Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 09-12-2007, 06:25 PM   #1
Invision STi
Vendor
Vendor Sales Rating: (3)
Member#: 126364
Default -iptuned.com: Exhaust POWER POST
XO2 Racing TMIC/FMIC/BOV/EXHAUST MANIFOLD/HOSES
Best prices Guaranteed.
PM ME, You will be suprised how much a TMIC KIT COST!!
20"x8"x4" (inch) WRX/STI TMIC Upgrade Kit come w/ all hardware
[IC-Z3038]
$250 shipped
XO2 Racing TOP MOUNT INTERCOOLER Complete Kit
Fit 02-06 Subaru WRX/STI. Direct bolt-on with no modification needed.
Come with Y-pipe silicone coupler and t-bolt clamps
Bigger capacity than the STi stock intercooler
Brand New...100% Aluminum, hand welded, constructed with a bar & plate design. Polished finish intercooler. Perfect for your next turbo project or upgrade.
850 CFM. Good for up to 500 bhp. low pressure drop 0.2psi at 15psi *Strong Bar and plate design allow 80psi high efficient we are very confident on our BAR AND PLATE intercoolers against efficient,reliability, all our intercooler has been tested to withstand more then 80psi pressure and it has very small pressure drop across the end tanks, at 15psi inlet the out let has 14.8psi that means it has only 0.2 psi pressure drop ,compare to many other intercoolers it is an excellent figure (some intercooler has 1-2psi pressure drop) also at the same condition, the temperature has drop from 120 degree to 28 degree ( and it is an excellent figure for efficiency)
Core Length : 20"
Core Height: 8"
Core Thickness: 4"
Outlet Size: 2.75"
Overall Size: 20" X 12" x 4"
BOV Adapter for 02 & Up Subaru WRX/STI
[BOV-10155]
$20 shipped
BOV Adapter for 02 & Up Subaru WRX/STI (BOV SHOWS IN THE PICTURE SOLD SEPARATELY)
Subaru 02+ WRX/Sti Catback w/Down-Pipe, Up-Pipe,
[CB-SW0204]
$340 shipped
100% SUS-304 Stainless Steel with computerized mandrel-bent 4 inch bellmonth design (the best for the WRX) 3 inch all the way back
-Tip size is 4.5 inch comes with silencer 3 inch stainless piping
- INCLUDES " REMOVABLE SILENCER " ALSO
- Comes with gasket and bolts.
- CNC machine flanges for strong solid support
- TIG weld for strength and durability
- 3 stage polish shine like a mirror
- Increase 20-30 horse power and torque
- Straight thru design and bolt-on installation
SUBARU IMPREZA GD/GG 2.0/2.5 WRX, WRX/STI 09/00 (2) RADIATOR HOSE
[SIL-RH015]
$70 shipped
SUBARU WRX 02 & UP RADIATOR
[RD-005]
$270 shipped
SUBARU WRX STI 04+ (4) TURBO HOSE
[SIL-TH001]
$135 shipped
Subaru WRX/STi 02-05 Front Mount Intercooler Kits
[PIPE001]
$370 shipped
THIS IS BRAND NEW FRONT MOUNT INTERCOOLR KIT FIT ALL 02-05 SUBARU WRX or STI. Polished aluminum intercooler piping, Oversized for maximum air flow, Increase horsepower and torque, Requires short ram intake and removes standard fog lights.
Kit inculding:
(6) PCS from 2.00 to 2.75 Intercooler set up piping.
(1) large front mount intercooler.
Core dimensions: 24" length x 9" Height x 3" Thickness
inlet and outlet size is: 2.5 "
END TO END length: 31"
(8) 3 polyester reinforced High temperature silicone hose.
Pressure Rating: 35PSI
Temperature Rationg:-65F to 350F
(16) T-Bolt Clamp best for turbo application.
Subaru WRX/STI 4-2-1 Equal Length Exhaust Manifold
[MF-EJ20]
$330 shipped
02-06 Subaru EJ20 EJ25 WRX/STI/Equal length manifold/Header T-321 Full stainless steel mandrel bend for ultra fast flow Integrated up-pipe Increase turbo spool up time, horsepower, and torque Reduce Turbo Lag CNC machine flanges with TIG and MIG welded construction 4 to 2 to 1 DESIGN LIGHT WEIGHT Gaskets and hardware included
Subaru WRX/STI Turbo Inlet Hose
[SIL-ih001]
$125 shipped
WRX/STI BOV
[BOV-WRX]
$70 shipped
Brand New! WRX/STI Blow Off Valve / Bypass Valve
Protect your turbo by releasing pressure surges when changing/shifting gears or backing off throttle quickly.Come with standard durable cast or aircraft grade billet aluminum frame and body.
Bypass or Blow Off Design
direct bolt on fit 02-05 Subaru WRX/STI
INCREDIBLE SOUND!
__________________
Invision Performance, Inc.
http://blog.invisionperformance.com
Invision STi is offline   Reply With Quote
Old 10-03-2007, 02:48 PM   #2
Invision STi
Vendor
Member#: 126364
iptuned.com is back
__________________
Old 10-12-2007, 03:03 PM   #3
Invision STi
Vendor
Member#: 126364
best prices
__________________
iptuned.com: SUN AUTO PRODCUTS BLOW OUT SALE Invision STi Gauges & Electronics 2 12-31-2007 08:50 AM
-iptuned.com: Exhaust POWER POST Invision STi Engine/Power/Exhaust 15 09-06-2007 09:10 PM
Exhaust power gains C Dust Engine Management & Tuning 8 03-05-2003 11:41 PM
Exhaust power gains? eingram Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-01-2003 03:44 AM
Initial data on MRT exhaust power gains Patrick Olsen Normally Aspirated Powertrain 10 08-18-2001 11:30 AM
