Welcome to the North American Subaru Impreza Owners Club Monday January 16, 2017
Old 10-03-2007, 06:51 PM   #1
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Default Ej207 valvecover gaskets???
Can you use USDM valvecover gaskets with these? If so, the ej205 gasket or ej255/7 gaskets
wrxwhat is offline   Reply With Quote
Old 10-03-2007, 07:03 PM   #2
ovedrivex
Member#: 116774
1997 Project GC8
ej207 and ej257 share the same heads so the the valve cover gasket for the sti stould work. ej255 doesnt have avcs
ovedrivex is offline   Reply With Quote
Old 10-03-2007, 07:11 PM   #3
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
awesome, thanks so much!
Old 10-04-2007, 12:50 AM   #4
norexyet
Member#: 39149
11 elantra
yea i said elantra
I am pretty sure you need 207 valvecover gaskets. I don't think the 205/255/257 will work.
norexyet is offline   Reply With Quote
Old 10-04-2007, 01:06 PM   #5
Member#: 106514
The EJ207 valve cover gaskets are much different.
The EJ207 and EJ257 heads are not much alike.
- Different combustion chambers
- Different ports
- Different cam cap design
- Different valve covers
- Different valve cover gaskets
- Different cam position sensors
- J.
Jeremy@Cobb is offline   Reply With Quote
Old 10-04-2007, 01:34 PM   #6
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
So... do I need EJ207 Gaskets or is there any USDM substitute that I could use?
Old 10-04-2007, 06:24 PM   #7
nicad
Member#: 33971
2006 WRX
fujibond
nicad is offline   Reply With Quote
Old 10-04-2007, 08:59 PM   #8
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
You can get some through Rallispec.
MJU1983 is offline   Reply With Quote
Old 10-06-2007, 05:36 PM   #9
mikaust
Member#: 7468
2008 Outback Limited
What he said.^ damn expensive.
mikaust is offline   Reply With Quote
Old 10-06-2007, 10:56 PM   #10
norexyet
Member#: 39149
11 elantra
yea i said elantra
yup. they usually have them. Dave is a good guy.
Old 10-06-2007, 11:59 PM   #11
testes1010
Member#: 47145
2012 Gas Saver
Rallispec or IAPerformance
as [email protected] said, they are completely different than EJ257 or EJ205 heads in all ways that matter.
testes1010 is offline   Reply With Quote
Old 10-07-2007, 05:13 AM   #12
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Just used Fujibond =)
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
bad valvecover gasket moonzie Baja Forum 1 01-27-2010 12:51 PM
ej207 head gasket set edro* Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-29-2009 03:51 PM
ej207 head gaskets? eclip5e Built Motor Discussion 0 08-27-2007 02:07 PM
Hesitation:Think it's a valvecover gasket problem RacerinLSL Normally Aspirated Powertrain 5 04-23-2001 08:24 PM
