06-15-2007, 04:36 AM | #1 |
Member#: 123873
BAIC
Vehicle:02 WRX Cobb Stage2 Silver |
Silly question: will disconnecting batt affect stg 2 map?
Just thought I'd ask so I can budget time:
I used openecu and tactrix to flash my 02 wrx to cobb stg2 map. I may need to disconnect the negative battery terminal for a few minutes tomorrow. Will I need to reflash the ECU or do Vishnu Reset trick, or will it be fine? Thanks all
06-15-2007, 09:26 AM | #2 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
You'll be fine, ecuflash stays in the ecu
06-15-2007, 11:33 AM | #3 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
The Vishnu trick will speed up the relearning features of your ECU, but isn't needed. Your car will do that fine on its own after a day or two.
06-15-2007, 01:20 PM | #4 |
Member#: 123873
BAIC
Good to know, thanks!
Ok to run base stg 2 map all the time? | Stiguy247 | Engine Management & Tuning | 9 | 05-18-2005 02:41 PM |
Which version Cobb stg. 2 map is better? | MF-DIF | Engine Management & Tuning | 4 | 03-05-2005 12:38 PM |
Stg.2 Map UTEC help | PaulRex | Engine Management & Tuning | 20 | 07-01-2003 08:55 AM |
Can I run TXS stg-2 map with the HKS DP? | Mitsuby | Engine Management & Tuning | 14 | 01-23-2003 03:43 PM |
generic stg 2 map and closed loop? | z&cobb | Engine Management & Tuning | 19 | 12-25-2002 02:49 AM |
