06-19-2007, 08:46 PM | #1 |
Member#: 101710
Vehicle:BOSS |
Wrong cable???
I just tryed reflashing my 2002 wrx ecu and im pretty sure the other cable that dangles off of the obd2 plug is the wrong one but im not positive. it should just plug into the bottom of the ecu right where the blue plug is?
06-19-2007, 11:32 PM | #2 |
Member#: 47145
Vehicle:2012 Gas Saver |
you bought the EVO cable, correct? Leave the dangling cable unplugged....
06-28-2007, 04:12 PM | #3 | |
Member#: 129905
AKIC
Vehicle:2005 WRB WRX 2003 F-350SD, 7.3PSD |
You did get the Evo\Subaru cable. You DO NOT plug it in to the ECU! The cable plugs in to your OBD2 Diagnostic port under the steering wheel. Never mess with the ECU. The white connector hanging off the OBD plug is not needed. You do however need to use the seperate blue connector block that came with the cable. Its got one wire. No offense dude.. But you should not be using openecu tuning if you don't know what ur doing... If you don't even know that the cable plugs in to the obd port, then that is not saying much about your ability to tune the car.. open ECU maps are OTS maps yes, But they are BASE MAPS only, 9 out of 10 cars need fine tuning to run safely. Just my 2 cents.. I think you need to go with an AP or let a professional tuner do your flash and fine tune it for you.. Yes its going to cost you some money, but its gonna be cheaper than replacing your block with a piston hole in it.. Most tuners charge an hour fee for fine tuning work like this, In houston at Engine Logics its 175 an hour, and i doubt it will even take an hour. Maybe 30 mins tops. Good investment... |
Monster Cable sued the wrong company... OMG BOOBIES! | Neek | Off-Topic | 70 | 12-30-2009 12:44 AM |
Help wrong cable with V1 | down_for_the_scooby | AccessPort | 8 | 11-24-2009 12:29 AM |
Unable to connect to romraider... possible wrong tactrix cable? | All4bSpinnin | Open Source Reflashes | 15 | 04-29-2009 12:33 PM |
Wrong Tactrix Cable or UTEC Issue? | litebrite2001 | Open Source Reflashes | 2 | 08-12-2008 07:18 AM |
whats wrong with my clutch cable | scobaru | Transmission (AT/MT) & Driveline | 2 | 08-25-2003 01:08 AM |
