
Not 100***37; sure, but I think a larger IC = colder/more dense air, therefore running the same fuel maps would result in a leaner mixture.
Pretty sure you'd need to add fuel to your map once the bigger IC is installed. good luck |
05-25-2007, 01:32 AM | #3 | |
Member#: 72829
W. Canada
Vehicle:2006 WRX 2015 WRX |
Colder air means provides more knock margin so you could actually use less fuel or more ignition timing. |
05-27-2007, 11:36 PM | #4 |
Member#: 80888
I got my cable yesterday! 2 days to ship it from Seattle to Cincinnati!
I am going to pull my ROM tomorrow night and then start the tuning and flashing! Can't wait! Joe |
05-29-2007, 12:15 AM | #5 |
Member#: 80888
Got my ROM pulled, flashed a map, and then logged it. Anyone want to check it over for me?
Joe |
05-29-2007, 01:39 PM | #6 |
Member#: 142599
RMIC
Vehicle:2002 WRX silver |
Be carfull with this stuff. What stage 2 map did you flash. Do you have enough gadges to tell whats going on with your car(I didn't and it's scarry as hell). I full on suport openecu tuning but the elders are right, its not a walk in the park. PM me your log if you want.
05-30-2007, 10:59 AM | #7 |
Member#: 35076
TXIC
Vehicle:2004 507whp Wagon Silver |
Joe, if you've got a user on my Osecuroms forum go ahead and PM your logs over to me and I'll check them out. Make sure to get a log from 2000-WOT in 3rd gear with the desired logger settings. I'm going to be releasing a logger profile for Enginuity that will help with that as well. (ev8siv3 on osecuroms)
05-30-2007, 07:07 PM | #8 |
Member#: 134685
Vehicle:2002 Impreza WRX PSM |
yea, like mentioned above fuel shouldnt need to be added. Because even if the new IC allowed a greater amount of air in, the MAF is still going to count how much is commining in and compensate with the propor fuel to match the target a/f number set in the ecu. And yes, denser air can run less fuel and more timing!!
06-01-2007, 04:10 PM | #9 |
Member#: 11029
I am running a stage 2 xpt map with an STi IC and no problems so far. The STi IC is not of a greater size then the stocker to net a noticeble gain in cooling. The bigger IC makes it up in a lower pressure drop. It will not negatively effect the mapping and the ecu is more then capable of compensating. Man you subie guys are edgy about tuning....I have heard people talk about tuning for an intake. Over in toyota world we would run 25% larger injectors and let the ecu learn...lol.
06-02-2007, 12:51 AM | #10 | |
Member#: 134685
06-04-2007, 11:13 PM | #11 | |
Member#: 80888
Sending it over right now. Thanks! Joe |
06-05-2007, 11:46 AM | #12 |
Member#: 111029
SWIC
Vehicle:06 LGT & WRX Wagon Both XPT Stage 2 |
Hey Turboge! How did it go with the XPT MY04 FXT flash? You were saying that the map seemed pretty well tuned from the factory...
06-05-2007, 12:25 PM | #13 |
Member#: 35076
TXIC
The FXT has a nice map to begin with, but needs a GM BCS for futher tuning.
Once we get the BCS on there I will hook up the WBo2 to verify the stock map. |
06-14-2007, 01:23 PM | #14 |
Member#: 113426
SCIC
Vehicle:2005 Saab 9-2x Black |
what is a GM BCS? and WBo2?
06-14-2007, 03:43 PM | #15 |
Member#: 75682
Vehicle:2006 OB XT Limited Black |
^^ are you serious??
06-14-2007, 04:43 PM | #16 |
Member#: 113426
SCIC
^^^ yes, i'm new to this stuff
06-15-2007, 06:12 PM | #17 |
Member#: 98699
Vehicle:2007 SWP WRX |
it stands for GM Boost control solenoid and wide band o2. if you dont know what those mean start searching now!
Have accessport on my wrx running stage 1 gonna upgrade to stage 2 some questions | Cobb2006WRXJR | AccessPort | 10 | 11-19-2009 07:18 PM |
COBB stage 2 or XPT stage 2....one more time people | silvasooby | Engine Management & Tuning | 0 | 06-11-2008 07:27 AM |
XPT stage 2 questions | 94'325is | Engine Management & Tuning | 1 | 02-28-2008 09:10 AM |
Some stage 2 upgrade questions.... | J. Steinbeck | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 12-23-2007 03:56 PM |
stage 2 upgrade questions | skimmilk68 | Newbies & FAQs | 3 | 04-23-2004 12:22 PM |
