Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 12-04-2007, 08:19 AM   #1
DeadBolt Enterprises
Vendor
Vendor Sales Rating: (16)
Member#: 34272
2005 STi
Crystal Grey
Default Deadbolt Enterprises - The original Subaru turbo specialists!
Deadbolt Enterprises - Often Imitated, NEVER duplicated! We are STILL the original Subaru turbo specialists, and have the widest range of turbos available for the Subaru vehicles of any vendor out there, as well as the best customer service in the industry.
NEW BUDGET SERIES TURBOS
Our products have never been the least expensive on the market, and we know that. We have recently gotten more and more requests from our customers to carry a budget series turbo that could save some money over our standard models so we have decided to offer these on a limited basis. The turbos below DO NOT INCLUDE ANY OF OUR PORTING OR COATING SERVICES!!! Water cooled models carry the same warranty and free rebuilds services as our Zilla series above, but NON-WATER COOLED MODELS DO NOT COME WITH FREE REBUILDS.
Prices for budget models include only the following accessories: Coolant lines, coolant banjo bolts, coolant banjo seals, oil return line, oil return line gasket, oil return line bolts, standard wastegate actuator. NO PORTING NO COATINGS.
Water Cooled Models (Wet cartridges)
TD05H-18G - $899.00
TD05H-20G - $999.00
TD05H-Super16G - $849.00
TD06H-18G - $1199.00
TD06H-20G - $1299.00
Non-Water Cooled Models (Dry cartridges)
TD05H-16G - $499.00
TD05H-18G - $699.00
TD05H-20G - $799.00
TD06H-18G - $999.00
TD06H-20G - $1099.00
SHIPPING SPECIALS:
These are shipping by UPS ground within the lower 48 states. Shipping outside the lower 48 states or additional insurance will cost extra.
Standard turbochargers-$18.99
Larger Garrett Models (GT40, 42, etc.) - $24.99
STANDARD DEADBOLT TURBOS
TD04 Turbos
REBUILT TD04 $499*
Starting with a good condition core, we will perform a complete teardown, and rebuild including all seals, bushings, retainers, and O-rings.
MONSTER TD04 $599*
This is our original and most popular offering. Get a turbo upgrade without spending a ton of money. Quicker spoolup, much better "roll-on" acceleration, all new internals, we can even ceramic coat them for you!Starting with a good condition core, we will perform a complete teardown, and rebuild including all seals, bushings, retainers, and O-rings. After the rebuild we perform our now-famous Monster Port(TM) procedure.
Monster TD04 with upgraded compressor wheel - $799.00*
Same Monster TD04 as above, but with a larger, higher-volume compressor wheel and clipped turbine wheel for better midrange AND top end power. Nice turbo for folks running in race classes that require a "stock appearing turbocharger."
TD05H-16G Turbos
We were the first vendor in the US to market these on a large level, and still sell a TON of them all over the world! This turbo was originally never offered on the USDM WRX, or the later JDM versions as the compressor housing is not correct fitment for these models. We modify the inlet so that they fit perfectly on the USDM cars.
We include the metal coolant lines, banjo bolts, banjo seals, oil return with gasket, and stainless steel downpipe studs at this price unlike some other vendors! $799.00*
MONSTER TD05H-16G! Special Order - Same unit as above, except that we perform our famous Monster Port(TM) on the turbine housing providing even quicker spoolup, better midrange, and enhanced top end.
$949.00*
ZILLA SERIES TURBOS!
Remember, unlike some other companies our ZILLA series INCLUDES Installed Coolant supply lines, banjo bolts, AND Oil return line AND downpipe studs! (Over $150 for all necessary parts if purchased separately from that other vendor)
The ZILLA(TM) lineup will include our famous Monster Port(TM) Service, Port Matching to downpipe gasket, Wastegate porting, and turbine housing inlet smoothing. TD06 and Fat-boy models also include port matching of turbine inlet to gasket.
Coatings Included are Black Xtreme(TM) on exhaust housing, and Grey ceramic on compressor housing.
This is a LOT of turbo for the money!
WATER COOLED MODELS
Water cooled models include coolant supply lines, coolant supply banjo bolts, banjo seals, oil return line with gasket and bolts, and stainless downpipe studs.
18G Oil and Water Cooled TD06H turbine - $1445.00*
20G Oil and Water Cooled TD06H turbine - $1545.00*
Super16G Oil & Water TD06H turbine $1345.00*
18G Oil and Water Cooled TD05H turbine - $1295.00*
20G Oil and Water Cooled TD05H turbine - $1395.00*
Super16G Oil & Water TD05H turbine $1195.00*
3 inch inlet models of the 20G available at no additional cost, but require the use of Tumble Generator Valve deletes and 3 inch inlet tube.
All prices quoted above are for internal wastegate setups. We can weld the wastegate closed on the turbo for use with the TIAL brand of wastegates we sell below.
As always, email [email protected] or PM us with any questions.
SUPERZILLA!!!
SuperZilla turbos are available with internal or external gate, water cooled, or by special request, non-water cooled (dry)cartridges.
SZ55 19PSI-pump / 26 PSI C16
SZ49-55 are available with a 3 inch or standard inlet. 3 inch inlet models require TGV deletes and a 3 inch inlet pipe.
Limited time special pricing!
SuperZilla SZ49 oil and water cooled internally gated* - $1595.00
SZ55 oil and water cooled Fat-boy IWG configuration* - $1895.00
SZ60 oil and water cooled Fat-boy EWG configuration* - $1945.00
SZ65 oil and water cooled Fat-boy EWG configuration* - $1945.00
*-Prices do not include shippnig costs.
NEWLY RELEASED AND READY TO SCARE YOUR NEIGHBORS!
MEGAZILLA MZ72
Our newest monster, the Megazilla MZ72 features our gigantic Tsunami 555 turbine wheel, and a truly gargantuan 72 lb/min compressor wheel. This is the largest stock location turbo in the world. IT IS NOT BOLT-ON!!! Tumble Generator Valve Deletes MUST be used and a 3 inch inlet pipe. This turbo is available in very limited quantities, and is special order only. $2195.00 + shipping.
Don't forget! We are also a Thermotec warehouse distributor so we sell all the Thermotec goodies at the best prices!
We also carry Tial brand blow-off-valves, wastegates, etc.
DeadBolt Enterprises is offline
Old 12-05-2007, 08:25 AM   #2
Vendor
Member#: 34272
2005 STi
Crystal Grey
Upsy Daisy!
Old 12-06-2007, 08:07 AM   #3
Vendor
Member#: 34272
2005 STi
Crystal Grey
We received a VF39 yesterday with no info, anybody here?
Old 12-06-2007, 09:14 PM   #4
555
Member#: 20161
1998 Impreza ST
555
I have received a GT35R yesterday while I was expecting a GT35/4088 hybrid. Please check your P.M Jerry.
555 is offline
Old 12-06-2007, 09:52 PM   #5
Str8Gone
Member Sales Rating: (37)
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
Whats the best price you can give me on a Zilla TD05 18g?
Str8Gone is offline
Old 12-07-2007, 08:28 AM   #6
Vendor
Member#: 34272
2005 STi
Crystal Grey
Checked and replied.
Old 12-07-2007, 08:29 AM   #7
Vendor
Member#: 34272
2005 STi
Crystal Grey
Sending PM Now
Old 12-10-2007, 08:48 AM   #8
Vendor
Member#: 34272
2005 STi
Crystal Grey
Happy Monday everyone! Looks like we got a huge load of turbos for work on Friday afternoon. If you have a delivery, give us a couple of hours to sort through to make sure yours is here.
Old 12-11-2007, 08:15 AM   #9
Vendor
Member#: 34272
2005 STi
Crystal Grey
OK got all the turbos sorted through, all emails, PM's and phone messages returned. Thanks for the patience!
Old 12-12-2007, 11:46 AM   #10
kidrage
Member Sales Rating: (23)
Member#: 134880
2005 WRX
Bump for the best customer service I have gotten all year. Thanks Jerry!
kidrage is offline
Old 12-12-2007, 04:22 PM   #11
Vendor
Member#: 34272
2005 STi
Crystal Grey
Thanks for the kind words and for the bump!
Old 12-12-2007, 04:26 PM   #12
sjrexwagon02
Member#: 141896
2002 STi Wagon
Sedona Red Pearl
hi im looking for a price for teh SuPeRzIlLa sz49 externally gate and ceramic coated on the hot and cold side(s)
sjrexwagon02 is offline
Old 12-14-2007, 08:38 AM   #13
Vendor
Member#: 34272
2005 STi
Crystal Grey
You have PM!
Old 12-14-2007, 11:33 PM   #14
wuuusaa
Member Sales Rating: (20)
Member#: 92894
2015 Wrx
newb question but please tell me differences between wet and dry cartidges please?
im assuming one is oil and the other is water cooled correct? need more clarification
wuuusaa is offline
Old 12-17-2007, 08:02 AM   #15
Vendor
Member#: 34272
2005 STi
Crystal Grey
Wet cartridges are water cooled, like the factory turbo on the Subaru. These run at lower cartridge temperatures, and tend to have longer life.
Dry cartridges do not have water passages cast into them like the wet cartridges, and therefore do not have engine coolant passing through them. They run at higher cartridge temps, and tend to have shorter lifespans.
Old 12-18-2007, 09:02 AM   #16
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Do you have any twin scroll turbos? And can you make a standard turbo into a twin scroll? I'm thinking of running a JDM V7 sb with V8 heads and if there was a way to get a 20G twin scroll that would be sweet. Just curious.
breathinez is offline
Old 12-18-2007, 09:42 AM   #17
wuuusaa
Member#: 92894
2015 Wrx
What kind of life span? I don't see why if you have a turbo timer letting the turbo cool down etc it should last as long.
thanks
wuuusaa is offline
Old 12-19-2007, 08:12 AM   #18
Vendor
Member#: 34272
2005 STi
Crystal Grey
Unfortunately we have no Subaru twinscrolls. I am sorry. There is no way to make a Mitsubishi into a Twinscroll.
Old 12-19-2007, 08:13 AM   #19
Vendor
Member#: 34272
2005 STi
Crystal Grey
thanks
Well, even with turbo timing, the actual cartridge temperature is higher, so it is taking more of a toll on the oil, and also has a lower coaking threshold (coaking is oil hardening/crystalization). From the testing we did about 3 years ago there was a 25% difference in lifespan and wear.
Old 12-19-2007, 02:19 PM   #20
TurbojonLS
Member Sales Rating: (54)
Member#: 38772
2 Cars, No Bling
Are you guys open and working next week?
TurbojonLS is offline
Old 12-19-2007, 09:44 PM   #21
WReXd
Member Sales Rating: (67)
Member#: 114101
93 Impreza L Swap
Is it possible to order just the CHRA of a TD05H-18g? If so, can you still provide free rebuilds for life? I already have a wastegate actuator, compressor and turbine housings from an ej5-40t, but I suspect the center housing is cracked.
WReXd is offline
Old 12-28-2007, 10:45 AM   #22
nito822
Member Sales Rating: (1)
Member#: 50490
07 097/800 UGM STI
Dirty
Is the Zilla 20G TD06H guaranteed not to creep on an STI with a catless 3" TBE?
nito822 is offline
Old 01-01-2008, 01:49 PM   #23
Unabomber
👏 Big Ron 👏
Member Sales Rating: (11)
Member#: 18062
on car parts so PM
me b4 j00 buy
Howdy from Crete!
Unabomber is offline
Old 01-09-2008, 10:47 AM   #24
infantsam
Member Sales Rating: (16)
Member#: 51280
2015 WRB WRX
KNSBrakes
oooops
infantsam is offline
Old 01-10-2008, 12:22 PM   #25
Vendor
Member#: 34272
2005 STi
Crystal Grey
Sorry for the slow reply. After we reopened from the holidays we discovered that we had gotten locked out of the site.
We do offer TD05H-18G center sections only without a turbo assembly, availalbe in water cooled or non-water-cooled models.
We only offer the free rebuilds on full turbos, not on turbo parts, I am sorry.
Closed Thread
Free turbo or machine work from Deadbolt Enterprises!!! DeadBolt Enterprises Vendor 'For Sale' Classifieds 157 11-12-2003 07:57 PM
The best Subaru turbo ever Matt South East Region Forum 6 04-18-2003 12:03 PM
Missing precats in the new Subaru turbo engines Jon [in CT] News & Rumors 56 04-13-2003 02:40 PM
('93-'01) The Original Subaru REX Jon [in CT] Impreza Forum 16 07-05-2001 08:31 PM
