06-06-2007, 02:01 PM | #1 |
Member#: 82612
Vehicle:2015 WRX STI Ice Silver Metallic |
Installed EGT sensor - check out my temps
Mods:
td05 20G 7cm2 sti tmic modded stock injectors stock intake w/ perrin drop-in stock block stock headers 93 octane fuel At redline I'm sitting at 1620* F Cruising around town I'm sitting around 1200-1300* F At idle I'm around 800-900* F A/F is 11.2 peak boost tapering to 10.8 at redline. 11* Timing at peak boost tapering up to 19* at redline. Boost is 20psi across.
06-06-2007, 02:21 PM | #2 |
Member#: 25433
Vehicle:2003 WRX SW all we'll drive |
Where is your egt probe located? It must be close to the exhaust port if you can see 1620F. Mine is at the driver side manifold.
When you see 1620F at redline, is that on a flat road? I'm chicken to go above 1600F so my target afr is just a tad lower than yours at redline. I climb a pretty long hill on my commute. Great info though! Thanks! |
06-07-2007, 08:58 AM | #3 |
Member#: 82612
Mine is on the driver's side too. 1620* F isn't bad at all. That's pretty much exactly where you want it. I may advance another degree and see if I can drop them down a bit. This was also in hot weather.
06-07-2007, 09:18 AM | #4 |
Member#: 44771
On my STi I've seen ~1700F to almost 1800F. Then again I was off the max of the probe. This was at almost 125mph in the straights at Grattan Raceway.
Not like I was racing in school zones while masturbating drunk to Jesus porn. |
06-07-2007, 09:19 AM | #5 |
Member#: 82612
Damn!
Check out my ghetto xm/hu/cell phone install | workin4audi | Car Audio, Video & Security | 6 | 07-12-2004 10:15 AM |
check out my automer A/F ratio gauge and Autometer Shift light install | FromMugen2STI | Member's Car Gallery | 3 | 08-25-2003 09:11 PM |
Quick help! have pics installing EGT sensor on Borla header | AndyM | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 01-03-2003 12:52 PM |
Check out my oil catch can install | jetguy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 45 | 07-30-2002 11:50 AM |
Need help installing EGT sensor | IMPBOY | Bay Area Impreza Club Forum -- BAIC | 4 | 02-27-2001 11:43 PM |
