#1 |
Vendor Sales Rating: (61)
Member#: 25194
RMIC
Vehicle:2008 Forester XT 5mt Dark Gray |
![]() Black Friday Special,
![]() Gearsets: ![]() Our shipment has finally arrived. We have 2 RA Gearsets ready for new homes. Each set is Cryo and Micro Polish Finished. These bad boys are built to withstand ~350-390 whp of raw Subaru power!. Plus, check out the ratios, this is how Subaru should have built the WRX from the factory. If you would like, you can retain your stock 5th gear assembly for highway cruising. More gear set information can be found below in this post. Priced at $1599 shipped 48 (used to be $1450, but we now have added cryo and micro process) Assembled Gearboxes: ![]() Take the guess work out of the install and let one of our Subaru Master Techs build your gearbox for you. Each box comes with new Synchros and Bearing sets installed. Stock 5th gear is also optional for same price. Direct plug and play for Subaru 5 speeds. Please denote model year when ordering. $2650 + $800 refundable core + ship Bearing / Synchros: ![]() We also have Bearing and Syncro sets in stock ready to ship with these at no added shipping charge. Plus these are Subaru factory parts, sold cheaper than your local dealership.
(free Next Day ship on clutch only good with purchase of RA BOX, otherwise you get free ground ship) ![]() Exedy 5 speed stg1- $499 shipped w/ free next day air Exedy 6 speed stg1- $450 shipped w/ free next day air Exedy Twin disc 6 speed- $1599 shipped w/ free next day air ACT 5 speed stg1- $550 shipped w/ free next day air ACT 6 Speed stg1- $569 shipped Short Shifters: Cobb Short Throw Shifters. All apps in stock. ![]() 6 spd- $165 shipped 50 & PR 5 spd- $135 shipped 50 & PR Shifter Bushings and Mounts: Cobb Shifter bushings ![]() 6 spd- $35 5 spd- $30 Subaru Group N lower transmission mounts ![]() 6spd- $79, free shipping 48 states when purchased with any other item 5spd- $79, free shipping 48 states when purchased with any other item Subaru Group N pitch mounts (5spd and 6spd same part) ![]() 5spd and 6spd- $39.99, free shipping 48 states when purchased with any other item STI Type RA Gearsets 02+ WRX Close ratio gears from the STi RA feature strengthened and hardened components for improved reliability of the 5MT in modified Imprezas. Treated gearsets now feature optional cryo w/ micro-polishing for improved reliability, strength, and reduced frictional losses. Each gearset includes all necessary parts for installation including a custom speedometer gear (specify 3.9, 4.1, or 4.4 final drive ratio when ordering). Non-turbo adapter kit includes additional parts to allow proper fitment of the gearset into non-turbo applications. Professional installation is recommended. Gear Kit Includes STI RA Main Shaft STI RA 1st Driven Gear STI RA 2nd Driven Gear STI RA 3rd Driven Gear STI RA 4th Driven Gear STI RA 3rd/4th Driven Gear Cluster STI RA 5th Drive Gear STI RA 5th Driven Gear 3rd/4th Shift Fork Rod 3rd/4th Synchro Hub Set 4th Gear Thrust Washer Lock Nut, Main Shaft Lock Nut, Pinion Shaft Lock Nut, Driven Shaft Oil Seal, Main Shaft Custom Steel Speedometer Gear, Calibrated for 3.90 Final Drive Case Gasket STi RA ratios: 3.083 (1st), 2.062 (2nd), 1.545 (3rd), 1.151 (4th), 0.825 (5th) Optional Items
All Major CC's and Paypal accepted. Stephen ![]()
FS (moco, MD): PPG1/2 s/c, 3/4 LGT Gearbox, clutch, and lightweight flywheel | GreenLantern | MAIC Private Classifieds | 18 | 03-28-2009 08:04 AM |
WTB: RA Gearset or Gearbox | gling | NESIC Private Classifieds | 7 | 06-10-2007 09:57 AM |
Now on Ebay... ra gears, aem, perrin, zerosports and more | hybrid gti 2 | Private 'For Sale' Classifieds | 38 | 05-25-2006 02:56 AM |
Ver. 6 STI RA gearsets in stock! ACT and Exedy Clutch combos! | Gruppe-S | Drivetrain | 11 | 02-09-2006 03:39 PM |
CA: New Exedy Sport Clutch and more | grantn | Private 'For Sale' Classifieds | 0 | 07-22-2004 06:09 PM |
