01-22-2008, 07:32 PM | #1 |
Member#: 151996
Red Line 5W40 or 10W30
Which one would be a better choice for Houston, TX weather?
01-22-2008, 08:54 PM | #2 |
Member#: 157247
RMIC
Vehicle:1991 Legacy L+AWD BJ White |
I would say 10W-30 if it is an older Subie and 5W-30 on a newer one.
01-22-2008, 08:56 PM | #3 |
Member#: 70459
TXIC
Vehicle:2002 AW Bugeye ej257 6spd, GT3076R, Alky & EWG |
10w30
01-22-2008, 09:13 PM | #4 |
Member#: 141347
SCIC
Vehicle:2005 WRX WRB |
Well the weather changes in Houston right? If you drive hard, use 5w40 year round. If not, run a Xw30 in the winter and Xw40 in the Summer. Check your oil often.
01-22-2008, 09:21 PM | #5 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
Yep, it depends on your application (car, driving conditions, mods, etc). Generally, thinner is actually ok with Redline. Their 5W20 has a higher High Temp High Shear than a lot of Energy Conserving 5 and 10W30's. Redline does not have a 5W40. http://www.redlineoil.com/pdf/4.pdf
-Dennis |
01-22-2008, 10:14 PM | #6 | |||
Member#: 151996
http://www.redlineoil.com/products_m...=3&subCategory It's towards the very bottom: Quote:
any help bluesubie? |
01-22-2008, 10:22 PM | #7 |
Member#: 41070
Vehicle:2005 Black Tiger (Black Turbo Baja) |
You're wasting money running their 5W40 on a reasonably stock motor. 10W30 is more than adequate.
01-22-2008, 11:27 PM | #8 |
Member#: 141347
SCIC
Not necessarily. If he drives very conservatively, then yes maybe. But for hard driving in hot climates a "energy conserving" Xw30 is something I would avoid. |
01-23-2008, 09:35 AM | #9 |
Member#: 767
Thank you, Ramo. VII's are Viscosity Index Improvers. It's what's used in an oil to give it a wider grade range. They're the first part of an oil to break down and the better oils use little or no VII's. http://www.bobistheoilguy.com/oilshear.htm
skydes - That's why Redline is like magic. Redline's xW30's are as thin as Energy Conserving oils at 100C, but their high High Temp High Shear numbers are much better than an EC oil. Their xW30's have an HTHS of 3.8. GC is ~3.6. EC oils have to be 3.5 or less and most are 2.9-3.2. -Dennis |
01-23-2008, 01:38 PM | #10 |
Member#: 141347
SCIC
That's interesting. I ran Redline last oil interval (10w40), I just did not want to pay $7+ a quart and drive 10 miles out of my way to get it again.
01-23-2008, 02:09 PM | #11 |
Member#: 767
Oh, I just realized the chart from bitog that Ramo posted (created by AndyH, STI owner) shows a lot of HTHS values.
-Dennis |
01-23-2008, 02:14 PM | #12 |
Member#: 151996
Do you think rl 5w40 will be too much for houston? i have an 06 sti that's stock and drive hard when pulling onto the freeway from the on ramp
01-23-2008, 08:11 PM | #13 |
Member#: 141347
SCIC
^^^That is the extent of your "hard" driving? Nothing else? No weekend excursions to a twisty road or autocross?
Save your money, and just run a cheap synthetic like Penzoil Platinum 5 or 10w30 in the winter and GC 0w30 in the summer. Or you don't have to run a synthetic at all really, just run a quality dino oil like Havoline in Xw50 and you should be fine. Make sure to check your oil often. |
01-23-2008, 09:27 PM | #14 |
Member#: 41070
No, even if he drives hard in a place much hotter than Houston. We're both speaking in generalities, and only a properly-read UOA can tell more specifically, but speaking from experience with a modded turbo SAAB in the deserts of southern Arizona on RL 10W30 and according to the UOAs, RL 10W30 is more than adequate and their 5W40 will waste his money.
01-23-2008, 09:52 PM | #15 | |
Member#: 90879
TXIC
01-23-2008, 10:01 PM | #16 |
Member#: 141347
SCIC
^^^I think he is probably relating to the fact that you might get a bit better gas mileage with 10w30 versus 5w40.
01-23-2008, 10:27 PM | #17 |
Member#: 41070
Correct-o.
As an aside, mpg often (normally) correlates better to HTHS viscosity than to kinematic viscosity @ 100C (212F) Last edited by bulwnkl; 01-23-2008 at 10:33 PM. |
2qts. Red Line 75w90(NOT NS) + 1qt. Red Line Heavyduty Shockproof in 5MT WRX = ??? | mcdrama | Service & Maintenance | 23 | 03-05-2007 07:30 PM |
5W-30 or 10W30? | JoeBloggz23 | New England Impreza Club Forum -- NESIC | 4 | 05-28-2002 04:27 PM |
5w30 or 10w30??? | db97 | Service & Maintenance | 14 | 10-23-2001 03:30 PM |
('93-'01) 7000 or 7500 red line? | chuglobal | Impreza Forum | 10 | 10-20-2001 01:09 AM |
5W30 or 10W30? | IBO | Newbies & FAQs | 35 | 08-28-2001 07:56 AM |
