Welcome to the North American Subaru Impreza Owners Club Wednesday June 20, 2018
Old 09-22-2007, 07:52 AM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default gear ratio calculator/solver
ever wonder what the IDEAL gear ratios would be for your setup?
wonder no longer!
input FD ratio, wheel circumference, desired speed and rpm for some arbitrary 4th gear operating point, what your desired shift bracket [1] is, and solve for a nice, evenly-spaced determination of gear ratios from first through fifth. set your two step once and have it match up perfectly on every upshift! stay right on top of your peak power and maximize your acceleration! get the edge on your competition! sleep with the hottest girls that do the naughtiest things! [2]
the spreadsheet will also show you what your "next gear" rpm would be at any given rpm point, as well as show a chart of rpm vs mph for all gears.
already loaded in the spreadsheet is what i personally consider a very attractive hypothetical gearset. use the fields in red typeface to adjust the parameters to your liking.
disclaimer: this spreadsheet will not manufacture, source, distribute, install or pay for your perfect gear ratios.
http://ken-gilbert.com/wrx/gearsolutionsproposed.xls
have fun!
ken
[1] shift bracket in this context is defined as the desired "upshift at" and "fall to" rpm range.
[2] no guarantee that the gear ratio calculator will achieve any aforementioned claim of sexual activity is expressed or implied. use at your own risk. always wear protection. don't drink and drive.
Old 09-22-2007, 08:02 AM   #2
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Very nice!
...and like your the little CYA at the bottom
Rasmusson14 is offline   Reply With Quote
Old 09-23-2007, 12:05 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Ill take a look at thıs and maybe add ıt to my nınja spreadsheet when I can. Im ın an Istanbul ınternet cafe rıght now.
Compression ratio calculating spreadsheet mattwalters Normally Aspirated Powertrain 5 10-13-2012 01:30 PM
Meth ratio calculations. (washer fluid to HEET ratio etc.) DuckStu Water/Methanol Injection, Nitrous & Intercooler Cooling 18 06-10-2010 01:43 PM
Manual Trans 4.11 gear ratio sleepysubie RMIC Private Classifieds 0 06-03-2010 10:26 PM
Need gear ratio / speed calculator t_c General Community 3 03-16-2009 03:23 AM
Meth ratio calculations. (washer fluid to HEET ratio etc.) DuckStu Water/Methanol Injection, Nitrous & Intercooler Cooling 2 03-01-2008 07:31 PM
