01-08-2002, 08:50 AM | #1 |
Member#: 9078
Vehicle:2006 STI Gray |
car wont start in the cold
This only happens when temp is below freezing-Forester 2001 automatic wont start. Engine cranks, after several minutes it will finally start. Subaru replaced fuel sensor (but this was not the problem apparently), dealer said everything else checked out fine when this happened last year during winter. Dealer had car for 3 weeks!! (but weather was not below freezing). No problems with warm weather.
Any help is appreciated-
01-08-2002, 03:05 PM | #2 |
Member#: 3409
NWIC
Vehicle:98 My FMIC Is bigger than yours. |
Try stuffing a more powerful battery in it. The stock batteries are nothing to scream about, quite weak in fact, and cold weather slows the reaction down enough to make it hard to start. Either that or get a battery warmer and keep it plugged in.
01-08-2002, 04:03 PM | #3 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
well i am going to throw a bone out here...try a coolant temp sensor...it sounds to me like the PCM is not giving the car enough cold start enrichment. Whenever we have a hard start when cold it's typically and intermittent problem with the TW(coolant temp) sensor. Might want to suggest they look at that with the car outside and see what the PCM is offereing as injector duty cycles.
jeremy |
PROBLEM!! crank case sensor, wont start in the morning | sike43 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 01-09-2010 07:32 PM |
05 wouldnt start in the cold *** | 05rswagon | Normally Aspirated Powertrain | 5 | 12-20-2004 08:48 PM |
How are 600+ cc injectors starting in the cold (freezing) temps? | SlideWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 11-19-2003 12:26 PM |
Help, Car wont start... friday the 13th, coincidence? | biggreen96 | Legacy Forum | 15 | 12-15-2002 03:34 PM |
Is anyone having trouble starting in the cold? | M a t t | General Forum Archive | 37 | 12-11-2000 04:43 PM |
