06-06-2007, 01:06 AM | #1 |
Member#: 98645
NESIC
Vehicle:2002 WRX Wagon PSM |
low boost, running lean
noticed while tooling around the other day, that my A/F had gone leaner than normal (as observed by LC-1+gauge). I took some logs tonight and saw that my boost is lower than normal (normally 18.2, most seen is 16.8)My normal full load AFR is between 11.3 and 11.5. I'm getting a consistent 11.9-12.0. My fuel trims are +/- 3-4% also. I figured a possible intake/boost leak, but my fuel trims would look all weird. And I would figure an exhaust leak would make my LC-1 read rich as exhaust gas escapes. Any insight?
06-06-2007, 01:14 AM | #2 |
Member#: 34860
Vehicle:2005 Forester CGM |
Boost leak = less boost = less load = leaner afrs if the particular load site you're hitting with lower boost calls for leaner afrs.
06-06-2007, 09:01 AM | #3 |
Member#: 98645
NESIC
thats the thing, i checked the load sites, and the AFR isn't much leaner than my full load AFRs.
06-06-2007, 10:39 PM | #4 |
Member#: 44422
SWIC
Vehicle:2009 G8 GT Cammed, sprayed, stalled |
Your boost may be lower simply from the warmer weather. Perhaps your AFR being off is simply due to a change in fuel? More ethanol content? Just throwing out ideas.
06-06-2007, 11:29 PM | #5 |
Member#: 60324
Vehicle:1998 RS |
are you hitting differnet load cels? differnet MAFv?
Misfire, Running Lean, And Boost Surge | jeminunguy | Tri-State Area Forum | 11 | 04-29-2010 01:55 PM |
Misfire, Running Lean, And Boost Surge | jeminunguy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 04-28-2010 08:43 PM |
Getting engine knock @ low RPMs & also running lean after Stg2 Map | zigforjustice | Open Source Reflashes | 3 | 01-09-2010 06:55 AM |
Running Lean Under Boost | SloRice | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 21 | 11-28-2005 01:15 PM |
Running Lean at full boost | tdorlando | Engine Management & Tuning | 13 | 09-18-2004 04:38 PM |
