#1 |
Member#: 152933
Vehicle:CT9A TB |
![]() Grimm speed has not tested it yet and the person who is hasnt told them the answer yet. My question to you is will the grimm speed ewg work with the turboxs downpipe? I dont want to order it and have to buy a whole new exhaust. But thats what will happen if it doesnt fit. So does anyone know?
#2 |
Member#: 147339
Vehicle:05 STi |
![]() I'm the one testing it for them. I got it in last Thursday in the middle of my FMIC install. I'll have an answer for you very soon
#3 |
Member#: 162942
Vehicle:2006 STi Black&Gold Stage 2 |
![]() Hmmm the Turbo XS Downpipe does look pretty big. Clearance problems you got there. You should of just got the Whole TurboXs EWG Up-Pipe and DP kit.
#4 |
Member#: 152933
Vehicle:CT9A TB |
![]() Im ordering it monday and Ill make it fit, either with a big fing hammer or a tanabe downpipe.
#5 |
Member#: 92894
BAIC
Vehicle:2015 Wrx |
![]() subcribed waiting on more info from bluegrasswrx
#6 |
Member#: 129790
BAIC
Vehicle:2006 VF39 WRX Waygon XPT Boooosted! |
![]() Has Grimmspeed put out any poorly fit products to date?
Not to my knowledge, but I`d wait to see the test results! |
#7 |
Member#: 12682
![]() If the Grimm Speed EWG setup doesn't clear your TXS downpipe try putting a torch to it and bang the downpipe a tad. That's of coarse if A. It doesn't fit or B. You don't want to spend the extra money on a new downpipe. I've seen it done before on a Ultimate racing external setup and the hammering to the TXS Downpipe didn't effect the flow one bit. Still made 390whp on a FP Green.
#8 |
Member#: 136246
SWIC
Vehicle:07 WRX 39 swap 555 motorsports tuned |
![]() Which txs dp do you have. The big 4" bell mouth? They have 2 different dp's. One that is designed for ewg (which tapers to 3" alot sooner) and then the monster 4" From what I have researched and checked out, P & L's ewg kit is the only one tested and designed around the 4" bell mouth. Not that grimmspeeds won't work. I am currently in the same boat as too looking for an ewg up pipe solution.
*Subscribed* |
#9 |
Member#: 147339
Vehicle:05 STi |
![]() Ok I will be trying to get this fitted tomorrow. I will give an update when I figure out if it will fit or not.
#10 |
Member#: 136246
SWIC
![]() If your able to get pics I know I would appreciate it. Just to see how much clearance is actually there. Bluegrass you have the 4" bellmouth right?
#11 |
Member#: 152933
Vehicle:CT9A TB |
![]() I have the 4 inch, but I also have a tanabe so Ill be able to make it work either way.
#12 |
Member#: 136246
SWIC
![]() I believe that txs will swap out my dp if I want to for the smaller of the two so I can run an ewg prefabed up pipe instead of fabbing one up.
#13 |
Member#: 162942
![]() yeap u have to swap that downpipe with a different one im guessing.
#14 |
Member#: 136246
SWIC
![]() Unless I go with P & L's ewg up pipe. So far they are the only ones that make an ewg up pipe for the big bell mouth.
#15 |
Member#: 147339
Vehicle:05 STi |
![]() Got it installed. Here is what I've noticed. The dump tube seems to be out of the way of the axle. The wastegate is touching the DP ever so slightly, I'm talking like mayyybe 1/8 inch, which I'm thinking will be fine. I'm uploading some pics I took right now.
#16 |
Member#: 147339
Vehicle:05 STi |
#17 |
Member#: 136396
Vehicle:2015 WRX, 2012 WRX, 2013 BRZ, 2006 STI |
![]() edit. just saw your post.
so the grimmspeed ewg up pipe fits the giant 4" txs bellmouth..or at least mostly fits. we have some sneaky things coming soon that may make the wastegate not touch the down pipe at all..not even the ever so slightly that you have. loosen up those dump tube bolts and push the dump tube up a bit, hold it, then tighten down the bolts again. that may give you more room. Last edited by GrimmSpeed; 01-29-2008 at 12:40 AM. |
#18 | |
Member#: 147339
Vehicle:05 STi |
![]() Quote:
Good. Glad you saw it. I was going to call you tomorrow and let you know. I am not worried about the wastegate. I'm just really glad it fit as good as it did, and that I didn't have to beat the DP any. Glad to hear you got some tricks up your sleeves. Hopefully this test fit will help your sales, it's an awesome product. I thought about wrapping the dump tube to keep the cv boot from melting. And maybe also putting a washer or two on the bottom bolt to kind of tilt the dump tube. I'll try your idea as well. |
#19 |
Member#: 115819
Vehicle:2006 vf39 R0mRa1DeR Darknessess Wagon |
![]() Can't wait for the 44mm
#20 |
Member#: 89554
Vehicle:2006 EVO SE Black E85 30PSI dd |
![]() not trying to bash a great product, but is the dump tube laying ontop of the rubber cv boot a reason to be concerned. I feel like it would melt it, no?
#21 |
Member#: 136246
SWIC
![]() Yeah other then the dump tube routing and it looking like it hits the CV boot. I would be concerned about that. I have already rebuilt one CV boot and don't really feel like doing it again. Bluegrass thanks alot for the pics.
#22 |
Member#: 28897
Vehicle:2004 STOLEN WRX STI Blue/Gold |
![]() super close
#23 |
Member#: 136246
SWIC
![]() Nice looking product though. For the two minor issue, easily fixable, I may need to look into getting this. Once again Grimmspeed comes out with another great product.
#24 |
Member#: 152933
Vehicle:CT9A TB |
![]() **** and I just ordered a completly new exhaust because I didnt think this would fit with my txs 4 inch downpipe. O well.
#25 |
Member#: 136396
![]() i think because of the huge txs 4" downpipe pushing the wastegate down as far is it can go it is misaligning the dump tube. on a normal bellmouth this doesnt happen, you will have room all the way around the axel boot....just didnt want this example to mislead everyone that has normal 3" downpipes.
i'm just pumped you 4" txs dp guys have the option of running this now ![]() Justin |
08 sti Cobb AP 500$ firm, and turboXS downpipe | blubalzwrx | Engine/Power/Exhaust | 4 | 06-20-2010 10:10 AM |
grimm speed ewg up pipe and tial 38mm | Richmond WRX | Engine/Power/Exhaust | 3 | 03-12-2009 03:30 PM |
grimms 44 ewg questions | 06HAWKMAN | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 12-11-2008 07:34 AM |
Grimm speed ewg/ upipe | Zspectrum | TXIC Private Classifieds | 4 | 03-11-2008 11:38 AM |
uppipe and turboxs downpipe for sale | rjrutzky | Private 'For Sale' Classifieds | 8 | 08-17-2005 08:05 PM |
