Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 07-17-2007, 01:49 PM   #1
P&L Motorsports Inc.
Vendor Sales Rating: (26)
Member#: 67199
Default P&L Motorsports releases their Tial BOV kits for Impreza TMIC applications
http://www.pandlmotorsports.com/~pan...2aa2a0dd495ac3 <-- You can view this product in our online shopping cart.
At P&L we've always realized that the Subaru lineup of mass air flow based vehicles are very sensative to leaks in the induction systems.
What our maintenance programs have taught us is that 7 times out of 10 the compressor bypass valve (BOV) is the biggest source of failure, followed closely by inlet hose failures.
We always knew that Tial's products had been legendary in terms of reliability, but never had a way of packaging their BOV design in such a way that every Impreza owner could leverage them. That has changed with the release of our new BOV kit for the 2002-2007 Impreza lineup.
We start off with a custom designed and waterjet cut flange. That is precision tig-welded onto a v-band flange that the Tial high performance BOV is bolted onto. Then the entire assembly is machined to make sure the flange surface is flat and true.
Our kit has been designed and tested around several of the common aftermarket intercoolers, as well as the standard OEM units.
Our kits will be competative and retail in the same area as other high quality atmospheric units such as HKS's SSQV.
All kits will include our custom flange assembly, v-band flange, the Tial unit, a new 3 layer BOV gasket, and a machined plug for your factory return line. You supply the elbow grease, and about 3 minutes later, you're done.
Contact us with any questions you may have.
-Jorge
*Update*
We are now offering our BOV Kits with a REUSABLE O-ring gasket built in to the flange! Instead of paying for a new gasket each time you want to take the intercooler or BOV off, you can reuse this one which is pressed into the flange. It also provides better protection against boost leaks as pressure is applied evenly around the hole to ensure a proper seal!
P&L Motorsports Inc. is offline
Closed Thread
FS: p&l/tial bov kit for tmic in WI! n2oiroc Engine/Power/Exhaust 0 05-01-2008 05:05 PM
P&L Motorsports releases their 2008 Race Series Catback! P&L Motorsports Inc. Engine/Power/Exhaust 0 11-21-2007 12:31 PM
P&L Motorsports releases their 2008 Race Series Catback! P&L Motorsports Inc. MWSOC Vendor Classifieds 0 11-21-2007 12:30 PM
P&L Motorsports releases their Tial BOV kits for Impreza TMIC applications P&L Motorsports Inc. MWSOC Vendor Classifieds 14 08-22-2007 12:53 PM
