Welcome to the North American Subaru Impreza Owners Club Friday April 16, 2021
Old 11-30-2007, 04:23 PM   #1
jobber
Member#: 164043
2015 WRX and FozzyXT
Default Tranny/Rear end fluid change on 2005 WRX, with pics
This is the T70 socket you need for most of 2005-up. Maybe mid-2004 and up? I just put in T70 on Amazon and bought 2 of these, 1 for backup.
This is what the tranny dipstick looks like. I had to remove nothing to get to it. Mainly because of this killer funnel I got at Kragens.
My oil choice, there are enough oil debate threads, dont make this one of them. I'm old school and used plain old oil. I been modding my cars for at least 15 years, using synthetic sometimes. This time, I chose regular oil.
UPDATE: This oil is terrible in my tranny. All gears got way worse. I will be changing it out soon for the cocktail.
Pic of the drain plug still in:
Popped the drain plug off and let it drain until it was a very slow drip/stopped.
The tranny drain plug and its magnet. This pic shows the amount of metal buildup I had on my magnet:
For comparison, the cleaned up drain plug:
The T70 bolt itself:
With drain plug torqued properly, the fill starts. I found some posts saying 32.5 ft. lb, and some posts showing 50 ft lbs. I used 40 ft lb or so until I find a proper 2005 manual. The flexible funnel shows how easy it is to fill.
jobber is offline   Reply With Quote
Old 11-30-2007, 04:24 PM   #2
jobber
Member#: 164043
I used 3 quarts exactly...
to reach this almost perfect dipstick..
I added MAYBE 1/4 of a quart more after that, which got it just where I wanted it. So 3.25 quarts for me.
BONUS PICS - REAR END FLUID JOB
You dont have any leverage room to get the 2 rear end plugs out with car on ground. I simply put my floor jack under the big 1/2" drive rachet and it broke them loose with 2 pumps. I could get them plenty tight when I reinstalled.
Pic of the amount of metal on my rear end drain plug:
After cleaning, for comparison:
The location of the two bolts, very easy. I didnt jack up the car at all:
Don't mix up the rear end plugs. They look the same before you take them out:
The magnet plug goes in the bottom hole obviously:
Filling was not too big a deal. I first tried the bottles by themselves, but couldn't get the proper angle. I took a foot of my silicone hose and it was golden. The hose can even angle down, as long as the bottle is aimed down for pressure.
I used that 3/4+ quart or so bottle in the rear end, right as fluid started draining out the fill hole indicating it was full. I used hi-tack red gasket liquid on the threads instead of teflon tape. I doubt it would even leak bare, but it was added insurance.
Conclusion:
My tranny fluid was dirty and my rear end fluid was much worse. I am glad I got these both changed for my own piece of mine. I got this car less than a month ago with 57,000 miles on it.
Old 11-30-2007, 04:55 PM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Great write-up and the pics are great. Kudos
Hank3 is offline   Reply With Quote
Old 12-03-2007, 04:30 PM   #4
_JsWRX
Member#: 119117
06 wrx sgm
SGM
for the bolts that you took out, do you have to replace the washers ?
_JsWRX is offline   Reply With Quote
Old 12-03-2007, 04:51 PM   #5
jobber
Member#: 164043
only the drain plug had a washer and i didnt replace it. it was a non-crushing copper gasket and was fine.
Old 12-03-2007, 05:06 PM   #6
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
If you want to go by the book...
The rear diff plugs use Three Bond 1105. It's a liquid gasket/sealant. PN 004403010.
As jobber mentioned, the tranny washer/gasket is non-crushing and I've had no problems re-using it. PN 803926070.
FD777 is offline   Reply With Quote
Old 12-03-2007, 05:09 PM   #7
bzbuzz
Member#: 116052
2011 STI ( Sold )
nice write up!!!!!
but then how did you remove the dipstick w/ intercooler off....?
I tried to take it out..but then I coudnt do it....
bzbuzz is offline   Reply With Quote
Old 12-03-2007, 09:38 PM   #8
jobber
Member#: 164043
Originally Posted by bzbuzz View Post
nice write up!!!!!
06's must be different than 05's..
Old 12-04-2007, 07:46 AM   #9
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
From the 2005 Impreza service manual:
Tranny drain plug: replace the gasket/washer and the tightening torque is 51.6 ft/lbs.
*this is for the 5MT NOT the 6MT (STi)
Rear Diff.: use liquid gasket on drain plug and filler plug and tighten to 36.2 ft/lbs.
conker69 is offline   Reply With Quote
Old 12-04-2007, 05:26 PM   #10
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Great write-up!
I did the change at 3k miles and reused the copper gasket on trans and did-not use sealant on rear-end plugs. Thus far I have no leaks.
Respectfully, if you are going to change the rear-end fluid, it is advisable to see if you can first remove the top/fill plug. Why? Because if you can't get it off, but you were able to remove the bottom/drain plug, and you drain the fluid out, then how do you refill it?
On the 2006 WRX you can remove the trans dip-stick w/o removing the I/C. It becomes a bit more cramped if you installed the turbo heat-shield, but it can be removed none-the-less.
The 2006 WRX takes 3.7qts in the trans and 0.8qts in the rear diff.
Jobber, did you change out the fluid yet?
How important is it to use the sealant on the rear diff plugs (if I have no leaks)?
I'm using the Valvoline Super-Syn w/o any problems, but again I have a 2006.
What TMIC do you have?
Thanks.
Old 12-04-2007, 06:54 PM   #11
jobber
Member#: 164043
Thanks.
I changed it using the above oil. Now I will be changing it again in 2-3 days to the cocktail. Sealant on diff plugs isnt important at all, unless your leaking. Those plugs rarely leak when tightend properly. I have the stock 2005 TMIC.
Old 12-06-2007, 11:03 AM   #12
CGM6
Member#: 146911
ahhh nice write-up!
CGM6 is offline   Reply With Quote
Old 12-06-2007, 12:07 PM   #13
jobber
Member#: 164043
I just got done draining this crappy oil. Will be putting in my cocktail in the next 30 mins. It's a stress free job, very easy.
Old 12-06-2007, 12:47 PM   #14
jobber
Member#: 164043
Finished the cocktail install. The Redline is the thickest. The synchromesh is the thinnest. The Castrol Hypol was in between. Can't wait to get it all mixed up next time I drive.
Old 12-08-2007, 01:06 PM   #15
bzbuzz
Member#: 116052
2011 STI ( Sold )
why not "F" level tho?
Old 12-08-2007, 01:14 PM   #16
jobber
Member#: 164043
ahh cuz it expands a tad and just to be safe.
Old 12-08-2007, 01:32 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....I have found that these 5MT's like to be a bit 'over', better, than ANY 'under'
Old 12-08-2007, 08:26 PM   #18
bzbuzz
Member#: 116052
2011 STI ( Sold )
+++++1 yeh..i've noticed the same thing...
Old 12-08-2007, 09:34 PM   #19
jobber
Member#: 164043
hmm ill measure it again when i have time.
Old 03-29-2008, 12:36 AM   #20
Roamrex
Member#: 171487
06 WRX Wagon
SGM
Bump for best tranny/rear diff fluid change thread.
Im doing mine next weekend using the same Valvoline 75w90, why pay more for the synthetic stuff when the regular dino works fine.
Roamrex is offline   Reply With Quote
Old 03-29-2008, 01:52 AM   #21
Homerisking
Member#: 79164
2005 WRX
tHe Silver one
wow this is a great write up...better pics than Scoobymods I'm doing this in a few weeks...i'm glad to see taking the intercooler off isn't necessary. I grabbed Redline Lighweight Shockproof for the tranny and the gear oil for the diff off Amazon. I'm going to the dealer and pick up a new trans plug gasket just in case.
*subscribed...great write up
Homerisking is offline   Reply With Quote
Old 03-29-2008, 01:53 AM   #22
jobber
Member#: 164043
thanks. i made this a long time ago.
Old 12-26-2008, 01:59 AM   #23
tryfe
Member#: 169008
2005 WRX
YES; finally some pictures. I'll be doing this pretty soon. Gonna grab some Redline Lightweight Shockproof for the tranny & something thick for the rear.
tryfe is offline   Reply With Quote
Old 01-06-2009, 10:36 PM   #24
BDubWagon
Member#: 197177
2004 wrx
java black pearl
good explanation and pics!
BDubWagon is offline   Reply With Quote
Old 01-07-2009, 11:32 AM   #25
steverx05
Member#: 128269
Flexible funnel ftw, great idea! I'm going to pick one of those up plus a differential socket before I do my 60k fluid change. Great write up.
steverx05 is offline   Reply With Quote
Transmission Fluid Change on 2005 STi alanlcit Service & Maintenance 2 03-23-2010 02:02 AM
Tranny/Rear End Fluid Suggestions? Smalls Transmission (AT/MT) & Driveline 3 03-16-2007 12:14 AM
Tranny/Rear Diff fluid change atmosphere Service & Maintenance 1 08-30-2004 08:10 AM
First Tranny & Rear-end Fluid Change keithja Transmission (AT/MT) & Driveline 2 11-21-2002 04:34 PM
Socket size for a tranny and rear end fluid change/fluid question too keithja Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 11-20-2002 10:52 PM
