Welcome to the North American Subaru Impreza Owners Club Saturday May 8, 2021
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-25-2007, 08:53 PM   #1
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Default Baja Turbo spark plug change; How bad is it?
So, I've heard that it's a nightmare to change the plugs on a Baja Turbo (we have an '05). I've heard everything from having to take out motor mounts and push the motor sideways to having to lift it up with a cherry picker or something. What's the deal here? Has anyone actually changed Baja turbo plugs? Is it really that nasty to do? Help?
I've got ~80,000 miles on the one we just picked up and the Owner's manual specifies 60,000 mile intervals for the turbo, even with the iridium and platinum plugs. I seriously doubt they've ever been changed and I'd prefer to keep things in top shape prior to a failure in this regard.
bulwnkl is offline   Reply With Quote
Old 06-26-2007, 01:45 PM   #2
narenji
Member#: 12727
2016 ATS-V
Phantom Gray
or you could have an asian mechanic do it. it's not terrible, but definitely not easy. mostly its VERY tedious. you have to remove the airbox, the battery, windshield washer fluid bottle... ill be attempting mine soon.
narenji is offline   Reply With Quote
Old 06-26-2007, 06:17 PM   #3
shipjumper
Member#: 6307
what I has no car...
am carless
anyone done em from underneth? I was just thinking that would be easier
shipjumper is offline   Reply With Quote
Old 06-28-2007, 11:20 PM   #4
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
I got mine done with NGK 1 step colder plugs when I got a retune. they had to undo the motor mounts and jack the engine to pull them out. booo hooo, labor was a bitch, but perhaps there is an easier way... keep us posted if you find it. Good luck!
cliffhanger is offline   Reply With Quote
Old 06-29-2007, 03:58 PM   #5
bajawes
Member#: 128015
03 baja
yellow
i did mine myself and thought it was easy. now, i don't have a turbo but can't see how it's so much different. as said previously, the battery and washer jugs gotta come out and make room around the air intake, i know ya'lls are a little different for the n/a models but i really don't see any need to jack the engine in any way to do this 1 hour project. is there that big of a difference between the two?
wes
bajawes is offline   Reply With Quote
Old 06-29-2007, 09:56 PM   #6
shipjumper
Member#: 6307
am carless
YAH, NA is 100***37; different from twerbo.
I have done WRX plugs from the top down, and its a pain, back breaker....
I dont see why it would be needed to LIFT the engine... you remove the air box, and washer fluid, and then remove the coil packs, then put the socket in the hole... put an extention on the socket, push it down to the plug, remove, install repeat... its just a pain, but not hard...
Old 06-30-2007, 08:04 AM   #7
the slug
Member#: 139006
I haven't been under the hood of a Turbo model, but ours (the NA crowd) is a SOHC. The Turbos are DOHC, maybe the head design is enough different to need to lift the engine some for sparkplug changes. I've had front-wheel drive V-6s that I had to do that to.
Ease of Tune-up; Advantage goes to NA (oh, and we don't need premium fuel sorry, had to add that)
the slug is offline   Reply With Quote
Old 07-01-2007, 09:10 AM   #8
shipjumper
Member#: 6307
am carless
no maybe about it...
they are different. take a look at the DOHC NA subaru motors, same deal, they are a pain to get to, but not enough to lift a motor...
those are people looking to complain about all they HAD to do to get it done, instead of looking for easier routes...
Old 07-01-2007, 10:36 PM   #9
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
I was just under the hood of my turbo tonight trying to find where I've got a line or a heat shield vibrating (never did find it). After pulling off the underbody shielding (7 screws) I saw where it was very easy to get to the driver side plugs/coils. Passenger side was a bit of a different story with a big exhaust pipe running along the side..
It should be fairly easy to change out my plugs when the time comes on my turbo.
moonzie is offline   Reply With Quote
215/40/17's on bugeye wrx, how bad is it? LASERBLUE135 Tire & Wheel 15 06-07-2010 07:56 PM
Spark plug removal! How to get it out? fowler-04wrx Service & Maintenance 27 06-04-2005 02:18 PM
How bad is it to leave out the exhaust manifold heat shields? Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-10-2002 11:30 PM
How bad is it to.... IggDawg Brakes, Steering & Suspension 6 10-30-2001 08:04 PM
How bad is it if my car is knocking? myko011 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-13-2001 04:31 AM
