Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 10-27-2007, 10:48 PM   #1
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Cosworth, TSR70, MZM Tune
Subaru Stars Pics of the "Silver Sleeper" STi
These are up to date pictures of the "Silver Sleeper" (as it was called in D-Sport magazine) - the ones in D-Sport magazine were almost a year old.
Instead of using my own camera, I borrowed a much better one. As these pics prove, I suck at photography and it has never been the camera's fault.
This is the car in the exact same state it was in when it ran the 10.5 second quarter mile pass. I drove to the track, made the passes, and drove it home.
The car is a 2004 STi with just a "few" changes.
The [email protected] thread: Click Me
The 540whp thread: Click Me
The Cosworth/APS TSR70 build thread: Click Me
The console swap thread: Click Me
The suspension thread: Click Me
Dasani is offline   Reply With Quote
Old 10-27-2007, 10:48 PM   #2
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Complete Modifcation List
Engine
- Accurate Machine Works Oil Catch Cans
- APS 3.5in Turbo Back Exhaust
- APS 80mm Cold Air Intake
- APS Billet Aluminum WRX Fuel Rails
- APS Braided Stainless Steel Fuel Rail Lines
- APS Braided Stainless Steel Power Steering Lines
- APS DR725 Front Mount Intercooler
- APS Dual Vent Bypass Valve
- APS Split Pulse Header
- APS Split Pulse Header Exhaust Shields
- APS TSR70 Turbo
- Cosworth 274 Exhaust Camshafts
- Cosworth 278 Intake Camshafts
- Cosworth Big Valve Cylinder Heads
- Cosworth Billet Crankshaft
- Cosworth Billet Timing Belt Guide
- Cosworth Connecting Rod Bearings
- Cosworth Cylinder Head Studs
- Cosworth Forged Pistons
- Cosworth H-Beam Connecting Rods
- Cosworth Main Bearings
- Cosworth Oil Pump
- Cosworth Piston Rings
- Crucial Racing 160 Degree Thermostat
- Crucial Racing Ported Stock Throttle Body
- Crucial Racing Radiator Caps
- Custom Automatic Intercooler Sprayer
- Custom Harmonic Damper
- Denso IKH24 Spark Plugs
- HKS 1000cc Fuel Injectors
- HKS A/F Knock Amp
- HKS F-Con V Pro Engine Management
- HKS Twin Power DLI Ignition Amplifier
- JDM WRX Tumble Generator Valve Deletes
- Koyo Aluminum Radiator
- MZM Performance Braided Stainless Steel Fuel Lines
- MZM Performance Braided Stainless Steel Wastegate Lines
- MZM Performance Brake Line Heatshields
- MZM Performance HKS F-Con V Pro Tune
- MZM Performance Ecutek Reflash
- MZM Performance Fuel Pump
- MZM Performance Turbo Blanket
- Samco Silicone Radiator Hoses
- Sard Adjustable Fuel Pressure Regulator
- STi Kevlar Timing Belt
- System One Fuel Filter
- Tial 44mm Wastegate
- Thermotec Intercooler Piping Heatshield
Drivetrain
- ACPT Carbon Fiber Driveshaft
- Carbonetic Carbon Triple Plate Clutch
- Driveshaft Shop Front Axle Shafts
- Driveshaft Shop Level 5 Rear Axles/Hubs/CV Joints
- Kartboy Front Shifter Stay Bushing
- Kartboy Rear Shifter Stay Bushing
- Kartboy Shifter Lever
- Kartboy Transmission Crossmember Bushings
- SPT Short Shifter Mechanism
- Turn In Concepts Shifter Linkage Bushings
- Turn In Concepts Shifter Pivot Bushings
Chassis
- Cusco Motor Mounts
- Cusco Rear Subframe Brace
- Cusco Transmission Mount
- Happi Motoring Fender Cowl Braces
- Kartboy Billet Aluminum Engine Pitch Mount
- Kartboy Exhaust Hangers
- Kartboy Rear Differential Crossmember Bushings
- STi S204 Front Performance Damper
- STi S204 Rear Performance Damper
- STi JDM Transmission Under Panel
- STi Spec-C Titanium Strut Tower Brace
- Turn In Concepts Rear Differential Bushings
- Whiteline Rear Subframe Locking Bolts
- Whiteline Steering Rack Bushings
Suspension
- Cobb Tubular Front Sway Bar
- Cobb Tubular Rear Sway Bar
- Ohlins 25 Way Adjustable Front Struts
- Ohlins 25 Way Adjustable Rear Struts
- Perrin Front Sway Bar End Links
- Perrin Rear Sway Bar End Links
- Racecomp Engineering Front Camber Plates
- STi JDM Spec-C Front Spring
- STi JDM Spec-C Rear Springs
- STi Group-N Rear Strut Mounts
Brakes
- Goodridge Stainless Steel-Braided Brake Lines
- Hawk HPS Front Pads
- Hawk HPS Rear Pads
- The Brakeman 2 Piece Front Rotors
Interior
- 2004 WRX Black Carpet
- 2004 WRX Katzkin Leather Covered Rear Seats
- 2006 STi Center Console
- 2006 STi Steering Wheel & Air Bag
- 2006 WRX Armrest Extension
- 2006 WRX Limited Leather Door Panels
- 2007 STi Limited HVAC Controls
- Autometer Triple Gauge Glove Box Mount
- Autospeed Billet Dead Pedal
- Bazooka 8in Subwoofer Tubes
- Defi Dash Triple Gauge Mount
- Defi Exhaust Temperature Gauge
- Defi Fuel Pressure Gauge
- Defi Link 2 Gauge Controller
- Defi Oil Pressure Gauge
- Defi Oil Temperature Gauge
- Defi Water Temperature Gauge
- Infinity Kappa Perfect 6.1 Front Speakers
- Infinity Kappa 42.5i Rear Speakers
- Kenwood DDX-7017 Head Unit
- Kenwood KDH-C710 Hard Drive Unit
- Kenwood KNA-DV4100 Navigation Unit
- Recaro Sport Black Leather Front Seats
- Redline Automotive Leather Armrest Extension Cover
- Redline Automotive Leather Emergency Brake Boot
- Redline Automotive Leather Shifter Boot
- Rockford Fosgate Power 851 Amplifier
- Rockford Fosgate Power 1001BD Amplifier
- Solar Gard Window Tint
- STi CDM Black Floor Mats
- STi JDM Automatic Intercooler Sprayer Switch
- STi S204 Hazard Button
- STi S204 Shifter Trim
- STi Spec-C V-Limited Shifter Knob
- Turbosmart e-Boost 2 Boost Controller
- Valentine One Radar Detector
Exterior
- 2005 STi Headlight Housings
- 2005 STi Front Emblem
- 2005 STi Rear Emblem
- 2006 STi Rear Diffuser
- 2006 STi Side Under Panels
- 2007 STi Limited Rear Wing
- 2007 STi Limited Trunk Lid
- Autospeed Billet Front Bumper Trim
- BBS RE 18x8 Diamond Black Wheels
- Car Service Hiro Battle Hawk Carbon Fiber Hood
- Carbign Craft Alternator Shroud
- Clearshield Vinyl Front Bra
- Cusco Stainless Steel Hood Pins
- Gruppe-S Carbon Fiber Radiator Shroud
- GT Spec Carbon Fiber Rear Bumper Heat Shield
- Hella Xenon Blue High Beam Headlight Bulbs
- Kartboy Billet Aluminum Battery Tie Down
- STi S203 Wheel Center Caps
- STi Spec-C V-Limited Front Lip
- STi Spec-C V-Limited Rubber Under Lip
- Trust Aluminum Lug Nuts
- Yokohama Advan Neova 235x40x18 Tires
Old 10-27-2007, 10:52 PM   #3
Calitri-Boost
Member#: 109090
08 IS-F
WFC Mbr # 004
very nice, the interior looks super clean
Calitri-Boost is offline   Reply With Quote
Old 10-27-2007, 10:53 PM   #4
kcook
Member#: 78074
2005 STi
holy crap! that car runs 10s? what exhaust is that
kcook is offline   Reply With Quote
Old 10-27-2007, 10:54 PM   #5
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt sold
saw your car in the mag, really liked what you did with it. must be fun having 500 plus hp at a blip of the foot.
David Glasscock is offline   Reply With Quote
Old 10-27-2007, 10:54 PM   #6
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
thats the aps 3.5 it sounds the BEST imo, did you run that pass on the neovas?
scby rex is offline   Reply With Quote
Old 10-27-2007, 10:56 PM   #7
Spooky
Member#: 58864
wow...evo 9 seats/love the wheels/love the STi limited trunk spoiler..all FTMFW!
Spooky is offline   Reply With Quote
Old 10-27-2007, 10:57 PM   #8
dv04
Member#: 140622
2015 WRX
clean!!
love it!! but i wouldnt exactally call it a sleeper tho.. the loud exhaust and rims.. but its still beautiful!!
dv04 is offline   Reply With Quote
Old 10-27-2007, 11:02 PM   #9
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
the 3.5" isnt loud at all with a header. I have 3" twin tip run right next to a friend witht he 3.5 mine is louder.
Very badass car I love the leather interior
robbieshonda is offline   Reply With Quote
Old 10-27-2007, 11:04 PM   #10
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Yep, it's the APS 3.5" exhaust. I ran it at the track on the Neovas, absolutely no changes to the car other than the fuel and the corresponding ECU map - in full street trim.
-D
Old 10-27-2007, 11:06 PM   #11
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Actually, the seats are made-to-order black leather from Recaro and not from the Evo. I think the Evo seats have fabric inserts. I'm a leather freak myself, so I needed the full leather versions.
-D
Old 10-27-2007, 11:07 PM   #12
lugee
Member#: 86604
08 C6 Corvette Z51
WRX 18G WFC 034 (sold)
what hood is that? Its hot. Btw - I am going a similar route with my WRX.
lugee is offline   Reply With Quote
Old 10-27-2007, 11:09 PM   #13
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Originally Posted by dv04 View Post
clean!!
D-Sport magazine nicknamed it the "Silver Sleeper" (and it was running "only" 11.3 at the time) so it's kind of stuck with the car. Surprisingly, it's not obnoxiously loud with the 3.5" exhaust.
-D
Old 10-27-2007, 11:12 PM   #14
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
The hood is a 'Car Service Hiro Battle Hawk'. As far as I know, only a couple of them exist and they are made to order, but I've been wrong many times before, so don't take that as gospel.
-D
Old 10-27-2007, 11:13 PM   #15
buzz367
Member#: 99226
2005 impreza 2.5 rs
aspen white
that is my new favorite silver car on nasioc
buzz367 is offline   Reply With Quote
Old 10-27-2007, 11:32 PM   #16
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
ibphatronsysitsnotasleeper!
by the way, that is a beautiful car
mrubino83 is offline   Reply With Quote
Old 10-27-2007, 11:37 PM   #17
JBee
Member#: 105076
2002 Tuned by FORZA2
RMK #4
pls tell me those are fujitsubo cbe
JBee is offline   Reply With Quote
Old 10-27-2007, 11:37 PM   #18
rallydriverosix
Member#: 145419
2008 WRX
now with more hatchbackin
amazing STi. best subie on Nasioc
rallydriverosix is offline   Reply With Quote
Old 10-28-2007, 12:00 AM   #19
soji
Member#: 87178
2003 Japanese Spec
Impreza STi
wow love it very clean, the only thing I don't like but don't mind is the shifter and trim thats about it.
soji is offline   Reply With Quote
Old 10-28-2007, 12:04 AM   #20
Spooky
Member#: 58864
-D
ohh....I see the difference now...lol.. I just took a quick glance at the pics..
sleeper nonetheless
Old 10-28-2007, 12:04 AM   #21
dewmudgeon
Member#: 156933
1998 2.5 RS
Acadia Green
bazooka tubes?!
dewmudgeon is offline   Reply With Quote
Old 10-28-2007, 12:10 AM   #22
dpk777
Member#: 97537
2005 Saab 92x Aero
niiice. those seats look comfy!
dpk777 is offline   Reply With Quote
Old 10-28-2007, 12:17 AM   #23
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Originally Posted by dewmudgeon View Post
bazooka tubes?!
Of course. One must have a nice radio when cruising down America's interstates.
There is a very nice multimedia system with a 120GB hard drive hidden from view. The Bazooka's have custom drivers that are hooked up to a 1000 watt Rockford Fosgate amp.
-D
Old 10-28-2007, 12:21 AM   #24
pjloyd
Member#: 160216
1998 Impreza L
Red
damn!..i love the interior..
color gray is hot!..
i don't like the wheels though..
i wonder what color wheel goes great with gray cars!~
pjloyd is offline   Reply With Quote
Old 10-28-2007, 12:22 AM   #25
dewmudgeon
Member#: 156933
1998 2.5 RS
Acadia Green
-D
oh ok, i guess thats not bad, but i just always had the stereotype in my head that a person who buys bazooka tubes gets all the rest of their stuff at walmart.. with you the exception of course
Couple pics of the new(to me) STI RedlineWRX04 Member's Car Gallery 9 09-17-2009 06:27 PM
Pics of the "Silver Sleeper" STi Dasani Texas Impreza Club Forum -- TXIC 42 11-11-2007 08:33 PM
Why hasn't www.subaru.com updated pics of the '06 WRX/STI? thsiao General Community 13 08-13-2005 10:38 AM
Better pics of the SVX w/ STi wheels. Bwana Member's Car Gallery 59 07-04-2005 08:08 AM
anyone have pics of the 02-03 sti scoop compared to the wrx scoop? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-18-2004 04:11 PM
