Welcome to the North American Subaru Impreza Owners Club Saturday April 19, 2025
Old 09-28-2007, 01:57 AM   #1
z
Member#: 41762
04 STi
in ur Floriduh
Default axle question - spline count
Need a little info please...
I'm looking to source some new CV parts for my 2004 STi axles. I have the earlier female inner CV - DOJ87. The DOJ (double offset joint) with inner race, ball and cage design is a lot stronger than a tripod joint that one might find in an aftermarket "compatible axle"
If you have the following info for 2004 STi, that would be awesome!
Feel free to post other years wrx/sti info here too so we can figure out compatibility between years. ie it may be possible for wrx and 04 sti to switch to 5 x 114.3 simply by swapping the outer CV and hubs/discs instead of replacing the whole axle assembly.
I found a company that can supply the assemblies except I need a spline count. It should be around $30-$40 or so for each joint, which would make the cost of replacing a failed axle the same price or cheaper than replacing with an inferior aftermarket axle or "remanufactured" which involves grinding out the race and installing larger balls, making the race inherently weaker.
If someone has upgraded their axle bars to DSS axles and have their old axle bar hanging around, if you could count the splines. DSS's site says it varies from different year STis.
So onto the necessary info-
1. spline count to hub - I think may be 27 if someone could confirm
2. " axle bar into outer CV
3. " axle bar into inner CV
4. spline count on diff stub into inner CV - I think may be 25 if someone could confirm (or on male inner CV for later wrx or sti)
thanks in advance!
z is offline   Reply With Quote
Old 09-28-2007, 03:14 PM   #2
z
Member#: 41762
04 STi
in ur Floriduh
come on now...someone has answers!
Old 07-09-2011, 10:02 PM   #3
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
bump i know this is pretty old but i would really like to know this for a project i have going atleast the splines on bars
seanathanq83 is offline   Reply With Quote
Old 07-11-2011, 08:06 PM   #4
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
funny sean, I was just searching this too.. Had issues getting my 05 Axles into my 04 Trans.
Layvon is offline   Reply With Quote
Old 07-11-2011, 09:23 PM   #5
z
Member#: 41762
04 STi
in ur Floriduh
I never did find out the answers. I ended up just buying some used (early) 04 STi axles.
In retrospect, what I thought was a bad cv joint was really a bad wheel bearing though.
It wasn't apparent until I took the axle nut off and got the knuckle out. Then it was obvious that the wheel bearing was shot. (there was no back and forth play in the wheel when it was all bolted up)
Old 07-12-2011, 08:57 PM   #6
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
I'll count when I get home. Im in Iowa till friday but I have 8 axles at home.
(4) 04 STi axles
(2) 05 FRONT STi axles
(2) 06 Rear STi axles. (Should be same as 04s)
Old 11-06-2018, 07:42 PM   #7
Kobura
Member#: 395872
2000 RSTi 2door
Necro for great justice
Investigating what axle-wise is needed to put 5*114 front hubs on a car with an 04sti gearbox
Thankfully the rears are simple.
Kobura is offline   Reply With Quote
Old 01-24-2023, 01:39 AM   #8
Punapple
Member#: 421229
(4) 04 STi axles
Any counts?
Punapple is offline   Reply With Quote
Old 02-01-2023, 02:49 PM   #9
ether947
Member#: 297799
2003 WRX
EJ207 version 8
Originally Posted by Punapple View Post
Any counts?
I have a cv axle table here. It isn't complete as this info is hard to come by.
https://b.obsdian.com/2021/01/15/res...axle-database/
Also, aftermarket axles can have completely different shaft spline counts.
ether947 is offline   Reply With Quote
Axle Spline Count stimpy Transmission (AT/MT) & Driveline 22 07-31-2021 06:09 AM
wrx front drive axle spline count??? tranny mounts! brodie.gordon Transmission (AT/MT) & Driveline 0 08-12-2009 05:59 PM
spline count pilfflip 'Old School' Subaru Forum 2 11-01-2004 11:43 PM
Ring and Pinion and Spline Count RockRaceScooby Transmission (AT/MT) & Driveline 0 03-29-2004 11:29 AM
Axle spline count RedBrighton96 Transmission (AT/MT) & Driveline 4 10-25-2002 05:03 PM
