Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 12-03-2007, 11:57 AM   #1
Built Industries
Vendor Sales Rating: (24)
Member#: 33839
Default Slowboy Racing Overstock List Sale!
Please send me a PM with pricing questions on the available items. These items will be discounted in order to continue moving our inventory along
ACT- MB1-HDSS x 4 (2100 clutch kit) (in route from ACT right now)
AR1-XTSS x 2 (Acura RSX Extreme Clutch ACT AR1-XTSS)
MB1-XTSS x 4 (ACT 2600 kit MB1-XTSS )
DN3-HDMM (Dodge SRT4 Clutch kit - ACT DN3-HDMM)
SB2-HDSS x 1 (ACT Subaru Impreza 2100 Clutch SB2-HDSS)
HA3-XTSS x 1 (ACT 2600 Prelude 92-02 - HA3-XTSS)
600210 x 2-EVO 4-8 Prolite Flywheel
600175 x 2-WRX Flywheel
600170 x 1-WRX Prolite Flywheel
600155 x 3-89-92 FWD DSM Flywheel
600165 x 2-92-99 MITSU FWD 7 bolt flywheel - 600165
600150 x 7-89-92 ACT awd flywheel 6bolt
600240 x 2-04-05 wrx sti prolite act 600240
AEM 30-1910-AEM Fuel / Ignition
Controller (F/IC) AEM 30-1910
AEM Uego's-2 in stock
30-4300 x 8-19 Channel Serial Gauge -
23-852C x 2-AEM cam Gear (single) for 4g64 AEM 23-852C/R/B
23-802B x 1-99-00 B16 Adj. Cam Gear (single gear) Red. AEM 23-802
30-4350 x 1 -52mm Boost Control Gauge
AEROMOTIVE:
14132-Aeromotive Evo Billet Fuel Rail - AER 14132 ( 7 in stock)
12302-Pro-Series, In-Line Fuel Filter (AN-12) 100 micron stainless steel element
14105-Fuel rail Mitsu 4 cyl
11106-Aeromotive 800 HP Pump
13105-Compact EFI Regulator, Billet, Adjustable, EFI, (1) AN-6 male inlet and return, AER 13105
13109- Aeromotive FPR 13109, AER 13109
12301-Aeromotive 10 Micron Fuel Filter
12304-Aeromotive 100 Micron Fuel Filter
13115-Honda/Acura Billet Adjustable Regulator 2.3 L VTEC engine years 98 - 01,
APEXI- 147-KM01 (2G AWD downpipe)
NEO's-11 in stock
Arias-3420401 x 2-8.7:1 7 bolt/Evo 85.5mm bore arias 3420401
BC-0112 x 17 (Stage 3, EVO 8 cams)
BC-0102 (6 sets) BC CAMSHAFTS - STAGE 3 (Mitsubishi 4G63 Eclipse) - BC-0102
BC-0160 (7 sets)- SRT-4 S&R kit - BC-0160
BC-0103 (3 sets)- BC CAMSHAFTS -288 STAGE 4 (Mitsubishi 4G63 Eclipse) -
BC-0122-Evolution IX 280 Cams
BC 0123-Evolution IX 288 Cams
BEP-Mitsu-SMIC sidemount intercooler
Blitz SBC-1DIII Black 15095 sequential boost controller
Brad Penn Oil
COBB-
513500 (SS turbo heat shield WRX/STI)
511301-Cobb Urethane Exhaust Hanger Subaru Impreza STi 2004-2007
111212 (brake pads, 05-06 Rear Subaru Legacy GT)
213320 x 4 (Shifter bush 02-06 WRX)
213315 x 2 (STI double adj, 6 spd shift)
912240 (WRX Tubular anti sway bar kit-front and rear)
Cosworth:
KK 3806 x 3 (EVO cams)
KK3814-Subaru WRX STI EJ25 (2.5L) Set of four (AVCS Type) North American spec Int."260" deg. 9.6mm lift / Exh. "260" deg. 9.6mm lift
20000909-EVO Head Gasket Bore = 86mm T ~ 1.5mm COS 20000909
20000910-EVO IV-VIII Head Gasket Bore = 86mm T ~ 1.5mm COS 20000910
20000922 x 2-WRX EJ20 Head Gasket Bore = 93mm T ~ 1.1mm each COS 20000922
20000916 x 2-STI Bore= 101mm T ~ 1.1mm each COS 20000916
20000913 x 2-STI Headgasket Bore = 101mm T~ .78 mm each COS 20000913
PR 7851 x 5-High Performance Engine Bearings Nissan SR20 (2.0L) Main Bearing Set- Tri Metal: Race
PR 7852 x 5-High Performance Engine Bearings Nissan SR20 (2.0L) Rod Bearing Set- Tri Metal: Race
SB0006 x 3-High Performance Engine Bearings Subaru WRX/ STI EJ25/EJ20 Main Bearing Set-Tri Metal: Race
PR7428 x 11-High Performance Engine Bearings Mitsubishi Evo 4G63 (2.0L) Rod Bearing Set -Tri Metal: Race
PR7429 x 12-High Performance Engine Bearings Mitsubishi Evo 4G63 (2.0L) Thrust Bearing set
PR7843 x 11-Head Stud Kit Mitsubishi Evo 4G63 (2.0L)
PR7427 x 12-High Performance Engine Bearings Mitsubishi Evo 4G63 (2.0L) Main Bearing Set -Tri Metal: Race
PR7425 x 4-Mitsubishi Evo 4G63 (2.0L) Main Stud Kit
PR7243 x 2-Head Stud Kit Subaru WRX STI EJ25/EJ20 (2.5L) 11mm
PA2667-Forged Piston Sets Subaru WRX STI EJ25 (2.5L) 99.5mm 8.2:1cr Includes pistons, pins and circlips
20000164 x 5-Mitsubishi Evo 4G63 (2.0L) High RPM Valve Spring set (16)
Crower-
84164-Crower 84164 K20A spring and retainer kit
63443Z-Honda D16Z V tec SOHC-1 cam
DEI-lots of all this stuff in stock!!!
DNP-059-MITSUBISHI EVOLUTION IV- IV T4 EXHAUST MANIFOLD UPGRADE w/ 44mm V-Band Flange (Tial 44) - DNP-59
EVO spark plug well covers (we have 27 of these-sell them) (we have 3 that are powder coated HKS purple)
FIC- 175-0625H WRX
FIC 126-1000 EVO
FIC 125-0650 x 9 sets
Fidanza
110661 x 2 (STI flywheel 04 and up)
161731 x 1-Fidanza awd 7 bolt turbo Flywheel
361221 x 2 (Stage 3 street clutch kit)
191681 x 10 (94-01 integra)
191221 x 5 (H22)
861940 (lots in stock, 1g short shifter)
861990 x 6 (2g short shifter)
891940 x 15 (acura integra short shifter)
161691 x 2 -Fidanza awd 6 bolt turbo Flywheel
Full Throttle Maf Translators-
1G- in stock
2G- in stock
Goodridge Brake line kits-
26052 x 3 (EVO 8, 03 and up)
25022 x 6 (89-94 FWD)
26024 x 5 (94-99 non turbo)
26022 x 5
26023 x 8 (89-94 awd, 1g)
Greddy Exhaust- 10136622
Greddy 13500515N-Greddy "Super Light" Oil Catch Tank 15mm - Greddy - 13500515
Greddy RS BOV x 7
Hawk HB367F.585 (95+ Rear brake pads)
HB 352F3665 (front brake pads, WRX)
Holley- 522-6501 x 4 (1 set)- Holley Fuel Injectors Fuel Injector - 65 lbs. - hr. - Low Impedance - 12 V Saturated Circuit Driver - Universal
HKS 2202RM004 x 2 ( 264 4G63 exhaust cams)
HKS Timing belts
HKS Super SQV
Honda turbo Kit PN#1500-96-2000 Civic D 16
INNOVATE:
3730 (3 instock)- 6-ft. long, mini to stripped-and-tinned, matching LM-1 analog output specifications. The cable has (2) Analog Outputs 0-5 volts that are fully programmable with the LM-1 software. - Innovate 3730
3741 (lots in stock)- Serial cable - Innovate 3741
3737 (lots in stock)- Bosch LSU4.2 5-wire, wide-band O2 sensor (replacement LM-1 Sensor) - Innovate 3737
3723 (7 in stock)- LM-1 BASIC KIT - Innovate 3723
3769 (5 in stock)- LC-1 Lambda Cable (Standalone Wideband Controller and Sensor) Innovate 3769
3780 (5 in stock)- Innovate XD-16: (16 in 1 gauge only)
3781 (3 in stock)- Standalone Wideband Guage kit - Innovate - 3781
JE Pistons-
245015-JE Piston .020 For SR20DET
185918-rings included-pn#JG1004-3346 for rings -JE Pistons for Honda B16A1 / B16A2 / B16A3 8.4:1 JE 185918
244871-Nissan SR20 DET Pistons, stock bore JE 244871
K&N-lots and lots in stock!!
RU-3480 (2G- 4")
E2875 (1G)
33-2232 (WRX 02+)
HP-1010 (oil filter)
57-5504 (2G FIPK)
33-2105 (EVO 8)
69-8001TS x 10 (typhoon system )
KOYO-
R 1299 x 3 (3000 GT)
R2704 x 2 (03-06 WRX)
Magnacore-
45423-EVO VIII 8.5mm Magnecor Plug Wires - 45423
45169-8.5mm spark plug wire set 90-94, 2.0 - MAG 45169
45231-8.5mm wire set, eclipse 95-99 NON-Turbo, MAG 45231
45257-8.5mm spark plug wire set, 95-99 TURBO - MAG 45257
49169-10mm spark plug wire set, 90-94
49257-10mm spark plug wire set, 95-99
45164-MAG-45164 Honda Civic 88-91 D15B 1/2/6 or D16A6
Magnus manifolds-
2G 75 mm x 2 in stock
EVO 75 mm
Fuel Rails EVO
Mahle
MIT 130366I23 x 2 sets -
(2.3L 7 Bolt EVO Stroker Piston Mahle Motorsport 85.5mm ( .020 )
SUB209917I22-1 set-Subaru 2.5L TURBO US STI 8.5:1 Pistons 99.5mm Bore std - Mahle SUB209917I22
Mach V 1G sway bar kit-front
Magnaflow 10778-Magnaflow 3" Y pipe dual 2.5" outlet - Magnaflow 10778
Megan Racing:
Cat-Back System, 3" Pipe w/ Tit Tip, 03+ Evo 8, MEG CBS-MLE03 (have 1)
Stainless Steel Downpipe, 3" Pipe, 89-94 Eclipse GSX, MEG MR-SSDP-ME89GSX (we have 10)
Guage Pod- 3 holes A Pillar, 95-99 Eclipse, MEG GP-ME953H
MEG MR-PY-AI9093-Integra 90-93 Silver crank pulley
Motul- Dot 5.1 Brake Fluid
Engine clean
SAE 90
SAE 5W30
SAE 15W50
Fuel system cleaner
Brake cleaner
MITSU-
MD 318150-99 3KGT turbo 6G72 crankshaft MD 318150
MR 224509 manifolds
PE timing belts-2JZ 1201-BT311-
Toyota 2JZ Kevlar Super Strong Timing Belt - Power Enterprise 1201-BT311
PE oil filters, mag power II-OF-04A
Permatex-
Threadlocker
Thread sealant
Ultra grey
Liquid gasket
Hylomar thread sealant
Perrin PSP-ENG-201-black-Perrin Performance Subaru WRX Top Feed Fuel Rails - Perrin PSP-ENG-201-Perrin Performance Subaru WRX Top Feed Fuel Rails - Perrin PSP-ENG-201
Perrin PSP-EXT-050- exhaust header-Perrin Equal Length Header for 02-06+ WRX/STi, & 05+ LGT - Perrin PSP-EXT-050
PowerSlot-
518PSL/PSR-Front 90-99 FWD w/out ABS, 90-99 NT, 88-5/90 ALL, 95-99 2WD, 5/90-92 AWD w/out ABS - PowerSlot 518 PSL & 518 PSR - Pair
RC Engineering-injectors-SRT4 650's x 2, 750's x 1
Redline 75W90
Samco-TCS 299C-MItsubishi Lancer EVO 9 (2) Coolant Only Hose Kit BLACK -
TCS135C-Samco TCS135C-BK Radiator Hoses - Incl. STI, 2.5L - Black-Samco 02-04 WRX collant hoses samco tcs135/c3
SBR Cast Manifolds
SBR FMIC's
1G -14 in stock-Race
2G x 5
SBR Private Label clutch kits-
SBR-4000 x 2
SBR-4500 x 6
Stewart Warner 114379 x 8-Gauge, Boost/Vacuum, 0-25 psi/30 in. Hg, 2 1/16 in., Analog, Mechanical, Black Face - SWG 114379
Tial WG-38 and 44
Tial BOV
TPM 9180-95-02 Civic 2DR EX/Integra LS Front Rotor, Single Rotor - TPM 9180-141
TUR 10763-Turbonetics RAPTOR BOV Kit 17063
TURBOS-
SBR-4753-EVO IX 20G MHI upgrade turbo SBR-4753 TME edition (5 in stock)
PTE PTB-300-5031E-Precision 50 Trim, Stage 3 Wheel, E Cover PTB 300-5031
PTE-PTB 300-6152E-6152E Standard Bearing *Please specify Housings* - PTB 300-6152 (THM3-52 housing)
PTE PTB 400-6077-PTB 400-6077 4" inlet/ 2.5" outlet, THM3.76W housing
PTE PTB 300-6031E-PTE 60-1 with Stage III Turbine Wheel PTB 300-6031E, THF 3.31W housing
PTE 300-6153-PTE 6152RE Dual Ball Bearing Turbo PTB 300-6153
SBR- 4342- WRX/STI 20G 06H turbine wheel w/ 8cm Housing SBR-4342 (2 in stock)
SBR-4312- WRX/STI 20G 06H turbine wheel SBR-4312- no gaskets x 2
SBR-4455-WRX/ STI GT 35R BB Internal WG SBR-4455 (1 in stock)
SBR 4403-WRX/ STI GT13 BB External WG 700177-0013 CHRA (one in stock)
SBR-4452-WRX/ STI GT12 BB Internal WG 700177-0012 CHRA (2 in stock)
Borg Warner-KO4E -53049880015 x 1
EVO III 16 G's x 9
UNO 010930602 and 010940602- (1 set)
2G Alternator Pulley - Silver UNO 010930602
2g Power Steering Pulley, UNO 010940602
VDO-gauges x 4-VDO 30-0-25 psi boost gauge, black face - VDO 150-121
Visteon radiators:
7020-Visteon 2g turbo radiator with SPAL fan and HP cap vis 7020
7022-Visteon 2g Non-Turbo aluminum radiator. Vis 7022
VRS 1G AWD 02 Elim 300 SS DP
VRS 3" 1G alum DP and 3" test pipe alum
Built Industries is offline
Old 02-07-2008, 04:22 AM   #2
Ammata
Member Sales Rating: (9)
Member#: 155819
2004 Impreza WRX
how much for a 20g turbo for a 2004 wrx? i don't know which one choose......i would like one that will give me good streetability and good all around power thanks
Ammata is offline
Old 02-10-2008, 12:57 PM   #3
dropdfocus
Member Sales Rating: (25)
Member#: 89756
1992 Legacy Sport
1997 Impreza L sedan
Do you have any RRFPRs? If so, how much?
dropdfocus is offline
Old 02-10-2008, 03:19 PM   #4
ruggedman
Member Sales Rating: (4)
Member#: 17590
2006 WRX Limited
WR Blue
PM me price of VDO gauge shipped. Thanks!
ruggedman is offline
Old 02-11-2008, 02:16 AM   #5
kaeo_15
Top Scoob 021
Member Sales Rating: (44)
Member#: 115406
On to the next...
Price for evo III 16g and 8cm 20g please...
kaeo_15 is offline
Closed Thread
Slowboy Racing is hiring!! Sales / Techs / Machine Shop Help! Built Industries South East Region Forum 1 02-17-2010 04:39 PM
Slowboy Racing Overstock List Sale! Built Industries Engine/Power/Exhaust 7 11-28-2007 05:40 AM
Slowboy Racing New Website Sale!!! Built Industries Engine/Power/Exhaust 0 03-08-2007 07:46 PM
Slowboy Racing Head Parts Sale!!! Built Industries Engine/Power/Exhaust 0 11-06-2006 03:43 PM
Slowboy Racing Turbo for Sale dlewis Private 'For Sale' Classifieds 5 06-26-2005 02:51 PM
