Welcome to the North American Subaru Impreza Owners Club Monday October 23, 2017
Old 08-27-2007, 11:11 PM   #1
anurevolution
Member#: 157557
2007 2.5i
Newport Blue Pearl
Default Stock 06 STI exhaust on 07 2.5i
I've been thinking of putting an 06 STI exhaust on my 07 2.5i. I know a guy that I can pick one up from for $250 which is a deal and a half. I already know I'd have to weld a reducer on the pipe to get it to fit. I just want to know if it would be a good idea or not. And if it would either benefit my car aside from making it sound beastly or have negative repercussions.
anurevolution is offline   Reply With Quote
Old 08-29-2007, 05:33 PM   #2
tludwins539
Member#: 149764
2007 2.5i
for that much money you could get a catback exhaust made for your car. You can even get the SPT exhaust for that much. There isnt a need for the STI exhaust on your car anyway, if anything just get the axleback from a wrx or sti and it will be a much easier and cheaper change with the same result.
tludwins539 is offline   Reply With Quote
Old 08-29-2007, 11:37 PM   #3
anurevolution
Member#: 157557
2007 2.5i
Newport Blue Pearl
wouldn't the axel back exhaust from a wrx or sti.. still need a reducer to fit the 2.5i.. being that they are turbo'ed so its a 3" pipe. ??
Old 08-30-2007, 04:16 AM   #4
subySerb
Member#: 155411
from what i read here, STi axleback is a direct bolt on for the 2.5i.
p.s. What kind of color is Nautilus Blue, i thought that only Newport was available on the 07's
subySerb is offline   Reply With Quote
Old 08-30-2007, 10:08 AM   #5
novacivic
Member#: 117980
2005 sti
wr blue
you also need to lengthen the midpipe to put it on because of the new cat design. the new cats are shorter than previous models. your best bet would be to find an aftermarket made for your car or do the axle back. the sti axle back is larger diameter than the wrx.
novacivic is offline   Reply With Quote
Old 08-31-2007, 03:32 PM   #6
05BluePearlGT
Member#: 111760
1993 Impreza L
Java Black Pearl
yeah, thats a ripoff, dont buy that. You can find a cheaper one elsewhere. But a wrx axleback would be your best bet. I have a 02 or 04 wrx axleback on my 93 L
I paid 20 for that, and 40 to have a flange chopped off and rewelded (rotated). Yours should be a direct fit though
05BluePearlGT is offline   Reply With Quote
Old 08-31-2007, 07:34 PM   #7
Churro80
Member#: 145876
07 Impreza 2.5i
obp
I recently got an 07 STi axle-back on my 07 2.5i. It was a direct bolt on replacement. 10 minutes start to finish w/out jacking the car up. Just crawled under It made a small difference noise wise, still quite quiet which is what i wanted. Noticed a small difference in power but that might just be the placebo effect Got it used of another local NASIOC member for $70. All in all it's not going to change much for you but anything looks better than the stock "pea-shooter" on our 2.5i's. Sounds like you might want to search for one cheaper, they are usually between 100-125 if they are near perfect. I just got lucky and found a good deal from a fellow member.
Hope this helps. GL
Churro80 is offline   Reply With Quote
Old 08-31-2007, 08:43 PM   #8
yo14jman
Member#: 138229
2006 STI
um dude $250 isnt a deal...i see your from the tri state area too, i have a OEM 06 STi catback for sale $75 picked up! ONly has 10,700k on it. Let me know, i live in bethlehem pa
yo14jman is offline   Reply With Quote
Old 09-07-2007, 11:46 PM   #9
turbowagon
Member#: 11619
2008 Impreza Hatch
Spark Silver
Shouldn't pay more than $100 for an STi exhaust. That is the going rate. Yes it bolts up perfectly.
turbowagon is offline   Reply With Quote
Old 09-09-2007, 12:56 PM   #10
Dayzwalker
Member#: 157738
2007 2.5I Wagon
what about for a wgon? I have an 07 2.5I wagon and I want to upgrade the stock pea shooter, but NOT go aftermarket. Will the exhausts from sedans fit as well or am I stuck with finding a wrx wagon exhaust???
Dayzwalker is offline   Reply With Quote
Old 09-17-2007, 10:09 PM   #11
new2.5i
Member#: 149435
2013 GRF STi
bump for same answers
04-07 STi axlebacks -> straight bolt-on onto 06-07 2.5i's without any modifications?
new2.5i is offline   Reply With Quote
06 STI headlights install on 07 2.5i/WRX Shiz36 Electrical & Lighting 12 05-19-2010 09:29 PM
Update to 07 STi cat-back on 07 2.5i Wagon nuggetWRX Normally Aspirated Powertrain 8 05-15-2008 12:45 PM
2006 STi exhaust on 2007 2.5i zsimpreza Newbies & FAQs 7 09-12-2007 08:48 PM
Disabling DRLs on 07 2.5i same as 07 WRX/STI? Jonny07subie Electrical & Lighting 2 08-17-2007 02:11 PM
STi Exhaust on a 2.5i? Civic2Subie Normally Aspirated Powertrain 20 01-07-2006 03:43 PM
