Welcome to the North American Subaru Impreza Owners Club Monday April 23, 2018
Old 01-23-2008, 05:23 PM   #1
All4thaN0okie
Member#: 103037
2006 VF43'd WRX TR
Surgeline Tuned
Default Speakers not working in cold weather
I have found that in the mornings when its really cold out (under 30 degrees) the woofers on my components do not work. The tweeters work, and the sub works, but the woofers do not. Eventually, as the car warms up after 15-20 minutes of driving each speaker will crackle and then begin to work. The speakers are Diamond Audio Hex components, crossovers are in the kick panels, and the speakers are in the normal front door locations.
Has anyone had this happen before? How would you fix this?
Thanks,
John
Edit: I also wanted to add that the amplifier is in the trunk, attached to the back of the seats.
All4thaN0okie is offline   Reply With Quote
Old 01-24-2008, 07:50 AM   #2
mmetalmilitiaa
Member#: 160878
06 sti
sgm
This used to happen to me in my jeep... I'm pretty sure the woofers just operate best when they're not frozen.
mmetalmilitiaa is offline   Reply With Quote
Old 01-24-2008, 10:09 AM   #3
Squishy
Member#: 128530
2013 BRZ
Damn that blows my hope for superconductivity of speaker magnets at super freezing temps to get SUPER BASS.
Squishy is offline   Reply With Quote
Old 01-24-2008, 10:28 AM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
It's a long shot, but it sounds like something is lose, something that contracts (being tempature dependant) and loses contact... I've seen this on circuit boards in the past, but it wasn't so much from a contact but from an IC chip... I would hit it with freeze spray and it would work, as soon as it warmed up it would fail... I know it's the oppisite of your problem, but it was the inverse of it.
I would look at the component crossovers really close, at the solder joints, if you can. To see if there are any "rings" around the various components wires at the solder joint... these "rings" I speak of, would indicate bad solder...
Old 01-24-2008, 10:59 AM   #5
biketx2812
Member#: 142337
2004 WRX Wagon
Could also be a pinched wire... Currently chasing this on my own car.
biketx2812 is offline   Reply With Quote
Old 01-24-2008, 12:22 PM   #6
bcarm
Member#: 100068
2010 Outback
I had a similar problem with my passenger side door. Especially when it was cold out, my speaker somewhere in the wiring would ground itself out on the body and I'd lose all sound except for my powered sub.
bcarm is offline   Reply With Quote
Old 01-24-2008, 10:37 PM   #7
DFWrxWagon
Member#: 154005
2004 WRX Wagon
if they are the original Diamond Audio speakers from 2002-2004 era, its actually the cone material. Diamond actually had a problem with the early speakers, woofers & tweeters literally shattering in to pieces in extreme cold climates. They had to redesign the cone materials...
I would vote for a broken, stressed or pinched wire... not making contact when it shrinks (cold) & then making contact when warmed up. Very likely in the crimp connector on the speaker or could be on the crossovers too... which reminds me of another issue Diamond Had back in the day... capacitors breaking/loosing connection on the circuit board in the crossover cases.
Rob
DFWrxWagon is offline   Reply With Quote
Old 01-25-2008, 08:39 AM   #8
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Wow, I was just shooting at the moon with my reply, but you seemingly are backing up my statements....
Old 01-25-2008, 09:28 AM   #9
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Could also be the speaker is literally frozen...water pours inside the door when it rains, usually coating the back of the speaker. If it went below freezing before drying off, it could freeze the coil in the gap until the current from playing music thawed it and it broke free.
Just a thought, and it's only possible if it was raining the day before or that night.
Old 01-25-2008, 09:34 AM   #10
djpast
Member#: 31016
2016 Focus RS (blue)
2005 WRX Wagon (white)
I have had subs freeze before, just from the interior humidity of the car freezing them solid. you could try and press them down in the box and feel that it was frozen. my recommendation is start warming your car up in cold weather for a few minutes (you should try to do this anyways) before you leave with the radio off (not good for the driver to try and move the speaker while its frozen) and then once the car is warm, then give it a try.
djpast is offline   Reply With Quote
Old 01-25-2008, 05:19 PM   #11
All4thaN0okie
Member#: 103037
2006 VF43'd WRX TR
Surgeline Tuned
Thanks for all the suggestions guys, sounds like I'm pretty much going to have to check everything from the crossovers to the speakers. The problem with this is that I'm probably going to wait until its warm outside to do this, so I hope it will be obvious LOL.
Old 01-25-2008, 10:00 PM   #12
dougkmcse
Member#: 85938
2004 WRX
The speaker is frozen...... I had the same issue. Checked everything then i opened the door up and the woofer would not move. Wait till the morning when it is not working open the door up and check the speaker. It will save you a lot of time checking things. I took the speaker inside and let it warm up and dry out it solved the problem for the last few days. Good luck
dougkmcse is offline   Reply With Quote
Old 01-25-2008, 11:48 PM   #13
DFWrxWagon
Member#: 154005
2004 WRX Wagon
ask a friend, work, local business for a favor. Park the car, with doors open, batt disconnected overnight. Warm/above abient temps is the goal...
see what happens.
Rob
people who commute on a motorcycle in cold weather and complain about being cold cnw Off-Topic 51 10-20-2009 02:09 PM
Gas smell that is not related to cold weather ImpreziveWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-08-2006 08:41 PM
Amp not working in the cold? RacerinLSL Car Audio, Video & Security 3 02-05-2006 05:13 PM
My STI Does NOT like the cold weather!!!! Mikemar Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 11-12-2004 04:28 PM
head lights not coming in cold weather reaubideux Electrical & Lighting 1 11-27-2003 09:28 PM
