Welcome to the North American Subaru Impreza Owners Club Saturday September 23, 2017
Old 09-16-2007, 09:29 PM   #1
jays05
Member#: 78165
05 STI 35r + e85
Default Built motor failure: P0345 and no compression ==> busted cam! now with pics
Well, I was out driving today and the car felt like a cylinder dropped out or like it was running really rich. It died as I was pulling off the road into a parking lot. I had my laptop and an obd2 scanner with me so I read the code... P0345.
P0345: Camshaft Position Sensor A - Bank 2 Circuit Malfunction
I had just washed the car, so I hoped for the best that something had just gotten wet... I cleared the CEL and tried starting it, but it sounds like there is no compression. Sounds exactly like when you have the spark plugs out and are doing a compression test. So I think it's safe to assume that something in the heads let go and the valves are stuck open
I had the car towed back to the shop that built my motor. I had left my beater car in the parking lot there so I drove that home.
Any guesses as to what happened? I am guessing that the timing belt skipped a tooth, an idler failed, a cam gear broke, or something along those lines. I was running 27psi on 93+meth at the time, and had done a 3rd gear pull about a minute before the car died.
And an abreviated modlist:
cp 100mm pistons, pauter rods
stock crank, oem bearings, cosworth oil pump
ported heads, supertech valvetrain, oversize SS valves, cosworth 278/274 avcs cams
pe timing belt, new tensioner, cosworth timing belt guide
~3800 miles
see below for update and pics
jays05 is offline   Reply With Quote
Old 09-16-2007, 10:01 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I would bet a timing belt issue. Was the idler reused or replaced?
mick_the_ginge is offline   Reply With Quote
Old 09-16-2007, 10:06 PM   #3
jays05
Member#: 78165
05 STI 35r + e85
The idlers were reused. All seemed fine. The car has 44k original miles.
Old 09-16-2007, 10:10 PM   #4
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Yea timing accident..
I had this happen at a gas station once.. I shut the car off and got gas... when I restarted it it started and died. Popped 2-3 codes, as well as the Tbelt and valves..
Junior2JZ is offline   Reply With Quote
Old 09-16-2007, 10:54 PM   #5
jays05
Member#: 78165
05 STI 35r + e85
I was driving at ~3000rpm when it happened. Right before that about a mile down the road I did a sick 3rd gear pull under a bridge and everything was great.. After that I was just cruising when it let go
Old 09-17-2007, 03:10 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hmmm.. was that a premonition or what?
very sad to hear of your issue, jay.
even though i'm a cheap bastard, if i ever rebuild my engine it is going to have one new t-belt tensioner. i've heard too much baloney ensue from reusing them to take the chance.
ken
Old 09-17-2007, 03:36 PM   #7
jays05
Member#: 78165
05 STI 35r + e85
Actually I was leaving my beater at the shop because we were gonna blow it up on the dyno with NAWZ
I talked with somebody at the shop this morning and they expect to be able to get the timing belt cover off today.
Old 09-18-2007, 12:56 AM   #8
modaddict
Member#: 95840
sold to a good bud
awaiting next car
damn jay you can has no lag.
let us know what happened with PICS!
modaddict is offline   Reply With Quote
Old 09-18-2007, 12:25 PM   #9
modaddict
Member#: 95840
sold to a good bud
awaiting next car
updates?
Old 09-18-2007, 01:26 PM   #10
jays05
Member#: 78165
05 STI 35r + e85
update: no word from the shop yet. And I hate driving my beater car.
I have datalogs from one hour before it happened and all looked good. Although I really doubt that I could have done anything with the tune to cause this. I normally always datalogged, but I was driving from the carwash back to home so I wasn't logging. I logged on the way there.
It's finally setting in that my motor let go... and I am really now.
Old 09-18-2007, 04:18 PM   #11
Badazzcr
Member#: 67693
4 Making them
faster then anyone else.
this actually is pretty common, tell the shop to unplug the sensors and blow the water out of the connector/sensors. The cam sensors are not sealed and can get water inside them causing it to read incorrectly.
Badazzcr is offline   Reply With Quote
Old 09-18-2007, 04:22 PM   #12
jays05
Member#: 78165
05 STI 35r + e85
Wow, I will paypal you $5 if that fixes it.
But I am concerned about how the car sounded when cranking it over.
Old 09-18-2007, 08:13 PM   #13
Shawn96VR-4
Member#: 129912
1996 3000GT VR-4
Panama Green / Tan
*hopes for good news*
Shawn96VR-4 is offline   Reply With Quote
Old 09-18-2007, 10:39 PM   #14
FrodoTBaggins
Member#: 117154
2005 OBP STi
No mods yet, soon to come
+++++++111111
FrodoTBaggins is offline   Reply With Quote
Old 09-20-2007, 03:32 PM   #15
jays05
Member#: 78165
05 STI 35r + e85
Well, the timing belt didn't skip, and there wasn't any water in the cam position sensor connectors.
Compression and leakdown test next...
Old 09-20-2007, 06:39 PM   #16
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
^ tell me about it.. I`am in a 95 oldsmobile!
Good luck let us know what happens when you get those numbers!!
STi_Guy04 is offline   Reply With Quote
Old 09-21-2007, 04:11 AM   #17
BLUE STINGER
Member#: 84206
Wow sorry to hear Jay. Good luck with it.
Regards,
Ron
BLUE STINGER is offline   Reply With Quote
Old 09-21-2007, 08:32 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hmmmm... that would have been my from the hip diagnosis.
strange that it sounded like there was no compression... i remember that sound distinctly when it came from my wife's 1st gen eagle talon 4g63 after the balance shaft belt disintegrated and threw itself into the main timing belt causing it to skip about 10 teeth.
Old 09-21-2007, 09:01 AM   #19
jays05
Member#: 78165
05 STI 35r + e85
Yeah, I've compression tested the motor a few times recently, and I've also primed the motor after an oil change (just a couple days before this all happened) and I know the difference in how it sounds.
I'm already wishing I never posted about this though. "Word on the street" is that my crappy tune blew it up. If a piston or valve melted, or it spun a rod bearing, yeah, I probably did it. I can't see any of those problems throwing a cam position sensor CEL.
And regarding the CEL... Bank 2 is the passenger side right?
Old 09-21-2007, 12:25 PM   #20
modaddict
Member#: 95840
sold to a good bud
awaiting next car
you would really have to be trying to melt a piston. OR your water/meth failed on that pull.
either way, I wish you luck. I think you'll pull off the valve cover/head and you'll find the culprit.
Old 09-21-2007, 03:52 PM   #21
jays05
Member#: 78165
05 STI 35r + e85
Cylinder 1
115 psi 5% leak down
Cylinder2
0 psi 80% leak down
Cylinder 3
110 psi 30% leak down
Cylinder 4
25 psi 45% leak down
They said that one cyl was leaking through the intake, and two cylinders through the bottom end.
If one cyl wasn't leaking through the intake, and if it hadn't thrown the P0345 CEL, I would believe that it was a fueling issue due to massive det. But right now I am not sure what to do
Old 09-21-2007, 04:10 PM   #22
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I would bet you have bent valves, hence the 0psi which was produced by a slipped timing belt.
Old 09-21-2007, 04:13 PM   #23
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
with 0 compression and that much leakdown on cyl 2, that would hint toward a valve issue no?
jigga is offline   Reply With Quote
Old 09-21-2007, 04:44 PM   #24
jays05
Member#: 78165
05 STI 35r + e85
The timing belt didn't slip. I am betting the pistons hit the valves. I had upped the AVCS from 7.5 to 10 about a week earlier and did maybe 100 miles like that, including two passes at the dragstrip and some street action the night before.
This post from my original build thread is coming back to haunt me.
They are the Cosworth 278/274 AVCS cams that bboy analyzed and made a great thread about(I read it at least 20 times). 10.9mm lift on the intake cams and 10.28mm on the exhaust cams. This is something I was really concerned about. My engine builder didn't check for piston/valve interference at full avcs advance. So, on the first day I got the motor back, I put 20 in the avcs map (10 degrees @ cam) and it didn't grenade I don't think I will even try going higher than that, although I have talked to somebody with the same pistons and cams who is running full avcs advance. I have read that these cams do not need a lot of avcs advance.
The shop thinks it was a fueling issue that led to massive det. I want to see the plugs up close... they were NGK coppers with maybe 1000 miles on them, if that... if there was massive det enough to completely destroy CP pistons, some remnants of the pistons should be on the plugs.
Old 09-21-2007, 04:51 PM   #25
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Ok, I still think valves only issue rather than det for something like this but I am looking forward to the real story and pictures
CP's IMO are pretty much indestructable, do you remember the sponaugle thread where one of his valves broke off into the cylinders?? The CP's bounced that thing around during the dyno pull and still made 400 WHP.
That would have to be MASSIVE det and heat to burn up a CP.
Help!!! PLZ One Spark and No Start :( TheGroceryGetterWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-17-2009 09:41 AM
Built Motor Compression Question davidsti1 Built Motor Discussion 9 07-23-2009 09:33 PM
Built Motors, Oil Coolers, Cams, Exhaust and Headers, Helix, Perrin and much more! Gruppe-S Engine/Power/Exhaust 21 03-13-2006 05:01 PM
Gruppe-S Built Motor Packages! Alky Injection! Helix and much more! Gruppe-S Engine/Power/Exhaust 26 11-18-2005 05:55 PM
Built Motor Compression test 13secwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 11-10-2005 12:15 PM
