Welcome to the North American Subaru Impreza Owners Club Saturday May 28, 2022
Old 08-10-2007, 07:12 PM   #1
gumby647
Member#: 2532
2001 2.5RS-T
BRP
Default Bad Transfer Gear Bearings
Has anyone seen these do this before? I've been getting a lot of noise that sounded like a bearing and what do you know .
All the other bearings and gears look fine. I don't know if it's from the Royal Purple I've been using in there or if there preload was never set right from the get go.
gumby647 is offline   Reply With Quote
Old 08-11-2007, 01:47 AM   #2
DJT-WRX
Member#: 112829
2006 WRX TR
San Remo Red
Just curious to know what the noise was like that you were experiencing?
I have a 2006 WRX TR with 20,000 miles and this is what I'm getting now:
With the engine running and the transmission in neutral, there is a squeak or squeal that goes away when the clutch is depressed. Noise is also heard while the car is in gear and moving.
Pilgrim Subaru in Rhode Island has already replaced the throw out (clutch release) bearing but I noticed the noise again a day or two later.
It's going back to the dealer on Monday and I'm going to request that they take a good look at the transmission and related bearings.
At this point I have mixed emotions; I am happy that the problem is closer to being solved but sad because I don't want to be without my car for a week or so.
DJT-WRX is offline   Reply With Quote
Old 08-11-2007, 07:40 AM   #3
gumby647
Member#: 2532
2001 2.5RS-T
BRP
I was hearing a growling noise like a bad wheel bearing only when I jacked up the car to find the noise it was coming from the tranny. Your problem won't be the same bearings since these only spin when the car is moving so you won't get any noise in neutral.
If I were you I'd wiggle the clutch fork while the noise is happening and see if it changes. If it does they did a bad job on the TO bearing. If not I guess a main shaft bearing.
Old 08-11-2007, 11:07 AM   #4
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
If your going through TO bearings that quickly then I think they need to adjust the clutch pedal, because it must be pushing on the TO and making it wear out very quickly.
Or the TO fork is screwed up somehow.
Crazykev is offline   Reply With Quote
Old 08-12-2007, 05:37 PM   #5
DJT-WRX
Member#: 112829
2006 WRX TR
San Remo Red
I think the throw out bearing and the rest of the clutch assembly is fine. At this point I really think it is something in the transmission. I think the OP is on the right track with the main shaft bearing.
It's going to the dealer again tomorrow morning I'll post about it again once I get the car back.
On a side note I checked the tranny oil the other day (about 5 days after the throw bearing was replaced) and it was low. Does replacing a throw bearing involve draining the tranny oil? I'm wondering if the dealer forgot to top the tranny oil off once the work was done. They did neglect to put the turbo heat shield back on.
Bears Vikings How bad will the Bears be slaughtered tonight? Akirasoft Mid West Subaru Owners Club Forum -- MWSOC 20 12-18-2007 05:37 PM
Bearing preload for center diff transfer gears. 340Duster Transmission (AT/MT) & Driveline 2 05-21-2007 04:24 PM
WTB: 99+ RS Transfer gears Splinter VIC Private Classifieds 0 11-13-2006 04:50 PM
EDM & New USDM 1.1 to 1 Transfer Gear scarygary Transmission (AT/MT) & Driveline 5 11-01-2006 06:14 PM
Gauging interest on "unbreakable" output-transfer gear-shaft sets for 5mt and 6mt's WRXINTX Transmission (AT/MT) & Driveline 14 05-04-2006 04:02 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
