06-25-2007, 12:06 AM | #1 |
Member#: 139465
Vehicle:2011 STi Limited Satin White Pearl |
2006 WRX Fog Light Removal
Can someone post a link or explain how to remove the fog light (including the bodywork that goes with it).
thanks.
06-25-2007, 05:21 PM | #2 |
Member#: 139465
bump1
06-25-2007, 05:42 PM | #3 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
i think those covers just pop out. then you can unscrew the light. its uber simple.
Shane |
06-25-2007, 06:30 PM | #4 |
Member#: 139465
06-25-2007, 07:14 PM | #5 |
Member#: 140712
SCIC
not sure, but i think its in the manual under replacing fog light bulbs
Shane |
06-25-2007, 08:09 PM | #6 |
Member#: 121883
E. Canada
You'll need to get under the front of your car, you'll see black clips that hold the under body plastic lining thats under your foglights.. pop 'em out, only those around the foglight areas..
then fold/pry them out of the way. Stick your hand through, and you'll touch the back of your fog lights. You'll need to use a screw driver + cloth to remove the fog light bezel. There's a small slot at the bottom-center of your fog light bezel. Put a screw driver and cloth (to avoid scuffing/chipping your paint!) Pry it out. Then use a #8 or #10 (I forget) ratchet with extension to remove the 2 bolts (bottom of foglight) that holds it to the car. Un-do 'em and pull your fog light out. Harness is about 6" long.. unclip it if needed. Then you can remove them and replace the bulbs. Takes 10mins each about. |
06-25-2007, 08:57 PM | #7 | |
Member#: 139465
thanks jezzy
06-27-2007, 11:23 AM | #8 |
Member#: 120152
You can also undo the clip for the fog cover from the back if you're worried about marring the paint on the front.
06-28-2007, 05:42 PM | #9 |
Member#: 121883
E. Canada
True true.. push the tabs in from behind.. =) good point.
06-29-2007, 11:03 PM | #10 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
Ive found a butterknife works best for this. YMMV
06-30-2007, 11:28 AM | #11 |
Member#: 139465
06-30-2007, 02:48 PM | #12 |
Member#: 122980
South East
WTB: 2006 WRX Fog Lights | bluescoobie2 | Private 'Wanted' Classifieds | 0 | 05-16-2010 02:55 PM |
Removal of 06 WRX fog lights | brodiemash | Interior & Exterior Modification | 7 | 06-02-2006 01:47 AM |
WTB: 2006 WRX fog light - driver's side | 99ways2die | Private 'Wanted' Classifieds | 0 | 01-11-2006 09:28 PM |
How do you remove 2004-2005 WRX fog lights? | wanger | Interior & Exterior Modification | 4 | 07-04-2005 03:12 PM |
removing 04 wrx fog light covers | tacomaprime | Interior & Exterior Modification | 1 | 01-21-2005 08:35 PM |
