Tire & Wheel Forum sponsored by The Tire Rack |
01-28-2008, 12:52 PM | #1 |
Member#: 77308
Vehicle:'05 STi White |
Wheel and tires sizes for the GC8?
I could not find a thread that lists what wheel and tire sizes will fit the '98 - '01 RS. Before people get mad and post up the search link, could someone be kind enough to just post the link to where I can find this info.
Thank you
01-28-2008, 01:23 PM | #2 |
Member#: 92778
NESIC
Vehicle:2000 Impreza 2.5RS |
It's 5x100 PCD, so wheel selection is not too much different than the GD WRX. Factory wheel/tire setup is 16x7" +53 with 205/55-16 tires.
225 tires on stock offset wheels will be really close to rubbing in the rear, both on the fender and the lower strut perch (depending on the tire). Front has room for 245's (a few autocross setups have gone this route). Roll the rear fender enough and there should be room for 225+ tires. Alternatively, run spring rates stiff enough to keep the tire off the fender (not reccomended for lots of street driving). I use RE-070s on '04 STi BBS wheels. I ignore the rubbing in the back because it's an autocross only setup. |
01-28-2008, 01:39 PM | #3 |
Member#: 77308
Thank you for the reply.
I'm having a hard time finding more than two lowering springs for the GC8. So far I've found Tanabe GF210's and some Prodrive P1's. Are there any others? |
01-29-2008, 01:36 PM | #4 |
Member#: 92778
NESIC
I'm using STi Tarmac/Gymkhana springs with Koni inserts. Minimal drop (about 14" front and rear for me) and the highest spring rates available for a GC fixed perch setup (286 lb/in front, 274 lb/in rear). Works great for local autocross and isn't bad in snow.
wheel and tire size for sti | whitesti04 | Tire & Wheel | 3 | 11-24-2005 05:08 PM |
Preferred Wheel and Tire Size for STX? | Zoinks | Motorsports | 22 | 09-29-2004 02:25 PM |
Best wheel and tire size for a 2001 RS. | Space Boy Matt | Tire & Wheel | 4 | 12-06-2003 03:04 PM |
Offsets and tire sizes for GC8 | Bobby321 | Brakes, Steering & Suspension | 5 | 07-03-2002 11:55 AM |
Whats The Best Wheel And Tire Size Setup? | Turk | General Forum Archive | 1 | 07-25-2000 10:15 AM |
