05-28-2007, 12:48 AM | #1 |
Member#: 94131
Vehicle:08' SRT Caliber Hard to keep clean black! |
Enginuity Question
I am trying to use this to do some data logging (no tuning!), Is there a prompt in the program to turn on the turn ignition, i'm having trouble connecting between the car and the program. All my programs are up to date, Anyone know whats going on?
05-28-2007, 12:52 AM | #2 |
Member#: 103136
What cable are you using? The latest version will auto connect and the parameters should show up on left pane based on your ecu. If not, then try changing the com port in the drop down box.
05-28-2007, 01:00 AM | #3 |
Member#: 94131
I'm using a tactrix cable, and also switched between the com ports and still nothing, the pc hardware wizard found and installed the cable, but still no connection.
05-28-2007, 01:13 AM | #4 |
Member#: 103136
Did you also install Ecuflash which install the tactrix drivers? Do you have the ignition turned to on or car running?
05-28-2007, 01:51 AM | #5 |
Member#: 129905
AKIC
Vehicle:2005 WRB WRX 2003 F-350SD, 7.3PSD |
ive had a few ppl tell me that they cannot log on ecu's that are tuned with cobb or protuners.. i guess the tune puts a lock on the ecu? id think that it woud still connect tho?
05-28-2007, 09:27 AM | #6 |
Member#: 103136
No, not logging. Ecutek "locks" the ecu for reading/flashing. Shouldn't for logging as far as I know.
05-28-2007, 12:31 PM | #7 |
Member#: 7022
Vehicle:2001 Forester Arcadia green |
Did you install the openport software? I had this issue on my intel mac, windows XP didn't really get the correct drivers for my application, so I had to go online and get all the coresponding drivers. Also, make sure its in the com port after the computer boots up. I noticed if I left it in, it wouldn't "see" it.
05-28-2007, 04:25 PM | #8 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
05-28-2007, 05:53 PM | #9 |
Member#: 94131
Alright thanks guys i'll try this and see what happens, I'm sure I have all the right downloads, i'll let you know.
Enginuity/Wideband Sensor Questions | pilotstephen | Engine Management & Tuning | 3 | 11-29-2007 11:10 PM |
Enginuity Logs...And Random Questions | Phatron | Commercial ECU Reflashes | 4 | 11-13-2007 06:46 PM |
enginuity log questions | nhat | Commercial ECU Reflashes | 10 | 10-24-2007 12:16 AM |
Enginuity data logger questions | equinsu ocha 07 | Texas Impreza Club Forum -- TXIC | 3 | 09-26-2007 11:14 AM |
UTEC+Enginuity questions | texas05sti | UTEC | 3 | 07-18-2007 05:35 PM |
